    Jellyfin Forum Support Troubleshooting Problem with remote playback
    Remote Playback not possible with some devices.
    ice-p
    2025-01-13, 07:22 PM
    Ok, will try with disabled proxy. Is disabling proxy an security risk or is it ok?
    Here is the nginx-proxy-config:
    https://pastebin.com/u9Mhmbeh
    2025-01-13, 07:44 PM
    I don't want you to disable the proxy permanently. But let's remove it as a factor briefly. Can you share the contents of these three files?
    conf.d/include/block-exploits.conf
    conf.d/include/proxy.conf
    /data/nginx/custom/server_proxy[.]conf
    ice-p
    2025-01-13, 08:46 PM
    i was not able to paste it in pastebin because of the content. Here are both files, the server.conf file did not exist in my environment.
    cat block-exploits.conf
    ## Block SQL injections
    set $block_sql_injections 0;
    if ($query_string ~ "union.*select.*\(") {
    set $block_sql_injections 1;
    if ($query_string ~ "union.*all.*select.*") {
    if ($query_string ~ "concat.*\(") {
    if ($block_sql_injections = 1) {
    return 403;
    ## Block file injections
    set $block_file_injections 0;
    if ($query_string ~ "[a-zA-Z0-9_]=http://") {
    set $block_file_injections 1;
    if ($query_string ~ "[a-zA-Z0-9_]=(\.\.//?)+") {
    if ($query_string ~ "[a-zA-Z0-9_]=/([a-z0-9_.]//?)+") {
    if ($block_file_injections = 1) {
    return 403;
    ## Block common exploits
    set $block_common_exploits 0;
    if ($query_string ~ "(<|%3C).*script.*(>|%3E)") {
    set $block_common_exploits 1;
    if ($query_string ~ "GLOBALS(=|\[|\%[0-9A-Z]{0,2})") {
    if ($query_string ~ "_REQUEST(=|\[|\%[0-9A-Z]{0,2})") {
    if ($query_string ~ "proc/self/environ") {
    if ($query_string ~ "mosConfig_[a-zA-Z_]{1,21}(=|\%3D)") {
    if ($query_string ~ "base64_(en|de)code\(.*\)") {
    if ($block_common_exploits = 1) {
    return 403;
    ## Block spam
    set $block_spam 0;
    if ($query_string ~ "\b(ultram|unicauca|valium|viagra|vicodin|xanax|ypxaieo)\b") {
    set $block_spam 1;
    if ($query_string ~ "\b(erections|hoodia|huronriveracres|impotence|levitra|libido)\b") {
    set $block_spam 1;
    if ($query_string ~ "\b(ambien|blue\spill|cialis|cocaine|ejaculation|erectile)\b") {
    set $block_spam 1;
    if ($query_string ~ "\b(lipitor|phentermin|pro[sz]ac|sandyauer|tramadol|troyhamby)\b") {
    set $block_spam 1;
    if ($block_spam = 1) {
    return 403;
    ## Block user agents
    set $block_user_agents 0;
    # Disable Akeeba Remote Control 2.5 and earlier
    if ($http_user_agent ~ "Indy Library") {
    set $block_user_agents 1;
    # Common bandwidth hoggers and hacking tools.
    if ($http_user_agent ~ "libwww-perl") {
    if ($http_user_agent ~ "GetRight") {
    if ($http_user_agent ~ "GetWeb!") {
    if ($http_user_agent ~ "Go!Zilla") {
    if ($http_user_agent ~ "Download Demon") {
    if ($http_user_agent ~ "Go-Ahead-Got-It") {
    if ($http_user_agent ~ "TurnitinBot") {
    if ($http_user_agent ~ "GrabNet") {
    if ($block_user_agents = 1) {
    return 403;
    and here the other file
    cat proxy.conf
    add_header      X-Served-By $host;
    proxy_set_header Host $host;
    proxy_set_header X-Forwarded-Scheme $scheme;
    proxy_set_header X-Forwarded-Proto  $scheme;
    proxy_set_header X-Forwarded-For    $proxy_add_x_forwarded_for;
    proxy_set_header X-Real-IP          $remote_addr;
    proxy_pass      $forward_scheme://$server:$port$request_uri;
    2025-01-13, 09:27 PM
    Your nginx config looks fine.
    (2025-01-13, 07:22 PM)ice-p Wrote: Ok, will try with disabled proxy. Is disabling proxy an security risk or is it ok?
    Coming back to this, are you asking about disabling nginx?  Or the cloudflare proxy?
    ice-p
    2025-01-13, 10:01 PM
    I asked about cloudflare proxy. Nginx i would never disable for something published outside Smiling-face
    2025-01-13, 10:28 PM
    Its only a security risk if you don't trust the people you share Jellyfin with.
    ice-p
    2025-01-14, 07:44 AM
    ok understand, thanks Smiling-face
    So nginx should work fine. I will start a test with my friend to check without proxy on cloudflare enabled.
    any other sugeestions?
    What I think was weired is, that the mobile phones would work out of the box even with proxy enabled. Just fire-tv has these problems.
    ice-p
    2025-01-14, 08:07 PM
    atm we are having issues with my friend authenticating. Since i disabled proxy on cloudflare he is not able to connect and gets an timeout error when trying to connect to my url.
    from mobile phone it is working, also when i try to connect from my site or cellular i can connect. any ideas? i would like to test it but atm not possible. We also restarted the router, deleted the app on firetv and booted the fire tv stick.
    2025-01-14, 08:32 PM
    Maybe DNS caching? What client are they using?
    ice-p
    2025-01-14, 11:08 PM
    the standard jellyfin app for fire tv stick
