    Jellyfin Forum Support Troubleshooting Problem with Transcoding after update to 10.8.12
    vin86
    2023-11-09, 09:33 PM (This post was last modified: 2023-11-09, 09:46 PM by vin86. Edited 1 time in total.)
    Hi,
    i have installed on my Synology DS218+ Jellyfin 10.8.11. I have enabled with success transcoding with tone mapping and works like a charm. After update to new version 10.8.12, transcoding doesn't works. On system log i have this error:"  No VA display found for device /dev/dri/renderD128"
    If i revert to "old" version 10.8.11 transcoding works without problems.
    2023-11-09, 09:49 PM
    Support for Linux kernel 4.x was dropped in the newer Intel drivers included in the official jellyfin docker. 4.X is the current version of the Linux kernel Synology uses with their OS. To be clear, this is something Intel did.
    Your options are to stay on the official 10.8.11 image or experiment with using unofficial images.
    https://docs.linuxserver.io/images/docker-jellyfin/
    https://github.com/linuxserver/docker-mo...encl-intel
    Your current jellyfin database and configs should be used by most unofficial images without issue. But always backup your data before hand, just in case.
    vin86
    2023-11-09, 10:13 PM (This post was last modified: 2023-11-09, 10:14 PM by vin86. Edited 1 time in total.)
    This "problem" will be resolved in future release?
    i have tested other version but transcoding doesn't works
    2023-11-09, 10:19 PM
    Whenever Synology updates the Linux kernel in DSM to 5.X or newer will the official Jellyfin image for .12 work.
    For the Linuxserver.io image, you have to install the "OpenCL Mod" to get tone mapping to work with their image. Or did that not work either?
    vin86
    2023-11-09, 10:28 PM
    linuxserver/jellyfin works only with tone mapping if i select vaapi and vpp tone mapping. colors are bad and i not prefer this solution.
    surely sinology will not update the kernel to version 5.x. bad news.
    problably version 10.8.11 will be latest release for synology nas at this point
    vin86
    2023-11-10, 09:47 AM
    i think that a possible solution it's install into a virtual machine on nas a instance of ubuntu and install jellyfin on it. right?
    2023-11-10, 01:04 PM
    Only if Synology DSM supports GPU passthrough for VMs.
