    Jellyfin Forum Development Feature Requests Player for android TV and firetv
    need ability to turn off subtitles to play a video
    2024-08-08, 09:44 PM (This post was last modified: 2024-08-08, 09:47 PM by TheDreadPirate.)
    (2024-08-08, 09:39 PM)theguymadmax Wrote: I don’t have many files with DVD subtitles to test, but if all of them are failing, there might be a problem either on the server or on the client side. As an additional workaround, you can disable subtitles on the server. The AndroidTV client uses the server’s settings, so if you disable subtitles there, they won’t load automatically on the client.
    Go to Settings -> Subtitle and set Subtitle mode to None.
    Where is this setting?  The subtitle config in the library settings is the only one I know of that applies to all clients.
    Also, I've only played PGS subbed content since 0.17 was released. But I'll test some of the DVDSUB content I have when I get home.
    Jellyfin 12.2 (Docker)
    #12
    2024-08-08, 09:49 PM
    On the home screen when you click on your avatar, you'll see the subtitle menu.
    2024-08-08, 09:57 PM
    Does that apply to your user across all devices?
    vince954
    2024-08-08, 10:15 PM
    I think I had it set that way but will check. If so that would solve my problem. If you like I can share a movie file to test with. But having the ability to default subtitles off would resolve it for me.
    #15
    2024-08-08, 10:26 PM (This post was last modified: 2024-08-08, 10:29 PM by theguymadmax. Edited 1 time in total.)
    [18:09:11] [ERR] [120] Jellyfin.Api.Middleware.ExceptionMiddleware: Error processing request. URL GET /videos/fe9a5a0b-c2e2-f028-5f66-5326f8231f0f/hls1/main/0.ts.
    System.NullReferenceException: Object reference not set to an instance of an object.
      at MediaBrowser.MediaEncoding.Attachments.AttachmentExtractor.<>c.<ExtractAllAttachments>b__8_0(MediaAttachment a)
      at System.Linq.Enumerable.Any[TSource](IEnumerable`1 source, Func`2 predicate)
      at MediaBrowser.MediaEncoding.Attachments.AttachmentExtractor.ExtractAllAttachments(String inputFile, MediaSourceInfo mediaSource, String outputPath, CancellationToken cancellationToken)
      at MediaBrowser.MediaEncoding.Transcoding.TranscodeManager.StartFfMpeg(StreamState state, String outputPath, String commandLineArguments, Guid userId, TranscodingJobType transcodingJobType, CancellationTokenSource cancellationTokenSource, String workingDirectory)
      at Jellyfin.Api.Controllers.DynamicHlsController.GetHlsVideoSegment(Guid itemId, String playlistId, Int32 segmentId, String container, Int64 runtimeTicks, Int64 actualSegmentLengthTicks, Nullable`1 static, String params, String tag, String deviceProfileId, String playSessionId, String segmentContainer, Nullable`1 segmentLength, Nullable`1 minSegments, String mediaSourceId, String deviceId, String audioCodec, Nullable`1 enableAutoStreamCopy, Nullable`1 allowVideoStreamCopy, Nullable`1 allowAudioStreamCopy, Nullable`1 breakOnNonKeyFrames, Nullable`1 audioSampleRate, Nullable`1 maxAudioBitDepth, Nullable`1 audioBitRate, Nullable`1 audioChannels, Nullable`1 maxAudioChannels, String profile, String level, Nullable`1 framerate, Nullable`1 maxFramerate, Nullable`1 copyTimestamps, Nullable`1 startTimeTicks, Nullable`1 width, Nullable`1 height, Nullable`1 maxWidth, Nullable`1 maxHeight, Nullable`1 videoBitRate, Nullable`1 subtitleStreamIndex, Nullable`1 subtitleMethod, Nullable`1 maxRefFrames, Nullable`1 maxVideoBitDepth, Nullable`1 requireAvc, Nullable`1 deInterlace, Nullable`1 requireNonAnamorphic, Nullable`1 transcodingMaxAudioChannels, Nullable`1 cpuCoreLimit, String liveStreamId, Nullable`1 enableMpegtsM2TsMode, String videoCodec, String subtitleCodec, String transcodeReasons, Nullable`1 audioStreamIndex, Nullable`1 videoStreamIndex, Nullable`1 context, Dictionary`2 streamOptions)
      at lambda_method1872(Closure, Object)
      at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.InvokeInnerFilterAsync()
      at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.InvokeFilterPipelineAsync()
    [18:09:11] [INF] [120] Emby.Server.Implementations.Session.SessionManager: Playback stopped reported by app Android TV 0.17.1 playing Fist of Fury. Stopped at 0 ms
    [18:10:01] [INF] [117] Jellyfin.Api.Helpers.MediaInfoHelper: User policy for Max. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True
    [18:10:09] [INF] [120] Emby.Server.Implementations.Session.SessionManager: Playback stopped reported by app Android TV 0.17.1 playing Fist of Fury. Stopped at 5553 ms
    [18:13:35] [INF] [84] Jellyfin.Api.Helpers.MediaInfoHelper: User policy for Max. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True
    I did two separate tests (mp4 container with dvdsub) and they both had the same results. When I leave the subtitle mode to default the subs will load automatically and ATV will request a burn-in and the server will error out causing playback failure. When I set subtitle mode to none, the ATV starts without loading subtitles causing successful playback. ATV is the only non-web-based client I have to test.
