    Jellyfin Forum Support Troubleshooting SOLVED: Codec issues on Sony Bravia using hardware acceleration
    can't read V_MPEG4/ISO/AVC
    Mehdi_FR
    Country:Singapore
    2024-07-05, 05:08 PM
    Here are my specs:
    Jellyfin version : 10.9.7
    Docker on sinology NAS DS423+ with DSM 7.2.1 (Docker compose) using Intel Celeron J4125
    Hardware acceleration is activated with options specified in the attached PNG files.
    My findings:
    - I have 2 videos : one with codec V_MPEGH/ISO/HEVC and one with V_MPEG4/ISO/AVC
    - on my laptop and on my iPhone, I can watch both files with Jellyfin application
    - on my Sony Bravia x90L, files with codec V_MPEG4/ISO/AVC cannot be read neither .mp4 files.
    I have also attached 3 logs : Log1 is Okay; Logs 2 and 3 are not Okay.
    and here is my docker compose file
    version: '3.5'
        image: jellyfin/jellyfin
        container_name: jellyfin
        network_mode: 'host'
          - /volume1/docker/jellyfin/configConfused-faceconfig
          - /volume1/docker/jellyfin/cacheConfused-facecache
          - /volume1/Archive/Video/movies
          - /volume1/Archive/Video/tv-series
          - /volume1/Archive/Video/tv-shows
          - /volume1/Archive/Video/vhs
        restart: 'unless-stopped'
        environment:
          - TZ='Asia/Singapore'
        devices:
          - /dev/dri/renderD128Confused-facedev/dri/renderD128
          - /dev/dri/card0Confused-facedev/dri/card0
    Thank you in advance for your help.
    BR
    .pdf   Log3.pdf (Size: 33.02 KB / Downloads: 148)
    .pdf   Log1.pdf (Size: 32.5 KB / Downloads: 162)
    .pdf   Log2.pdf (Size: 31.54 KB / Downloads: 163)
    2024-07-05, 05:25 PM (This post was last modified: 2024-07-05, 05:25 PM by TheDreadPirate.)
    Try unchecking low power encoding. That feature requires additional configuration in the OS that I'm pretty sure Synology makes difficult or impossible to perform. And it isn't required for your iGPU.
    Also try passing in /dev/dri in its entirety instead of the specific renderD128 device or card0. The Intel driver will automatically select the first available Intel device in that path.
    Mehdi_FR
    Country:Singapore
    2024-07-05, 05:40 PM
    I've applied the recommended changes and restarted the Jellyfin server but the issue remains the same.
    Here is the last log :
    {"Protocol":0,"Id":"946f6bd6789409d32778eee06876596e","Path":"/movies/Terreur sur le Britannic/Terreur sur le Britannic.avi","EncoderPath":null,"EncoderProtocol":null,"Type":0,"Container":"avi","Size":2095824896,"Name":"Terreur sur le Britannic","IsRemote":false,"ETag":"ea38ea11d7aaa469bd8116417dc6f951","RunTimeTicks":63545600000,"ReadAtNativeFramerate":false,"IgnoreDts":false,"IgnoreIndex":false,"GenPtsInput":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"OpenToken":null,"RequiresClosing":false,"LiveStreamId":null,"BufferMs":null,"RequiresLooping":false,"SupportsProbing":true,"VideoType":0,"IsoType":null,"Video3DFormat":null,"MediaStreams":[{"Codec":"subrip","CodecTag":null,"Language":null,"ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Comment":null,"TimeBase":"1/1000","CodecTimeBase":null,"Title":null,"VideoRange":0,"VideoRangeType":0,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":"Undefined","LocalizedDefault":"Default","LocalizedForced":"Forced","LocalizedExternal":"External","LocalizedHearingImpaired":"Hearing Impaired","DisplayTitle":"Undefined - SUBRIP - External","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":null,"BitRate":null,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":null,"SampleRate":null,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Height":0,"Width":0,"AverageFrameRate":null,"RealFrameRate":null,"Profile":null,"Type":2,"AspectRatio":null,"Index":0,"Score":null,"IsExternal":true,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Path":"/movies/Terreur sur le Britannic/Terreur sur le Britannic.srt","PixelFormat":null,"Level":0,"IsAnamorphic":null},{"Codec":"ass","CodecTag":null,"Language":null,"ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Comment":null,"TimeBase":"1/100","CodecTimeBase":null,"Title":null,"VideoRange":0,"VideoRangeType":0,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":"Undefined","LocalizedDefault":"Default","LocalizedForced":"Forced","LocalizedExternal":"External","LocalizedHearingImpaired":"Hearing Impaired","DisplayTitle":"Undefined - ASS - External","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":null,"BitRate":null,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":null,"SampleRate":null,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Height":0,"Width":0,"AverageFrameRate":null,"RealFrameRate":null,"Profile":null,"Type":2,"AspectRatio":null,"Index":1,"Score":null,"IsExternal":true,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Path":"/movies/Terreur sur le Britannic/Terreur sur le Britannic.ssa","PixelFormat":null,"Level":0,"IsAnamorphic":null},{"Codec":"mpeg4","CodecTag":"XVID","Language":null,"ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Comment":null,"TimeBase":"1/25","CodecTimeBase":null,"Title":null,"VideoRange":1,"VideoRangeType":1,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":null,"LocalizedDefault":null,"LocalizedForced":null,"LocalizedExternal":null,"LocalizedHearingImpaired":null,"DisplayTitle":"480p MPEG4 SDR","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":null,"BitRate":2240011,"BitDepth":8,"RefFrames":1,"PacketLength":null,"Channels":null,"SampleRate":null,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Height":426,"Width":720,"AverageFrameRate":25,"RealFrameRate":25,"Profile":"Advanced Simple Profile","Type":1,"AspectRatio":"120:71","Index":2,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Path":null,"PixelFormat":"yuv420p","Level":5,"IsAnamorphic":false},{"Codec":"ac3","CodecTag":null,"Language":null,"ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Comment":null,"TimeBase":"1/24000","CodecTimeBase":null,"Title":null,"VideoRange":0,"VideoRangeType":0,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":null,"LocalizedDefault":null,"LocalizedForced":null,"LocalizedExternal":null,"LocalizedHearingImpaired":null,"DisplayTitle":"Dolby Digital - Stereo","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":"stereo","BitRate":192000,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":2,"SampleRate":48000,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Height":null,"Width":null,"AverageFrameRate":null,"RealFrameRate":null,"Profile":null,"Type":0,"AspectRatio":null,"Index":3,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":null},{"Codec":"ac3","CodecTag":null,"Language":null,"ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Comment":null,"TimeBase":"1/24000","CodecTimeBase":null,"Title":null,"VideoRange":0,"VideoRangeType":0,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":null,"LocalizedDefault":null,"LocalizedForced":null,"LocalizedExternal":null,"LocalizedHearingImpaired":null,"DisplayTitle":"Dolby Digital - Stereo","NalLengthSize":null,"IsInterlaced":false,"IsAVC":false,"ChannelLayout":"stereo","BitRate":192000,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":2,"SampleRate":48000,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Height":null,"Width":null,"AverageFrameRate":null,"RealFrameRate":null,"Profile":null,"Type":0,"AspectRatio":null,"Index":4,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":null}],"MediaAttachments":[],"Formats":[],"Bitrate":2638514,"Timestamp":null,"RequiredHttpHeaders":{},"TranscodingUrl":null,"TranscodingSubProtocol":0,"TranscodingContainer":null,"AnalyzeDurationMs":null,"DefaultAudioStreamIndex":null,"DefaultSubtitleStreamIndex":null}
    /usr/lib/jellyfin-ffmpeg/ffmpeg -analyzeduration 200M -probesize 1G -init_hw_device vaapi=va:,kernel_driver=i915,driver=iHD -init_hw_device qsv=qs@va -filter_hw_device qs -noautorotate -i file:"/movies/Terreur sur le Britannic/Terreur sur le Britannic.avi" -map_metadata -1 -map_chapters -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 hevc_qsv -tag:v:0 hvc1 -preset veryfast -b:v 4480022 -maxrate 4480022 -bufsize 8960044 -g:v:0 75 -keyint_min:v:0 75 -vf "setparams=color_primaries=bt709:color_trc=bt709:colorspace=bt709,scale=trunc(min(max(iw\,ih*a)\,min(720\,426*a))/2)*2:trunc(min(max(iw/a\,ih)\,min(720/a\,426))/2)*2,format=yuv420p" -codec:a:0 copy -copyts -avoid_negative_ts disabled -max_muxing_queue_size 2048 -f hls -max_delay 5000000 -hls_time 3 -hls_segment_type mpegts -start_number 0 -hls_segment_filename "/cache/transcodes/dc957ae7ba6f9930cdecd83246cb3397%d.ts" -hls_playlist_type vod -hls_list_size 0 -y "/cache/transcodes/dc957ae7ba6f9930cdecd83246cb3397.m3u8"
    ffmpeg version 6.0.1-Jellyfin Copyright © 2000-2023 the FFmpeg developers
    libavutil 58. 2.100 / 58. 2.100
    libavcodec 60. 3.100 / 60. 3.100
    libavformat 60. 3.100 / 60. 3.100
    libavdevice 60. 1.100 / 60. 1.100
    libavfilter 9. 3.100 / 9. 3.100
    libswscale 7. 1.100 / 7. 1.100
    libswresample 4. 10.100 / 4. 10.100
    libpostproc 57. 1.100 / 57. 1.100
    [AVHWDeviceContext @ 0x555c85575a00] No VA display found for any default device.
    Device creation failed: -22.
