    Jellyfin Forum Support Troubleshooting Playback problem
    Playback problem
    GOBOXS
    Banned
    Threads: 8
    2025-01-27, 06:06 AM
    I play on ios android tv and web with file movies on rclone and raidrive , jellyfin direct stream, i try play same file on emby plex , direct play , i make script , jellyfin play link with script connect with rclone , it direct play , this problem is direct stream , cpu still work hard when direct stream , ffmpeg make more small file
    2025-01-27, 01:06 PM
    Can you share the ffmpeg log from the direct streams?
    GOBOXS
    Banned
    Threads: 8
    2025-01-27, 07:32 PM
    This log , it don't direct play , it direct stream and make more small file .mp4 in cache , cpu work hard some time over 90% and down and up . i tested on emby and plex , it direct play , in cache clear .
    .txt   LOG.txt (Size: 28.53 KB / Downloads: 129)
    2025-01-27, 09:40 PM (This post was last modified: 2025-01-27, 09:41 PM by TheDreadPirate.)
    On Android TV, did you enable Dolby passthrough in the Jellyfin app?
    GOBOXS
    Banned
    Threads: 8
    2025-01-28, 03:40 AM
    (2025-01-27, 09:40 PM)TheDreadPirate Wrote: On Android TV, did you enable Dolby passthrough in the Jellyfin app?
    Android tv work fine , just ios app , i tried more time it direct stream , plex by web direct stream , jellyfin player windown is ok
    gnattu
    2025-01-28, 03:56 AM
    The stream looks fine to me to be honest. If the client cannot play the required audio it needs to be transcoded and if your server CPU is too weak that is nothing we can do and it is not a jellyfin issue. On iOS the app does not correctly detect multi channel audio support iirc so you have to manually set max audio channel to 6, but even that the server still needs to do remux but that should be less CPU intensive as most thing is now only stream copy.
    GOBOXS
    Banned
    Threads: 8
    2025-01-28, 07:13 AM
    (2025-01-28, 03:56 AM)gnattu Wrote: The stream looks fine to me to be honest. If the client cannot play the required audio it needs to be transcoded and if your server CPU is too weak that is nothing we can do and it is not a jellyfin issue. On iOS the app does not correctly detect multi channel audio support iirc so you have to manually set max audio channel to 6, but even that the server still needs to do remux but that should be less CPU intensive as most thing is now only stream copy.
    Thank you for your reply , but i check more time and sure playback ios app problem , why ? i click play mkv file from mount google drive by rclone , it play direct stream , i jump 5 min , check server it direct play , and again jump 5 min , it back direct stream , i make python script put link inside strm file , python script connect with rclone , jellyfin connect with script by link inside strm file , when i click play on ios app or web , check server it direct play , i test again with plex and emby same file , both direct play on ios app , i don't believe jellyfin can not do better , and am sure playback ios app problem or in server some wrong .
    i share my script can do direct play with cloud drive . you can look , i add content to script and all direct play , note: this problem with all file from cloud drive and local drive , always direct stream , i never lucky play cloud drive and local drive with direct play , but play hls is direct play .
    .txt   test direct play.txt (Size: 2.74 KB / Downloads: 95)
