    Jellyfin Forum Support General Questions Samsumg nu8000 network problem
    Network error messege in Samsumg N8000 TV
    tipitao
    Country:Andorra
    2025-11-16, 03:34 PM
    Hello. I have Jellyfin running OpenMediaVault 7.2 in a Docker Compose on a NAS with the following hardware:
    Intel N100 x64
    16 GB RAM
    1 TB NVMe drive (Dockers)
    16 TB RAID 5 (Multimedia and personal files)
    6 x 2.5 Gb Ethernet cards
    The NAS works fine, and I understand that the Jellyfin Docker container is also working. The NAS normally uses 10% CPU, and when transcoding, less than 35%. It typically uses 25% or less of the RAM. The internal network speed is 1 Gbps. I tried copying a 10 GB file between the NAS (RAID 5 drive) and a PC, and it copied at a constant speed of approximately 115 MB/s, completing successfully. The small problem I'm having is that when playing the same 10GB file I copied (a 1980p movie, 1 hour 45 minutes long) on my Samsung Nu8000 TV with Jellyfin Web, the message "Network cable disconnected" appears twice during playback. If I click OK, it connects instantly and playback continues smoothly. I know it's not the cable or the TV's network connection (100 Mbps) because my wife watches Netflix in 1080p and never gets the message on her TV. This has me a bit puzzled. Any suggestions?
    Regards
