    Jellyfin Forum Support General Questions Plugin trakt problem
    rakt plugin duplicating everything I watch.
    Jonas6io
    Country:Brazil
    2023-12-13, 11:21 PM
    Hello, I use the Takt plugin available in Jellyfin, and recently, I started watching on Android. The issue is that I set ExoPlayer as the primary player, and when I watch something, the plugin sends it to Trakt twice. Is there any way to resolve this using ExoPlayer, or do I have to use the default player?
    Sorry if this isn't the ideal place.
    tmsrxzar
    2023-12-13, 11:47 PM
    exoplayer IS the default player. did you make a typo or are you using a different exoplayer that did not come with your android device?
    Jonas6io
    Country:Brazil
    2023-12-14, 03:10 PM
    (2023-12-13, 11:47 PM)tmsrxzar Wrote: exoplayer IS the default player. did you make a typo or are you using a different exoplayer that did not come with your android device?
    On Android Jellyfin settings > video player type, the default is "Web player," which is already selected. However, I changed it to the "Integrated player," based on ExoPlayer, and this leads to the error of duplicating entries on Trakt.
    tmsrxzar
    2023-12-14, 03:45 PM
    nevermind i was thinking android "TV", you're just on an android
