    Jellyfin Forum Support Troubleshooting Playlist disappear right after library scan
    Pages (3): « Previous 1 2 3
    Jolaru21
    Threads: 29
    Country:Spain
    #21
    2024-10-01, 04:51 PM
    I will check for any permission issue, but the github says that I'm not the only one XD
    Jolaru21
    Threads: 29
    Country:Spain
    #22
    2024-10-01, 05:16 PM (This post was last modified: 2024-10-01, 05:16 PM by Jolaru21.)
    I tried to give both folders of jellyfin full permission and I can't create playlists anymore:
    [2024-10-01 19:13:09.819 +02:00] [ERR] [33] Jellyfin.Api.Middleware.ExceptionMiddleware: Error processing request. URL "POST" "/Playlists".
    System.ArgumentException: parentFolder
    at Emby.Server.Implementations.Playlists.PlaylistManager.CreatePlaylist(PlaylistCreationRequest request)
    at Jellyfin.Api.Controllers.PlaylistsController.CreatePlaylist(String name, IReadOnlyList1 ids, Nullable1 userId, Nullable1 mediaType, CreatePlaylistDto createPlaylistRequest)
    at lambda_method866(Closure, Object)
    at Microsoft.AspNetCore.Mvc.Infrastructure.ActionMethodExecutor.AwaitableObjectResultExecutor.Execute(ActionContext actionContext, IActionResultTypeMapper mapper, ObjectMethodExecutor executor, Object controller, Object[] arguments)
    at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.<InvokeActionMethodAsync>g__Awaited|12_0(ControllerActionInvoker invoker, ValueTask
    1 actionResultValueTask)
    at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.InvokeInnerFilterAsync()
    at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.InvokeFilterPipelineAsync()
    [2024-10-01 19:13:12.697 +02:00] [INF] [33] Emby.Server.Implementations.HttpServer.WebSocketManager: WS "127.0.0.1" closed
    Maybe if I revert changes it works, but first I wanted to share with you
    Jolaru21
    Threads: 29
    Country:Spain
    #23
    2024-10-02, 09:12 AM
    I installed on a VM jellyfin server again, and tried to add a media to a playlist, but in this case, it isn't removed after scan. So probably, its something related to my JF installation.
    Any recommendations to export all my config to a fresh installation? (users, library, .nfo, content...) or isn't recommended for this case?
    2024-10-02, 01:29 PM
    The problem is that migrating MIGHT cause the problem to follow.
    It doesn't hurt to try, though.
    You should be able to migrate everything by moving this folder.
    C:\Users\Plex\AppData\Local\Jellyfin
    But your new VM needs to also have a Plex user since some data uses absolute paths.
    Jolaru21
    Threads: 29
    Country:Spain
    #25
    2024-10-02, 03:06 PM
    Understood,
    Thank you!
