    Jellyfin Forum Support Troubleshooting Problems with LiveTV MPEG2
    Kubwa
    Yesterday, 09:25 AM (This post was last modified: Yesterday, 09:27 AM by Kubwa. Edited 3 times in total.)
    Hello, i have a weird problem with LiveTV from an enigma2 receiver using Jellyfin.
    In the browser, the stream is not starting at all when trying to watch a channel encoded in mpeg2. It works fine with channels encoded in h264.
    Using the Jellyfin windows app, i can hear the audio but i dont have a video.
    I saw two behaviors:
    1. ffmpeg is creating HUGE segment files, more than 400mb each. While doing so, ffmpeg creates the following output (i removed the passwords from the urls):
    {"Protocol":1,"Id":"5","Path":"http://root:***@10.1.0.7:8001/1:0:1:1391:D001:F101:FFFF0000:0:0:0:","EncoderPath":null,"EncoderProtocol":null,"Type":0,"Container":"ts","Size":null,"Name":null,"IsRemote":false,"ETag":null,"RunTimeTicks":null,"ReadAtNativeFramerate":false,"IgnoreDts":false,"IgnoreIndex":false,"GenPtsInput":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":true,"UseMostCompatibleTranscodingProfile":false,"RequiresOpening":false,"OpenToken":null,"RequiresClosing":true,"LiveStreamId":"e2329f4997b378e64ccf8fa396deb76e_45a57807e651402733f095051d6ed6b8_5","BufferMs":null,"RequiresLooping":false,"SupportsProbing":true,"VideoType":null,"IsoType":null,"Video3DFormat":null,"MediaStreams":[{"Codec":null,"CodecTag":null,"Language":null,"ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Rotation":null,"Comment":null,"TimeBase":"1/90000","CodecTimeBase":null,"Title":null,"VideoRange":1,"VideoRangeType":1,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":null,"LocalizedDefault":null,"LocalizedForced":null,"LocalizedExternal":null,"LocalizedHearingImpaired":null,"DisplayTitle":"144p SDR","NalLengthSize":null,"IsInterlaced":false,"IsAVC":null,"ChannelLayout":null,"BitRate":null,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":null,"SampleRate":null,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Height":0,"Width":0,"AverageFrameRate":null,"RealFrameRate":null,"ReferenceFrameRate":null,"Profile":null,"Type":1,"AspectRatio":null,"Index":-1,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":false},{"Codec":"mp2","CodecTag":null,"Language":null,"ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Rotation":null,"Comment":null,"TimeBase":"1/90000","CodecTimeBase":null,"Title":null,"VideoRange":0,"VideoRangeType":0,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":null,"LocalizedDefault":"Standard","LocalizedForced":null,"LocalizedExternal":"Extern","LocalizedHearingImpaired":null,"DisplayTitle":"MP2 - Stereo","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":"stereo","BitRate":192000,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":2,"SampleRate":48000,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Height":null,"Width":null,"AverageFrameRate":null,"RealFrameRate":null,"ReferenceFrameRate":null,"Profile":null,"Type":0,"AspectRatio":null,"Index":-1,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":null}],"MediaAttachments":[],"Formats":[],"Bitrate":192000,"FallbackMaxStreamingBitrate":null,"Timestamp":null,"RequiredHttpHeaders":{},"TranscodingUrl":null,"TranscodingSubProtocol":0,"TranscodingContainer":null,"AnalyzeDurationMs":3000,"DefaultAudioStreamIndex":null,"DefaultSubtitleStreamIndex":null,"HasSegments":false}
