    Jellyfin Forum Support Troubleshooting Please help, Jellyfin 10.9 won't play live streams
    Jellyfin dropping playback after initiating call up of streams
    Peter Alfieri
    2024-08-24, 12:16 AM
    (2024-08-23, 11:26 PM)TheDreadPirate Wrote: I believe TVHeadEnd can also handle multi-stream HLS M3U's.
    Sounds great, I already made my docker-compose for tvheadend and have it running via portainer, I'll let you know how I make out with tvheadend.
    Thank you and have a nice night
    Peter Alfieri
    2024-08-24, 12:19 PM (This post was last modified: 2024-08-24, 01:19 PM by Peter Alfieri. Edited 1 time in total.)
    Good Morning,
    Well, after several hours of finally getting TVheadend to recognize SOME of the m3u and epg data, Jellyfin is still not playing the streams. I should add this too, TVheadend roughly only found half of the streams and after all the work I've put in I'm thoroughly disgusted; TVheadend doesn't make anything easy, it's interface is the same antiquated mess it was years ago when I tried it out. Please pardon my frustration, however,  I've wasted 8 hours of my life that I'll never get back and I have so much contempt towards TVheadend that I'm absolutely done using it.
    EDIT: I have no idea why things started working again, however, I unchecked Auto Loop Streams and Ignore DTS timestamps and now it's working. I have no idea what happened, but, I think before updating to 10.9.9 I had the same problem and checked the aforementioned options.
    I would like to seriously apologize for wasting your time and for my palpable frustration with TVheadend.
    Thank you and have a great day.
    Peter Alfieri
    2024-08-25, 09:43 AM (This post was last modified: 2024-08-25, 09:44 AM by Peter Alfieri. Edited 1 time in total.)
    Good morning,
    So, looks like my problem is back, however, this time I think I found a clue. So, after a server reboot, the same streams failed to play once again without even trying to load the stream, I went into the live TV setting and RE-checked "Autoloop Streams" and "Ignore DTS", once again, the streams would TRY to load this time but ultimately failed without playing a single frame. Then, again like yesterday, I UNchecked "Autoloop Streams" and "Ignore DTS" and VIOLA, it's now working again.
    Now that this is isolated or at the very least, narrowed things down, what are your thoughts?
    Logs are attached.
    Thank you and have a nice day.
    .gz   nostradamus.enable-disable-enable-liveTV-settings_8-25-24.tar.gz (Size: 124.97 KB / Downloads: 112)
    Peter Alfieri
    2024-08-26, 01:05 PM
    Good morning,
    Update:
    I updated to 10.9.10 and the results are still the same.
    I've narrowed this down to the Autoloop Streams feature. Every time I restart Jellyfin I need to tick off Autoloop, run a scan, then untick Autoloop, run another scan, and after that the streams can be watched.
    I've done this more than a dozen times over the last few days, it's repeatable and consistent.
    This is clearly a bug that's in the 10.9 branch.
    I can attach another log, however, without any input I feel like it's going on deaf-ears considering I'm not getting any feedback.
    Please advise.
    2024-08-26, 03:08 PM
    Go ahead and submit an issue on the jellyfin github.
