    Jellyfin Forum Support Troubleshooting SOLVED: direct play problem with mp4 and certain codecs on android native player
    David Müller
    2024-08-10, 10:06 PM (This post was last modified: 2024-08-11, 09:49 PM by David Müller. Edited 2 times in total.)
    Hi,
    I have strange problem with mp4 files on android (native player):
    If I have AV1 and Opus as codecs, then it transcodes both audio and video.
    If I have a file with h264 and Opus, then it transcodes only the audio.
    It says as reason that the audio codec is not supported in both cases.
    But it plays audio opus files with directly.
    It's also direct playing just fine if I use MKV or WebM.
    Also no problems when using Web Player, Firefox for Android or Findroid.
    Edit: Also no problem with mp4 files with AV1 and AAC.
    2024-08-11, 12:32 AM
    What version of Jellyfin are you running?
    David Müller
    2024-08-11, 09:43 AM
    10.9.9 for server.
    2.6.2 for android client.
    2024-08-11, 07:27 PM
    Can you share your full jellyfin and ffmpeg logs via pastebin?
    David Müller
    2024-08-11, 08:32 PM
    Jellyfin: https://pastebin.com/0ZX1QU1G
    FFMPEG: https://pastebin.com/9EuJFY5S
    2024-08-11, 08:45 PM (This post was last modified: 2024-08-11, 08:47 PM by TheDreadPirate. Edited 1 time in total.)
    This might be an issue with the device profile the jellyfin app produces. I confirmed that OPUS direct plays in webm and MKV, but transcodes when the same audio is in MP4.
    2024-08-11, 08:55 PM
    Yes. The profile builder is not including opus as a direct play codec.
    https://github.com/jellyfin/jellyfin-and...er.kt#L251
    2024-08-11, 09:46 PM (This post was last modified: 2024-08-11, 10:07 PM by TheDreadPirate. Edited 1 time in total.)
    I submitted this PR to add OPUS to the Android apps direct play profile.
    https://github.com/jellyfin/jellyfin-android/pull/1463
    David Müller
    Thanks!
    For now I made a custom build and it works just fine (both with AV1 and H264).
    I just wonder why it direct streamed the video with h264 but fully transcoded with AV1.