    ffmpeg -analyzeduration 3000000 -probesize 10000000 -f mpegts -init_hw_device d3d11va=dx11:,vendor=0x8086 -init_hw_device qsv=qs@dx11 -filter_hw_device qs -i "http://root:***@10.1.0.7:8001/1:0:1:1391:D001:F101:FFFF0000:0:0:0:" -map_metadata -1 -map_chapters -1 -threads 0 -sn -codec:v:0 h264_qsv -preset veryfast -b:v 704244980 -maxrate 704244980 -bufsize 1408489960 -profile:v:0 high -level 0 -vf "setparams=color_primaries=bt709:color_trc=bt709:colorspace=bt709,format=nv12" -codec:a:0 libfdk_aac -ac 2 -ab 256000 -copyts -avoid_negative_ts disabled -max_muxing_queue_size 2048 -f hls -max_delay 5000000 -hls_time 3 -hls_segment_type fmp4 -hls_fmp4_init_filename "R:\d8f4346af7e46467ed7bd1beb7c02568-1.mp4" -start_number 0 -hls_base_url "hls/d8f4346af7e46467ed7bd1beb7c02568/" -hls_segment_filename "R:\d8f4346af7e46467ed7bd1beb7c02568%d.mp4" -hls_playlist_type event -hls_list_size 0 -y "R:\d8f4346af7e46467ed7bd1beb7c02568.m3u8"
      built with clang version 19.1.7
      configuration: --cc=clang --pkg-config-flags=--static --extra-cflags=-I/clang64/ffbuild/include --extra-ldflags=-L/clang64/ffbuild/lib --prefix=/clang64/ffbuild/jellyfin-ffmpeg --extra-version=Jellyfin --disable-ffplay --disable-debug --disable-doc --disable-sdl2 --disable-ptx-compression --enable-lto=thin --enable-gpl --enable-version3 --enable-schannel --enable-iconv --enable-libxml2 --enable-zlib --enable-lzma --enable-gmp --enable-chromaprint --enable-libfreetype --enable-libfribidi --enable-libfontconfig --enable-libharfbuzz --enable-libass --enable-libbluray --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvorbis --enable-libopenmpt --enable-libwebp --enable-libvpx --enable-libzimg --enable-libx264 --enable-libx265 --enable-libsvtav1 --enable-libdav1d --enable-libfdk-aac --enable-opencl --enable-dxva2 --enable-d3d11va --enable-d3d12va --enable-amf --enable-libvpl --enable-ffnvcodec --enable-cuda --enable-cuda-llvm --enable-cuvid --enable-nvdec --enable-nvenc
    [AVHWDeviceContext @ 000002101fd2dd40] Using device 8086:1912 (Intel(R) HD Graphics 530).
    [mp3float @ 000002102194e4c0] Header missing
    [mpeg2video @ 0000021025a42cc0] Invalid frame dimensions 0x0.
    [mpegts @ 0000021025a58600] Could not find codec parameters for stream 2 (Unknown: none ([12][0][0][0] / 0x000C)): unknown codec
    Consider increasing the value for the 'analyzeduration' (3000000) and 'probesize' (10000000) options
    [mpegts @ 0000021025a58600] Could not find codec parameters for stream 4 (Unknown: none ([5][0][0][0] / 0x0005)): unknown codec
    Input #0, mpegts, from 'http://root:***@10.1.0.7:8001/1:0:1:1391:D001:F101:FFFF0000:0:0:0:':
      Duration: N/A, start: 8028.237789, bitrate: N/A
      Program 4177
      Program 4183
      Program 4247
      Program 4763
      Program 4764
      Program 4765
      Program 4871
      Program 4872
      Program 4873
      Program 4874
      Program 4875
      Program 4884
      Program 4896
      Program 4905
      Program 4956
      Program 4958
      Program 4959
      Program 4963
      Program 4965
      Program 4966
      Program 4967
      Program 4968
      Program 4969
      Program 4970
      Program 4971
      Program 4974
      Program 4981
      Program 5000
