    Jellyfin Forum Support Troubleshooting SOLVED: Jellyfin doesn't work
    Pages (3): 1 2 3 Next »
    supertanno
    2023-07-20, 09:06 PM (This post was last modified: 2023-07-20, 09:14 PM by supertanno. Edited 1 time in total.)
    I've been trying to get Jellyfin to work on Ubuntu 22.04 LTS. Initially, it worked fine, but after installing nginx it seems to have stopped working properly. While it does start up, the website refuses to load, with the connection getting timed out. Turning off Nginx doesn't fix the issue, so I'm not sure if it's actually related.
    The logs are as follows:
    [20:56:17] [INF] [1] Main: Jellyfin version: 10.8.10
    [20:56:17] [INF] [1] Main: Environment Variables: ["[JELLYFIN_LOG_DIR, /home/supertanno/jellyfin/log]"]
    [20:56:17] [INF] [1] Main: Arguments: ["/usr/lib/jellyfin/bin/jellyfin.dll", "restart"]
    [20:56:17] [INF] [1] Main: Operating system: Linux
    [20:56:17] [INF] [1] Main: Architecture: X64
    [20:56:17] [INF] [1] Main: 64-Bit Process: True
    [20:56:17] [INF] [1] Main: User Interactive: True
    [20:56:17] [INF] [1] Main: Processor count: 4
    [20:56:17] [INF] [1] Main: Program data path: /home/supertanno/jellyfin
    [20:56:17] [INF] [1] Main: Web resources path: /usr/lib/jellyfin/bin/jellyfin-web
    [20:56:17] [INF] [1] Main: Application directory: /usr/lib/jellyfin/bin/
    [20:56:17] [INF] [1] Emby.Server.Implementations.AppBase.BaseConfigurationManager: Setting cache path: /home/supertanno/.cache/jellyfin
    [20:56:17] [INF] [1] Emby.Server.Implementations.ApplicationHost: Loading assemblies
    [20:56:17] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Defined LAN addresses : [10.0.0.0/8,172.16.0.0/12,192.168.0.0/16]
    [20:56:17] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Defined LAN exclusions : []
    [20:56:17] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Using LAN addresses: [10.0.0.0/8,172.16.0.0/12,192.168.0.0/16]
    [20:56:17] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Using bind addresses: []
    [20:56:17] [INF] [1] Jellyfin.Networking.Manager.NetworkManager: Using bind exclusions: []
    [20:56:20] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: TMDb 10.8.10.0
    [20:56:20] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: Studio Images 10.8.10.0
    [20:56:20] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: OMDb 10.8.10.0
    [20:56:20] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: MusicBrainz 10.8.10.0
    [20:56:20] [INF] [1] Emby.Server.Implementations.Plugins.PluginManager: Loaded plugin: AudioDB 10.8.10.0
    [20:56:20] [INF] [1] Main: Kestrel listening on Any IP4 Address
    [20:56:20] [INF] [1] Emby.Server.Implementations.ApplicationHost: Running startup tasks
    [20:56:20] [INF] [1] Emby.Server.Implementations.ScheduledTasks.TaskManager: Daily trigger for Extract Chapter Images set to fire at 2023-07-21 02:00:00.000 +00:00, which is 05:03:39.0016938 from now.
