    Jellyfin Forum Support Troubleshooting Networking & Access Remote Control Devices from Jellyfin
    Cannot seem to remote control devices from Jellyfin
    8bitHero
    2025-04-01, 02:10 PM
    I am running Jellyfin server on a Linux server from Docker. I have it set to host networking...
        container_name: jellyfin
        image: jellyfin/jellyfin:latest
        user: "99:100"
          - /mnt/user/appdata/jellyfin:/config
          - /dev/shm:/cache/transcodes
          - /mnt/user/media:/mnt/user/media
        devices:
          - /dev/dri:/dev/dri
        ports:
          - "8096:8096"
        environment:
          - TZ=${TZ}
          - UMASK=${UMASK}
          - JELLYFIN_PublishedServerUrl=${JELLYFIN_PUBLISHED_SERVER_URL}
          - JELLYFIN_FFmpeg__analyzeduration=${JELLYFIN_FFMPEG_ANALYZE_DURATION}
          - JELLYFIN_FFmpeg__probesize=${JELLYFIN_FFMPEG_PROBE_SIZE}
        networks:
          - warpzone
        healthcheck:
          test: ["CMD", "curl", "-f", "http://localhost:8096/"]
          interval: 30s
          timeout: 10s
          retries: 3
          start_period: 40s
        restart: unless-stopped
    The server lists on 192.168.1.2 on my "Trusted" network. I am using Jellyfin on a NVIDIA Shield TV Pro device. It is connected to my "Untrusted/IOT" network at 192.168.3.124
    I have the following firewall rules in place...
    [Image: CVV5QS6YEC#aRvqmKSzEbR9]
    "Allow Return Traffic" is ticked.
    When I play something from my NVIDIA Shield TV Pro (192.168.3.124) to Jellyfin (192.168.1.2) it works great, except in the Dashboard I do not have the option to control the NVIDIA device. Such as stopping/pausing/sending messages. I was wondering what ports I am missing to make that happen.
    Thank you!
    2025-04-01, 04:42 PM
    Web sockets are required for device control to function. I don't think your rule would affect just web sockets.
    However, if you are using a reverse proxy you may need to enable websockets depending on which one you are using.
    8bitHero
    2025-04-01, 04:53 PM
    I am using Caddy but nothing crazy...
    jellyfin.domain.com {
    reverse_proxy localhost:8096
    2025-04-01, 06:00 PM
    Is the Shield connecting through your domain name? And is caddy also a container? Or installed directly on the host?
    AFAIK, Caddy automatically supports web sockets for reverse_proxy configs. And if you can connect at all, web sockets should also be going through. So the answers to my initial questions shouldn't really matter.....