      Program 5009
      Stream #0:1[0x30](deu): Audio: mp2 (mp3float) ([3][0][0][0] / 0x0003), 48000 Hz, stereo, fltp, 192 kb/s
      Stream #0:2[0x33]: Unknown: none ([12][0][0][0] / 0x000C)
      Stream #0:3[0x69](deu): Subtitle: dvb_teletext ([6][0][0][0] / 0x0006)
      Stream #0:4[0x6c]: Unknown: none ([5][0][0][0] / 0x0005)
      Stream #0:5[0x6e](deu): Subtitle: dvb_subtitle (dvbsub) ([6][0][0][0] / 0x0006) (hearing impaired)
      Stream #0:6[0x71]: Data: bin_data ([6][0][0][0] / 0x0006)
      Stream #0:7[0xa3]: Video: mpeg2video (Main) ([2][0][0][0] / 0x0002), yuv420p(tv, bt470bg, top first), 720x576 [SAR 64:45 DAR 16:9], 25 fps, 25 tbr, 90k tbn
          Side data:
            cpb: bitrate max/min/avg: 15000000/0/0 buffer size: 1835008 vbv_delay: N/A
      Program 5011
      No Program
      Stream #0:0[0x12]: Data: epg
    Stream mapping:
      Stream #0:7 -> #0:0 (mpeg2video (native) -> h264 (h264_qsv))
      Stream #0:1 -> #0:1 (mp2 (native) -> aac (libfdk_aac))
    [mp2 @ 0000021025a12080] Header missing
    [aist#0:1/mp2 @ 0000021025c49d80] [dec:mp2 @ 000002101fd66140] Error submitting packet to decoder: Invalid data found when processing input
    [hls @ 0000021025ac20c0] Opening 'R:\d8f4346af7e46467ed7bd1beb7c02568-1.mp4' for writing
    Output #0, hls, to 'R:\d8f4346af7e46467ed7bd1beb7c02568.m3u8':
      Metadata:
        encoder        : Lavf61.1.100
      Stream #0:0: Video: h264, nv12(tv, bt709, top coded first (swapped)), 720x576 [SAR 64:45 DAR 16:9], q=2-31, 704244 kb/s, 25 fps, 12800 tbn
          Metadata:
            encoder        : Lavc61.3.100 h264_qsv
          Side data:
            cpb: bitrate max/min/avg: 704244980/0/704244980 buffer size: 1408489960 vbv_delay: N/A
      Stream #0:1: Audio: aac, 48000 Hz, stereo, s16, 256 kb/s
          Metadata:
            encoder        : Lavc61.3.100 libfdk_aac
    [h264_qsv @ 0000021025ac29c0] Warning during encoding: incompatible video parameters (5)
    [h264_qsv @ 0000021025ac29c0] Interlaced coding is supported at Main/High Profile Level 2.2-4.0
    frame=  62 fps=0.0 q=26.0 size=N/A time=00:00:00.00 bitrate=N/A speed=  0x
    frame=  96 fps= 96 q=33.0 size=N/A time=00:00:01.01 bitrate=N/A speed=1.02x
    frame=  106 fps= 71 q=26.0 size=N/A time=00:00:01.70 bitrate=N/A speed=1.13x
    frame=  118 fps= 59 q=50.0 size=N/A time=00:00:01.97 bitrate=N/A speed=0.988x
    frame=  130 fps= 52 q=50.0 size=N/A time=00:00:02.46 bitrate=N/A speed=0.987x
    2. ffmpeg creates normal looking segments. But its still not playing. The log looks like this:
    {"Protocol":1,"Id":"3","Path":"http://root:***@10.1.0.7:8001/1:0:1:107:C001:F101:FFFF0000:0:0:0:","EncoderPath":null,"EncoderProtocol":null,"Type":0,"Container":"ts","Size":null,"Name":null,"IsRemote":false,"ETag":null,"RunTimeTicks":null,"ReadAtNativeFramerate":false,"IgnoreDts":false,"IgnoreIndex":false,"GenPtsInput":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":true,"UseMostCompatibleTranscodingProfile":false,"RequiresOpening":false,"OpenToken":null,"RequiresClosing":true,"LiveStreamId":"e2329f4997b378e64ccf8fa396deb76e_45a57807e651402733f095051d6ed6b8_3","BufferMs":null,"RequiresLooping":false,"SupportsProbing":true,"VideoType":null,"IsoType":null,"Video3DFormat":null,"MediaStreams":[{"Codec":"mpeg2video","CodecTag":null,"Language":null,"ColorRange":"tv","ColorSpace":"bt470bg","ColorTransfer":"bt470bg","ColorPrimaries":"bt470bg","DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Rotation":null,"Comment":null,"TimeBase":"1/90000","CodecTimeBase":null,"Title":null,"VideoRange":1,"VideoRangeType":1,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":null,"LocalizedDefault":null,"LocalizedForced":null,"LocalizedExternal":null,"LocalizedHearingImpaired":null,"DisplayTitle":"576i