    Failed to set value 'vaapi=va:,kernel_driver=i915,driver=iHD' for option 'init_hw_device': Invalid argument
    Error parsing global options: Invalid argument
    2024-07-05, 05:45 PM (This post was last modified: 2024-07-05, 05:46 PM by TheDreadPirate. Edited 1 time in total.)
    I forgot to mention this in my first reply. You also need to pass in the render group into the container.
    https://jellyfin.org/docs/general/admini...ial-docker
    group_add:
          - "122" # Change this to match your "render" host group id and remove this comment
    Mehdi_FR
    Country:Singapore
    2024-07-05, 06:25 PM
    Same issue remains
    I've opened ssh in DSM and used Terminal on my MacOS to find the render group.
    It was not existing.
    I've created with command sudo synogroup --add render
    And then I got
    Group Name: [render]
    Group Type: [AUTH_LOCAL]
    Group ID: [65538]
    I've update the docker compose file as followed
    version: '3.5'
    environment:
    devices:
    - /dev/driConfused-facedev/dri
    group_add:
    - "65538"
    Then I restarted Jellyfin on DSM and tried to read the fMPEG4 file again.
    it is not working on any device : Sony Bravia, Mac and iPhone.
    2024-07-05, 08:38 PM
    You shouldn't be creating a group. The render group should already exist and the GPU should already be a member of it.
    chris@rat-trap:~$ getent group render | cut -d: -f3
    993
    chris@rat-trap:~$ ll /dev/dri
    total 0
    drwxr-xr-x  3 root root        100 Jun 26 12:51 ./
    drwxr-xr-x 22 root root       4920 Jun 26 12:51 ../
    drwxr-xr-x  2 root root         80 Jun 26 12:51 by-path/
    crw-rw----  1 root video  226,   1 Jun 26 12:51 card1
    crw-rw----  1 root render 226, 128 Jun 26 12:51 renderD128
    The relevant part of my docker compose for reference.
      jellyfin-testing:
        image: jellyfin/jellyfin:10.9.7
        container_name: jellyfin-stable-testing
        user: 105:104
        group_add:
          - "993" # Intel render group
        networks:
          blackmoon:
            ipv4_address: 172.16.100.2
        expose:
          - 8096
          - ./jellyfin-stable-data/config:/config
          - ./jellyfin-stable-data/cache:/cache
          - /media/library:/media/library:ro
          - /media/storage2:/media/storage2:ro
        devices:
    Mehdi_FR
    Country:Singapore
    2024-07-06, 02:37 AM
    I see. But, the getent command does not work on my terminal (I use MacOS Terminal).
    So I asked ChatGPT for an alternative.
    Please see the history of commands :
    XXXXX@Serveur_MehdiConfused-face$ getent group render
    -sh: getent: command not found
    XXXXX@Serveur_MehdiConfused-face$ cat /etc/group | grep render
    Python2:x:236506:
    QuickConnect:x:177017:
    root:x:0:root
    rpc:x:32:
    StorageManager:x:112790:
    SynoFinder:x:195341:
    SynologyApplicationService:x:130369:
    SynologyDrive:x:153742:
    SynoOnlinePack_v2:x:225936:
    synopkgs:x:999Woozy-facetorageManager,Python2,QuickConnect,FileStation,SynoOnlinePack_v2,OAuthService,SynoFinder,SecureSignIn,PlexMediaServer,SynologyApplicationService,SynologyDrive,USBCopy
    synoplugind:x:941:
    SynoRsyncd:x:873:
    synotss:x:942:
    system:x:1:system
    taskmgr:x:939:
    tokenmgr:x:938:
    USBCopy:x:123545:
    users:xHundred-points
    videodriver:x:937:PlexMediaServer
    vmcomm:x:936:
    wheel:x:10:
    XXXXX@Serveur_MehdiConfused-face$ sudo synogroup --add render
    We trust you have received the usual lecture from the local System
    Administrator. It usually boils down to these three things:
    #1) Respect the privacy of others.
    #2) Think before you type.
    #3) With great power comes great responsibility.
    Group ID: [65538]
    Group Members:
    render:x:65538:
    you can see there was no render group initially before I create one.
    Why do you recommend ?
    thank you for your time and reactivity. I really appreciate
    2024-07-06, 02:56 AM
    Unfortunately, I'm at my limit of knowledge regarding Synology (I don't have any of their NASes).
    I found this reddit post that looks like what we need.
    https://www.reddit.com/r/jellyfin/commen..._hardware/
    Mehdi_FR
    Country:Singapore
    2024-07-06, 05:13 AM
    It works !
    Thank you very much.
    as a summary in Synology NAS, DSM 7.2.1
    1) stopped my jellyfish container in Docker
    2) allowed container execution with high privileges
    3) added environment variable 'DEVICES' with value '/dev/dri/renderD128'
    4) restarted the container
    Now all MPEG4 codecs can be read from my Google TV on Sony Bravia
