2025-09-29, 07:53 PM
(This post was last modified: 2025-09-29, 09:28 PM by TheChow. Edited 1 time in total.)
Edit: I forgot to mention I had Docker Desktop installed, and after some searching various places I found someone who had similar issues to mine and a reply saying they thought Docker Desktop may be an issue as they were unsure if it passes through devices. So I stripped Docker Desktop from my system and it works fine even without "privileged:true", but I need the user mapping.
I'm running KDE Neon 6.4.5 (Ubuntu 24.04LTS) on a AMD Ryzen 9 7940HS (Radeon 780M graphics) laptop. The system is up to date from apt-get and Discover.
I'm running into issues mapping /dev/dri to the Jellyfin container and have hit a wall in troubleshooting. I'm using the LinuxServer.io latest Jellyfin image.
Here's a trimmed version of my Docker compose.yaml
If I don't have "privledge: true" I get an error "Error response from daemon: error gathering device information while adding custom device "/dev/dri": no such file or directory"
With privledge it launches with "docker compose up", but if I open a shell on the container I don't see /dev/dri; and attempting to use VAAPI HW transcoding fails. I've tried with and without my ID specified, both result in missing /dev/dri inside the container.
If I run "sudo docker compose up", and in the container I can see /dev/dri, and using the same settings in Jellyfin transcoding is successful.
privileged: true
container_name: jellyfin
group_add:
- video
- 992 # group id for render
environment:
- PUID=1000 # my uid and gid
- PGID=1000
- TZ=America/New_York
- JELLYFIN_PublishedServerUrl=http://192.168.50.9 #optional
devices:
- /dev/dri:/dev/dri
- /home/myusername/docker/jellyfin/config:/config
- /home/myusername/docker/jellyfin/cache:/cache
- /media/Movies:/data/Movies # several more mappings
ports:
- 8096:8096
- 8920:8920 #optional
- 7359:7359/udp #optional
- 1900:1900/udp #optional
restart: unless-stoppedIf I don't have "privledge: true" I get an error "Error response from daemon: error gathering device information while adding custom device "/dev/dri": no such file or directory"