MPEG2VIDEO SDR","NalLengthSize":null,"IsInterlaced":true,"IsAVC":null,"ChannelLayout":null,"BitRate":2000000,"BitDepth":8,"RefFrames":1,"PacketLength":null,"Channels":null,"SampleRate":null,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Height":576,"Width":720,"AverageFrameRate":25,"RealFrameRate":25,"ReferenceFrameRate":25,"Profile":"Main","Type":1,"AspectRatio":"4:3","Index":-1,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Path":null,"PixelFormat":"yuv420p","Level":8,"IsAnamorphic":false},{"Codec":"mp2","CodecTag":null,"Language":null,"ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Rotation":null,"Comment":null,"TimeBase":"1/90000","CodecTimeBase":null,"Title":null,"VideoRange":0,"VideoRangeType":0,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":null,"LocalizedDefault":"Standard","LocalizedForced":null,"LocalizedExternal":"Extern","LocalizedHearingImpaired":null,"DisplayTitle":"MP2 - Stereo","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":"stereo","BitRate":192000,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":2,"SampleRate":48000,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Height":null,"Width":null,"AverageFrameRate":null,"RealFrameRate":null,"ReferenceFrameRate":null,"Profile":null,"Type":0,"AspectRatio":null,"Index":-1,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":null}],"MediaAttachments":[],"Formats":[],"Bitrate":2192000,"FallbackMaxStreamingBitrate":null,"Timestamp":null,"RequiredHttpHeaders":{},"TranscodingUrl":null,"TranscodingSubProtocol":0,"TranscodingContainer":null,"AnalyzeDurationMs":3000,"DefaultAudioStreamIndex":null,"DefaultSubtitleStreamIndex":null,"HasSegments":false}
    ffmpeg -analyzeduration 3000000 -probesize 10000000 -f mpegts -init_hw_device d3d11va=dx11:,vendor=0x8086 -init_hw_device qsv=qs@dx11 -filter_hw_device qs -hwaccel qsv -hwaccel_output_format qsv -noautorotate -c:v mpeg2_qsv -i "http://root:***@10.1.0.7:8001/1:0:1:107:C001:F101:FFFF0000:0:0:0:" -noautoscale -map_metadata -1 -map_chapters -1 -threads 0 -sn -codec:v:0 h264_qsv -preset veryfast -b:v 5000000 -maxrate 5000000 -bufsize 10000000 -profile:v:0 high -level 51 -g:v:0 75 -keyint_min:v:0 75 -vf "setparams=color_primaries=bt709:color_trc=bt709:colorspace=bt709,deinterlace_qsv=mode=2,vpp_qsv=format=nv12" -codec:a:0 libfdk_aac -ac 2 -ab 256000 -copyts -avoid_negative_ts disabled -max_muxing_queue_size 2048 -f hls -max_delay 5000000 -hls_time 3 -hls_segment_type fmp4 -hls_fmp4_init_filename "R:\b3933e4032c1949264e9627254d265c3-1.mp4" -start_number 0 -hls_base_url "hls/b3933e4032c1949264e9627254d265c3/" -hls_segment_filename "R:\b3933e4032c1949264e9627254d265c3%d.mp4" -hls_playlist_type event -hls_list_size 0 -y "R:\b3933e4032c1949264e9627254d265c3.m3u8"
    [AVHWDeviceContext @ 0000028cae52ef00] Using device 8086:1912 (Intel(R) HD Graphics 530).