    2024-08-08, 10:48 PM
    I also have a Roku Ultra 4800X to test with.
    I will be home in a couple hours and will report back on both the Roku and CCwGTV 4K with DVDSUBs.
    #17
    2024-08-09, 02:26 AM
    @TheDreadPirate
    I did additional testing and found that all MP4 files with DVDSUBs failed to play, each showing the same extraction error. These files also did not play in the web client. However, when I tested a DVDSUB file in an MKV container, it played successfully on both ATV and the web client. If you can verify this, it seems to be a bug with the server.
    Here's a pull request that notes ATV uses the server settings to enable subtitles by default.
    Log playing a MP4 DVDSUB file on the web client.
    2024-08-08 21:58:37.513 -04:00] [INF] [49] Jellyfin.Api.Helpers.MediaInfoHelper: User policy for "Max". EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True
    [2024-08-08 21:58:37.592 -04:00] [INF] [111] Jellyfin.Api.Controllers.DynamicHlsController: Current HLS implementation doesn't support non-keyframe breaks but one is requested, ignoring that request
    [2024-08-08 21:58:37.595 -04:00] [ERR] [111] Jellyfin.Api.Middleware.ExceptionMiddleware: Error processing request. URL "GET" "/videos/fe9a5a0b-c2e2-f028-5f66-5326f8231f0f/hls1/main/-1.mp4".
    [2024-08-08 21:58:37.666 -04:00] [INF] [21] Emby.Server.Implementations.Session.SessionManager: Playback stopped reported by app "Jellyfin Web" "10.9.9" playing "Fist of Fury". Stopped at "0" ms
    2024-08-09, 02:35 AM (This post was last modified: 2024-08-09, 02:35 AM by TheDreadPirate. Edited 1 time in total.)
    I was going to ask the question about the container. My DVDSUB videos worked on both my Roku and CCwGTV 4K with the subtitles burned in. Just about all of my content is in MKV containers. Including the videos I just tested with.
    Bruce Almighty
    Container: mkv
    Path: /media/library/Movies/Bruce Almighty/Bruce Almighty.mkv
    Video
    Title: 404p HEVC SDR
    Codec: HEVC
    AVC: No
    Profile: Main
    Level: 90
    Resolution: 720x388
    Aspect ratio: 1.85:1
    Anamorphic: No
    Interlaced: No
    Framerate: 29.97003
    Bitrate: 3315 kbps
    Bit depth: 8 bit
    Video range: SDR
    Video range type: SDR
    Color space: smpte170m
    Color transfer: bt709
    Color primaries: smpte170m
    Pixel format: yuv420p
    Ref frames: 1
    Audio
    Title: Surround 5.1 - English - Dolby Digital - Default
    Language: eng
    Codec: AC3
    AVC: No
    Layout: 5.1
    Channels: 6 ch
    Bitrate: 448 kbps
    Sample rate: 48000 Hz
    Default: Yes
    Forced: No
    External: No
    Audio
    Title: Surround 5.1 - English - DTS
    Language: eng
    Codec: DTS
    AVC: No
    Profile: DTS
    Layout: 5.1
    Channels: 6 ch
    Bitrate: 768 kbps
    Default: No
    Forced: No
    External: No
    Audio
    Title: Stereo - English - Dolby Digital
    Language: eng
    Codec: AC3
    AVC: No
    Layout: stereo
    Channels: 2 ch
    Bitrate: 192 kbps
    Default: No
    Forced: No
    External: No
    Audio
    Title: Surround 5.1 - Fre - Dolby Digital
    Language: fre
    Codec: AC3
    AVC: No
    Layout: 5.1
    Channels: 6 ch
    Bitrate: 384 kbps
    Default: No
    Forced: No
    External: No
    Audio
    Title: Surround 5.1 - Spanish - Dolby Digital
    Language: spa
    Codec: AC3
    AVC: No
    Layout: 5.1
    Channels: 6 ch
    Bitrate: 384 kbps
    Default: No
    Forced: No
    External: No
    Subtitle
    Title: English - DVDSUB
    Language: eng
    Codec: DVDSUB
    AVC: No
    Resolution: 720x480
    Default: No
    Forced: No
    External: No
    Subtitle
    Title: Fre - DVDSUB
    Language: fre
    Codec: DVDSUB
    AVC: No
    Resolution: 720x480
    Default: No
    Forced: No
    External: No
    Subtitle
    Title: Spanish - DVDSUB
    Language: spa
    Codec: DVDSUB
    AVC: No
    Resolution: 720x480
    Default: No
    Forced: No
    External: No
    vince954
    2024-08-09, 10:25 PM (This post was last modified: 2024-08-09, 10:26 PM by vince954. Edited 1 time in total.)
    i can send you a link to get some files to test with. note that i am using the windows versio of the server. not sure if this matters. upon some more testing i can confirm i have the server set up to none on subtitles but the players seem to always deault to on and give the error. as far as i can tell its only the androidtv player that does this, strange.. the workaround i am using is to set a button to select subtitles and then turn it off when you start playing the file... this seems to work for now.
    2024-08-09, 10:54 PM
    You could remux your MP4s into MKVs. No re-encoding required.
