    Jellyfin Forum Support Troubleshooting Media Scanning & Identification SOLVED: Help with Looney Tunes Blu Ray
    I need to know the prefix for naming the files.
    slimetabnet
    2025-11-03, 07:09 PM
    Hi everyone,
    I have a Blu Ray titled "Looney Tunes Collector's Choice: Volume 1" (2023) and I'm not sure how to name the files. It's not listed on IMDB, and TMDB has it listed as a "movie".
    https://www.themoviedb.org/movie/1397316...e-volume-1
    What prefix should I name each of the individual episodes?
    Thanks in advance!
    Ted Hinklater
    Threads: 8
    2025-11-03, 07:39 PM (This post was last modified: 2025-11-03, 08:04 PM by Ted Hinklater. Edited 1 time in total.)
    If it's like Tom & Jerry was for me, you would name the folder "Looney Tunes [tvdbid-72514]"
    Then for each year (season) you make a folder
    Beanstalk Bunny goes in "S1955" and the file name is S1955E04.mkv for example
    You can find all the episodes here, when you're done naming them & putting them in folders, it should identify as Looney Tunes
    slimetabnet
    2025-11-07, 10:57 AM
    (2025-11-03, 07:09 PM)slimetabnet Wrote: Hi everyone,
    Thanks in advance!
    (2025-11-03, 07:39 PM)Ted Hinklater Wrote: If it's like Tom & Jerry was for me, you would name the folder "Looney Tunes [tvdbid-72514]"
    This worked for getting Jellyfin to recognize the seasons/episodes from TVDB.
    For some reason the metadata is not populating. My guess is that it's the age of the episodes. But it's a great start.
    Thanks for your help!
