    Jellyfin Forum Support Troubleshooting SOLVED: Help with Tone Mapping
    I have QSV hardware transcoding working properly, but tonemapping causes fatal error.
    shotblocker
    2025-01-25, 03:09 AM (This post was last modified: 2025-01-25, 04:25 AM by shotblocker. Edited 5 times in total.)
    Please let me know what information I need to get this troubleshoot started. I am a bit of a noob in this aspect.
    Here is my latest transcode log for example.
    https://pastebin.com/83J4g3CB
    I enabled VPP tone mapping and left values at default. I also tried normal tone mapping and got the same issue. Disabling tone mapping allows me to transcode as normal.
    Using iGPU for transcoding, CPU is Intel Celeron N3450.
    docker exec -it jellyfin /usr/lib/jellyfin-ffmpeg/vainfo
    Trying display: drm
    vainfo: VA-API version: 1.22 (libva 2.22.0)
    vainfo: Driver version: Intel iHD driver for Intel(R) Gen Graphics - 25.1.0 (aa5ca48)
          VAProfileH264Main              : VAEntrypointFEI
          VAProfileH264High              : VAEntrypointFEI
          VAProfileH264ConstrainedBaseline: VAEntrypointFEI
          VAProfileVP8Version0_3          : VAEntrypointVLD
          VAProfileVP8Version0_3          : VAEntrypointEncSlice
          VAProfileHEVCMain              : VAEntrypointEncSlice
          VAProfileHEVCMain              : VAEntrypointFEI
    docker exec -it jellyfin /usr/lib/jellyfin-ffmpeg/ffmpeg -v verbose -init_hw_device vaapi=va -init_hw_device opencl@va
      built with gcc 13 (Ubuntu 13.3.0-6ubuntu2~24.04)
    [AVHWDeviceContext @ 0x65018793b480] Trying to use DRM render node for device 0.
    [AVHWDeviceContext @ 0x65018793b480] libva: VA-API version 1.22.0
    [AVHWDeviceContext @ 0x65018793b480] libva: Trying to open /usr/lib/jellyfin-ffmpeg/lib/dri/iHD_drv_video.so
    [AVHWDeviceContext @ 0x65018793b480] libva: Found init function __vaDriverInit_1_22
    [AVHWDeviceContext @ 0x65018793b480] libva: va_openDriver() returns 0
    [AVHWDeviceContext @ 0x65018793b480] Initialised VAAPI connection: version 1.22
    [AVHWDeviceContext @ 0x65018793b480] VAAPI driver: Intel iHD driver for Intel(R) Gen Graphics - 25.1.0 (aa5ca48).
    [AVHWDeviceContext @ 0x65018793b480] Driver not found in known nonstandard list, using standard behaviour.
    [AVHWDeviceContext @ 0x650187971400] Failed to get number of OpenCL platforms: -1001.
    Device creation failed: -19.
    Failed to set value 'opencl@va' for option 'init_hw_device': No such device
    Error parsing global options: No such device
    Jellyfin is running in docker, within a Proxmox LXC container (call that weird but its my setup).
    2025-01-26, 04:55 PM
    Did you install the openCL mod in your docker compose?
    shotblocker
    2025-01-28, 12:30 AM
    Sorry for the late reply, I thought I had email notifications on. I do not have openCL in my compose.
    version: "3.8"
        container_name: jellyfin
        group_add:
          - "106"
        devices:
          - /dev/dri:/dev/dri
        ports:
          - 8096:8096
        environment:
          - TZ=Etc/UTC
          - PUID=1000
          - PGID=1000
          - /appdata/jellyfin:/config
          - /mnt/media/data/media:/data/media
          - /mnt/media/data/media/tv:/data/media/tv
          - /mnt/media/data/media/movies:/data/media/movies
        restart: unless-stopped
    Would you be able to assist me in what I need to add?
    2025-01-28, 02:20 PM
    Add this to the environment section.
    - DOCKER_MODS=linuxserver/mods:jellyfin-opencl-intel
    shotblocker
    2025-01-29, 01:56 AM
    Installed opencl, yet all of my transcodes are logging conversion failed. I don't know a lot about codecs but all the 4k, UltraHD media I have is either H265, HEVC, or x265. Guessing the description of: "Tone-mapping can transform the dynamic range of a video from HDR to SDR while maintaining image details and colors, which are very important information for representing the original scene. Currently works only with 10bit HDR10, HLG and DoVi videos. This requires the corresponding GPGPU runtime," is relevant there.
    So for example if I'm watching a 4k movie that needs to transcode, the picture is washed-out (versus directly playing on i.e. Jellyfin Media Player). If all my media is in a non-supported codec, does that mean I just can't enable tone-mapping and have to just live with the washed-out colors? Or am I missing something.
    Stream mapping:
      Stream #0:0 (hevc) -> setparams:default
      Stream #0:15 (pgssub) -> scale:default
      overlay_qsv:default -> Stream #0:0 (h264_qsv)
      Stream #0:2 -> #0:1 (copy)
    [Parsed_tonemap_vaapi_6 @ 0x7030bc021540] VAAPI driver doesn't support HDR
    [Parsed_tonemap_vaapi_6 @ 0x7030bc021540] Failed to configure output pad on Parsed_tonemap_vaapi_6
    [fc#0 @ 0x588f45b52c00] Error reinitializing filters!
    [fc#0 @ 0x588f45b52c00] Task finished with error code: -22 (Invalid argument)
    [fc#0 @ 0x588f45b52c00] Terminating thread with return code -22 (Invalid argument)
    [vost#0:0/h264_qsv @ 0x588f478c0d80] Could not open encoder before EOF
    [vost#0:0/h264_qsv @ 0x588f478c0d80] Task finished with error code: -22 (Invalid argument)
    [vost#0:0/h264_qsv @ 0x588f478c0d80] Terminating thread with return code -22 (Invalid argument)
    [out#0/hls @ 0x588f477b6e80] Nothing was written into output file, because at least one of its streams received no packets.
    frame=    0 fps=0.0 q=0.0 Lsize=      0KiB time=N/A bitrate=N/A speed=N/A
    Conversion failed!
    2025-01-29, 03:55 PM
    If I'm reading Intel's docs correctly, ApolloLake CPUs do not support HEVC 10-bit.  Which is needed for tone mapping.
    I thought ApolloLake had Gen 9.5 graphics, which does support HEVC 10-bit, but it appears it has Gen 9 graphics.
    Check if you have intel-gpu-tools installed.  If you do run intel_gpu_top and tell me what generation it reports.
    sudo apt list --installed | grep intel-gpu-tools
    sudo apt install intel-gpu-tools  #If it isn't already installed
    sudo intel_gpu_top
    If it does report "Gen9" instead of "Gen9.5" you are out of luck for HDR tone mapping.
    shotblocker
    2025-01-29, 04:04 PM
    I do I have intel-gpu-tools installed, and yes, sadly it reports Gen9. Looks like I'll eventually find a new host for my media server. For the time being I'll just have to deal with washed-out 4k videos on transcoding clients.
    von Monster
    2025-12-16, 11:37 PM
    I found this thread helpful and I just wanted to add some additional information as I have an older NAS with an Apollo Lake CPU (J3455) - if you're running the Linuxserver docker with the Intel OpenCL mod while the 'Enable VPP Tone mapping' won't work the regular 'Enable Tone mapping' will via OpenCL.
    Obviously not as great as the built in VPP tone mapping but it's workable - last transcode I tried at 4k DoVI -> SD SDR ran at around 1.6x from the FFmpeg logs FWIW.