    [mp3float @ 0000028cb033f280] Header missing
    [mpeg2video @ 0000028cb035c100] Invalid frame dimensions 0x0.
        Last message repeated 9 times
    [mpegts @ 0000028cb031a300] Could not find codec parameters for stream 4 (Unknown: none ([5][0][0][0] / 0x0005)): unknown codec
    [mpegts @ 0000028cb031a300] Could not find codec parameters for stream 5 (Unknown: none ([12][0][0][0] / 0x000C)): unknown codec
    Input #0, mpegts, from 'http://root:***@10.1.0.7:8001/1:0:1:107:C001:F101:FFFF0000:0:0:0:':
      Duration: N/A, start: 7496.217111, bitrate: N/A
      Program 257
      Program 258
      Program 264
      Program 259
      Program 260
      Program 261
      Program 263
      Stream #0:1[0x46](deu): Subtitle: dvb_teletext ([6][0][0][0] / 0x0006)
      Stream #0:2[0x89](deu): Audio: mp2 (mp3float) ([3][0][0][0] / 0x0003), 48000 Hz, stereo, fltp, 192 kb/s
      Stream #0:3[0xa8]: Video: mpeg2video (Main) ([2][0][0][0] / 0x0002), yuv420p(tv, bt470bg, top first), 720x576 [SAR 64:45 DAR 16:9], 25 fps, 25 tbr, 90k tbn
          Side data:
      Stream #0:4[0x122]: Unknown: none ([5][0][0][0] / 0x0005)
      Stream #0:5[0x124]: Unknown: none ([12][0][0][0] / 0x000C)
      Stream #0:6[0x125]: Data: bin_data ([6][0][0][0] / 0x0006)
      Program 262
      Program 266
      Program 269
      No Program
    Stream mapping:
      Stream #0:3 -> #0:0 (mpeg2video (mpeg2_qsv) -> h264 (h264_qsv))
      Stream #0:2 -> #0:1 (mp2 (native) -> aac (libfdk_aac))
    [mp2 @ 0000028cb440cdc0] Header missing
    [aist#0:2/mp2 @ 0000028cb02e6e40] [dec:mp2 @ 0000028cb46d8e40] Error submitting packet to decoder: Invalid data found when processing input
    [hls @ 0000028cb033f280] Opening 'R:\b3933e4032c1949264e9627254d265c3-1.mp4' for writing
    Output #0, hls, to 'R:\b3933e4032c1949264e9627254d265c3.m3u8':
      Metadata:
      Stream #0:0: Video: h264, qsv(tv, bt709, progressive), 720x576 [SAR 64:45 DAR 16:9], q=2-31, 5000 kb/s, 50 fps, 12800 tbn
          Metadata:
          Side data:
            cpb: bitrate max/min/avg: 5000000/0/5000000 buffer size: 10000000 vbv_delay: N/A
          Metadata:
    frame=  146 fps=0.0 q=20.0 size=N/A time=00:00:00.00 bitrate=N/A speed=  0x
    [hls @ 0000028cb033f280] Opening 'R:\b3933e4032c1949264e9627254d265c30.mp4' for writing
    [hls @ 0000028cb033f280] Opening 'R:\b3933e4032c1949264e9627254d265c3.m3u8.tmp' for writing
    frame=  180 fps=180 q=17.0 size=N/A time=00:00:00.68 bitrate=N/A speed=0.678x
    frame=  190 fps=126 q=20.0 size=N/A time=00:00:00.88 bitrate=N/A speed=0.585x
    frame=  218 fps=109 q=24.0 size=N/A time=00:00:01.44 bitrate=N/A speed=0.719x
    frame=  242 fps= 97 q=24.0 size=N/A time=00:00:01.92 bitrate=N/A speed=0.767x
    Disabling hardwane encoding/decoding in any combination didnt help.
    Does anyone has an idea?