    [20:56:21] [ERR] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: Error validating encoder
    System.ComponentModel.Win32Exception (2): An error occurred trying to start process 'ffmpeg' with working directory '/home/supertanno'. No such file or directory
      at System.Diagnostics.Process.ForkAndExecProcess(ProcessStartInfo startInfo, String resolvedFilename, String[] argv, String[] envp, String cwd, Boolean setCredentials, UInt32 userId, UInt32 groupId, UInt32[] groups, Int32& stdinFd, Int32& stdoutFd, Int32& stderrFd, Boolean usesTerminal, Boolean throwOnNoExec)
      at System.Diagnostics.Process.StartCore(ProcessStartInfo startInfo)
      at System.Diagnostics.Process.Start()
      at MediaBrowser.MediaEncoding.Encoder.EncoderValidator.GetProcessOutput(String path, String arguments, Boolean readStdErr, String testKey)
      at MediaBrowser.MediaEncoding.Encoder.EncoderValidator.ValidateVersion()
    [20:56:21] [WRN] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: FFmpeg: Failed version check: ffmpeg
    [20:56:21] [INF] [1] MediaBrowser.MediaEncoding.Encoder.MediaEncoder: FFmpeg:
    [20:56:21] [INF] [1] Emby.Server.Implementations.ApplicationHost: ServerId: 7924572d27044f44a1cad2af34dc57d3
    [20:56:21] [INF] [1] Emby.Server.Implementations.ApplicationHost: Executed all pre-startup entry points in 0:00:00.1301507
    [20:56:21] [INF] [1] Emby.Server.Implementations.ApplicationHost: Core startup complete
    [20:56:21] [INF] [1] Emby.Server.Implementations.ApplicationHost: Executed all post-startup entry points in 0:00:00.173094
    [20:56:21] [INF] [1] Main: Startup complete 0:00:04.2414129
    [20:56:24] [INF] [11] Emby.Server.Implementations.ScheduledTasks.TaskManager: StartupTrigger fired for task: Update Plugins
    [20:56:24] [INF] [11] Emby.Server.Implementations.ScheduledTasks.TaskManager: Queuing task PluginUpdateTask
    [20:56:24] [INF] [13] Emby.Server.Implementations.ScheduledTasks.TaskManager: Executing Update Plugins
    [20:56:25] [INF] [13] Emby.Server.Implementations.ScheduledTasks.TaskManager: Update Plugins Completed after 0 minute(s) and 1 seconds
    [20:56:25] [INF] [13] Emby.Server.Implementations.ScheduledTasks.TaskManager: ExecuteQueuedTasks
    It stays stuck on the final thing. The ports seem to be fine, according to NetStat:
    Active Internet connections (only servers)
    Proto Recv-Q Send-Q Local Address          Foreign Address        State      PID/Program name
    tcp        0      0 127.0.0.53:53          0.0.0.0:*              LISTEN      722/systemd-resolve
    tcp        0      0 0.0.0.0:80              0.0.0.0:*              LISTEN      44528/nginx: master
    tcp        0      0 0.0.0.0:22              0.0.0.0:*              LISTEN      1534/sshd: /usr/sbi
    tcp        0      0 0.0.0.0:443            0.0.0.0:*              LISTEN      44528/nginx: master
    tcp6      0      0 :::80                  :::*                    LISTEN      44528/nginx: master
    tcp6      0      0 :::22                  :::*                    LISTEN      1534/sshd: /usr/sbi
    tcp6      0      0 :::443                  :::*                    LISTEN      44528/nginx: master
    udp        0      0 127.0.0.53:53          0.0.0.0:*                          722/systemd-resolve
    udp        0      0 192.168.178.82:68      0.0.0.0:*                          720/systemd-network
    udp6      0      0 fe80::7aac:c0ff:fea:546 :::*                                720/systemd-network
    How can I fix this?
    2023-07-20, 09:29 PM
    Does jellyfin have permission to that directory?
    supertanno
    2023-07-20, 09:39 PM
    I don't think so, I remember this also being an issue when I initially tried to put my media in /home/supertanno since Jellyfin couldn't access that.
    How can I fix this? I know that doing a CHMOD 777 on the user directory is not a good idea, but I don't have any other ideas for how to fix it.
    2023-07-20, 09:46 PM (This post was last modified: 2023-07-20, 09:47 PM by TheDreadPirate. Edited 2 times in total.)
    I can't think of a good reason why you would install an app, or have its data directory, or put your media library in your home directory.  The point of a home directory is that the files are accessible to you and you alone (not including root).You would have to add jellyfin to the group ownership of the folder.
    chown supertanno:jellyfin /home/supertanno /home/supertanno/jellyfin
    chmod 770 /home/supertanno /home/supertanno/jellyfin
    This might also work?  Slightly more restrictive permissions.
    chown supertanno:jellyfin /home/supertanno/jellyfin
    chmod 755 /home/supertanno
    chmod 770 /home/supertanno/jellyfin
    But really, nothing you need to regularly share with other users or processes should be in your home.
    supertanno
    2023-07-20, 09:52 PM
    (2023-07-20, 09:46 PM)TheDreadPirate Wrote: I can't think of a good reason why you would install an app, or have its data directory, or put your media library in your home directory.  The point of a home directory is that the files are accessible to you and you alone (not including root).You would have to add jellyfin to the group ownership of the folder.
