    Jellyfin Forum Support Troubleshooting Problem with detection of shows
    Jellyfin not displaying shows properly
    Galaxyraider20
    Country:India
    2025-05-22, 05:30 AM (This post was last modified: 2025-05-22, 05:45 AM by Galaxyraider20. Edited 1 time in total.)
    Here's the basic structure of my setup. I'm running proxmox on my computer. On proxmox -> Linux VM -> docker -> jellyfin. I'm using the docker-compose to run jellyfin. And I navigated the media folder correctly. Inside my media folder my file structure looks like media/Shows/The Big Bang Theory/Season 01/[episode name S01E01].mkv. the full path is mnt/nasdata/data/media/Shows/The Big Bang Theory/Season 01/
    I started jellyfin and created a library called shows and mapped it to Shows. I have two things there The Big Bang Theory and How I Met Your Mother. And one episode each inside
    However when Looking at jellyfin, under shows I can only see one of them(seems to be random which one) and inside that show it's just empty. (all screenshots attached)
    However I can see the episodes in recently added.
    I have tried everything and cannot get jellyfin to detect these shows properly. Been at this for the last 5-6 hours. Any help would be appreciated a lot!!!!
    ps: I'm setting up a homelab for the first time so pretty new to this stuff.
    [2025-05-22 04:38:52.348 +00:00] [INF] [26] Emby.Server.Implementations.Library.LibraryManager: Removing item, Type: "Series", Name: "The Big Bang Theory", Path: "/media/tv-shows/The Big Bang Theory", Id: 6b12dd77-80a5-1fad-f0dd-ae971cd7a8f8
    this was in the logs
    2025-05-22, 11:16 PM
    Try changing names to follow the guidelines in the Jellyfin docs. The odd things I spot are the colons, the lack of zero padding for season and episodes, and (possibly) the space-hyphen-space naming convention which can confuse the hell out of Jellyfin on occasion.
    One thing that seems to make a lot of difference for folks is adding the show ID to the series folder (no need for seasons).
    2025-05-22, 11:44 PM
    TMDB is blocked in India.  Download the TVDB plugin from the catalog and set that as the preferred metadata source in your library.
    https://forum.jellyfin.org/t-solved-medi...8#pid35198
