    Jellyfin Forum Support General Questions Problem start jellybin
    Pages (3): « Previous 1 2 3
    Paro89
    2025-04-11, 04:35 PM (This post was last modified: 2025-04-11, 04:48 PM by Paro89. Edited 1 time in total.)
    I do it, but it doesn't work, Jellyfin continue to doesn't see the HDD. But now if i try to enter in th4e HDD i can't because Ubuntu say me that i have not the permission!!
    Online
    Threads: 12
    2025-04-11, 05:20 PM
    What file system is that hard drive using?
    cat /proc/mounts | grep "/media"
    Jellyfin 12.4 (Docker)
    Paro89
    2025-04-11, 06:14 PM
    /dev/sdd /media/paro/Telefilm\0402 ntfs3 rw,nosuid,nodev,relatime,uid=1000,gid=1000,iocharset=utf8 0 0
    /dev/sdc /media/paro/Telefilm ntfs3 rw,nosuid,nodev,relatime,uid=1000,gid=1000,iocharset=utf8 0 0
    Online
    Threads: 12
    2025-04-11, 06:39 PM (This post was last modified: 2025-04-11, 06:40 PM by TheDreadPirate. Edited 1 time in total.)
    Oooooohhh. I assumed it was ext4. Since they are NTFS it does require ACLs, period.
    sudo setfacl -m user:paro:rwx,group:paro:rwx,group:jellyfin:r-x,other::--- /media/paro/Telefilm*
    I think that should give both you and Jellyfin access. If that partially works, you may need to recursively run the command with the -R parameter.
    sudo setfacl -m user:paro:rwx,group:paro:rwx,group:jellyfin:r-x,other::--- -R /media/paro/Telefilm*
    Paro89
    2025-04-11, 06:43 PM (This post was last modified: 2025-04-11, 06:45 PM by Paro89.)
    setfacl: /media/paro/Telefilm: Operazione non supportata
    Operation not supported
    (2025-04-11, 06:39 PM)TheDreadPirate Wrote: Oooooohhh.  I assumed it was ext4.  Since they are NTFS it does require ACLs, period.
    setfacl: /media/paro/Telefilm*: File o directory non esistente
    With *: File or directory does not exist.
    Without *: Operation not supported
    Online
    Threads: 12
    2025-04-11, 08:08 PM
    "Operation not supported" tells me that I mistyped the path in the example I provided. The "target" needs to be correct.
    Make sure that the path is correct. Not sure if I'm missing a special character somewhere.
    Paro89
    2025-04-11, 08:30 PM
    Ok, it works. The right command was: sudo setfacl -m user:paro:rwx,group:paro:rwx,group:jellyfin:r-x,other::--- /media/paro/