    This was moreso because I was still getting to grips with Ubuntu, which doesn't allow root access by default, and so FileZilla was struggling to upload into /media. I'm personally used to CentOS (which should tell you how long it's been since I last used Linux), which doesn't have this issue. I ended up doing a CHMOD 777 for /media and fixed that issue that way. No clue why the data path is in that folder, though, as I never screwed around with that.
    With the above in mind, would there be a way to move the data folder to a more sensible place? If so, which one would you recommend?
    2023-07-20, 09:54 PM
    Did you change the data directory during or after install? The default is /var/lib/jellyfin and that's where jellyfin should live. Since it owns and controls itself and you don't have to open up your home directory.
    supertanno
    2023-07-20, 09:55 PM
    Not that I recall, no. How would I go about changing the data directory back to /var/lib/jellyfin?
    2023-07-20, 10:06 PM (This post was last modified: 2023-07-20, 10:08 PM by TheDreadPirate. Edited 2 times in total.)
    (2023-07-20, 09:52 PM)supertanno Wrote: ....
    Maybe make a folder in / called "library" or something?  Owned by you, group owned by jellyfin, 770.  Or 750 if you don't plan to save NFOs or have the jellyscrub plugin.
    Move all your media into that folder. If you are using FTP with your credentials, then your FTP client shouldn't have any issues writing in that directory.
    (2023-07-20, 09:55 PM)supertanno Wrote: Not that I recall, no. How would I go about changing the data directory back to /var/lib/jellyfin?
    Unless someone chimes in, I will have to get back to you when I get home from work in about 4 hours to work out the steps.
    supertanno
    2023-07-20, 10:14 PM (This post was last modified: 2023-07-20, 10:16 PM by supertanno. Edited 1 time in total.)
    (2023-07-20, 10:06 PM)TheDreadPirate Wrote: Maybe make a folder in / called "library" or something?  Owned by you, group owned by jellyfin, 770.  Or 750 if you don't plan to save NFOs or have the jellyscrub plugin.
    I don't have my media in the home directory anymore, it's in ./media. /jellyfin is in the home directory, however. Oddly, there's a folder in /var/lib/jellyfin as well:
    supertanno@tannoflix:~$ ls /var/lib/jellyfin
    data  metadata  plugins  root  transcodes
    supertanno@tannoflix:~$ ls /home/supertanno/jellyfin
    data  log  metadata  plugins  root
    But, if I use --datadir to point it there, I get the following:
    supertanno@tannoflix:~$ jellyfin -d /var/lib/jellyfin
    Unhandled Exception
    System.UnauthorizedAccessException: Access to the path '/var/lib/jellyfin/log' is denied.
    ---> System.IO.IOException: Permission denied
      at System.IO.FileSystem.CreateDirectory(String fullPath)
      at System.IO.Directory.CreateDirectory(String path)
      at Jellyfin.Server.Program.CreateApplicationPaths(StartupOptions options)
      at Jellyfin.Server.Program.StartApp(StartupOptions options)
      at Jellyfin.Server.Program.<Main>(String[] args)
    Unhandled exception. System.UnauthorizedAccessException: Access to the path '/var/lib/jellyfin/log' is denied.
    Aborted (core dumped)
    supertanno@tannoflix:~$ jellyfin -d /var/lib/jellyfin/data
    Unhandled Exception
    System.UnauthorizedAccessException: Access to the path '/var/lib/jellyfin/data/log' is denied.
    Unhandled exception. System.UnauthorizedAccessException: Access to the path '/var/lib/jellyfin/data/log' is denied.
    So yeah, that's not working, and I am very confused by now.
    supertanno
    2023-07-20, 10:22 PM (This post was last modified: 2023-07-20, 10:23 PM by supertanno. Edited 1 time in total.)
    Update on the data folder location: I just uninstalled and reinstalled Jellyfin, since I'd barely done anything about my install yet and so nothing of value would be lost.
    The new install once again made /home/supertanno/jellyfin the data folder. I am beyond baffled. It does move forward to DLNA setup now, but I'm not yet convinced that it'll actually start working.
