    Jellyfin Forum Support Troubleshooting SOLVED: Audio Transcode Failing
    Pages (3): « Previous 1 2 3
    [q] command received. Exiting.
    roughnecknine0
    2025-03-25, 04:11 PM (This post was last modified: 2025-03-25, 04:12 PM by roughnecknine0. Edited 1 time in total.)
    journalctl -u jellyfin.service -xe
    ░░ Defined-By: systemd
    ░░ Support: http://www.ubuntu.com/support
    ░░ A stop job for unit jellyfin.service has begun execution.
    ░░ The job identifier is 431.
    Mar 24 23:08:46 Jellyfinx13x8096 systemd[1]: jellyfin.service: Deactivated successfully.
    ░░ Subject: Unit succeeded
    ░░ The unit jellyfin.service has successfully entered the 'dead' state.
    Mar 24 23:08:46 Jellyfinx13x8096 systemd[1]: Stopped Jellyfin Media Server.
    ░░ Subject: A stop job for unit jellyfin.service has finished
    ░░ A stop job for unit jellyfin.service has finished.
    ░░ The job identifier is 431 and the job result is done.
    Mar 24 23:08:46 Jellyfinx13x8096 systemd[1]: jellyfin.service: Consumed 24min 31.384s CPU time.
    ░░ Subject: Resources consumed by unit runtime
    ░░ The unit jellyfin.service completed and consumed the indicated resources.
    -- Boot 08fff356a6ab449e9ecc2170cf12141d --
    Mar 24 23:10:09 Jellyfinx13x8096 systemd[1]: Started Jellyfin Media Server.
    ░░ Subject: A start job for unit jellyfin.service has finished successfully
    ░░ A start job for unit jellyfin.service has finished successfully.
    ░░ The job identifier is 104.
    Mar 24 23:10:12 Jellyfinx13x8096 jellyfin[103]: [23:10:12] [WRN] The WebRootPath was not found: /var/lib/jellyfin/wwwroot. Static files may be unavailable.
    or via privatebin
    2025-03-25, 04:57 PM
    I have no idea what is going on. Something is fundamentally broken. And I'm leaning towards something with the OS.
    roughnecknine0
    2025-03-25, 05:03 PM (This post was last modified: 2025-03-25, 05:46 PM by roughnecknine0. Edited 1 time in total.)
    Well thanks for looking, I do appreciate it.
    My thought at this point is to delete the container and rebuild. I originally used a VE Helper script to install but maybe this time I try it manually.
    ETA: Spun up a new container & install, logs seem to be functioning normally. I'm going to file this as complete and create a new thread if I see the original issue again.
