    Jellyfin Forum Support Troubleshooting Networking & Access SOLVED: Connection issues from other local machines
    93trawl_file
    2024-12-31, 06:53 AM
    I can't access my Jellyfin server from any other machine on my home network. It is only accessible via http://localhost:8096
    Server is installed on a Windows 10 desktop. I'm trying to access it from a Windows 11 laptop. I can RDP to the desktop from my laptop. Both machines are on the same wi-fi AP.
    I've also tried to access the server from an Android TV.
    Server version = 10.10.3
    Server IP = 192.168.50.245
    Client IP = 192.168.50.252
    I see no errors in the log
    Attaching 2 screenshots:
    - Jellyfin windows firewall rules -> TCP/UDP private rule is enabled
    - Jellyfin from Networking tab of Resource monitor -> "not allowed/not restricted"
    At this point I'm thinking that this is probably a firewall issue. However, not sure why Resource monitor lists "not allowed" even when firewall rules are correct.
    Two other items to note:
    1. When I uninstalled, C:\Program Files\Jellyfin\Server was not removed.
    2. On a fresh install, the setup wizard does not ask me what I want to call the Jellyfin server anymore. It auto-sets it to my Device name.
    2024-12-31, 06:12 PM
    Is the network set to private or public?
    https://support.microsoft.com/en-us/wind...0da607448d
    93trawl_file
    2024-12-31, 10:19 PM
    Well, that did it. Thanks! I don't remember changing that in the past, when things were working fine.
    2024-12-31, 10:54 PM
    I've seen Windows updates reset the NIC to public.
