    Jellyfin Forum Support Troubleshooting SOLVED: Library content won't load with some sort options
    elter
    2024-07-04, 04:54 PM
    When trying to view my movie library the content won't load (loading screen appears and nothing changes). The problem is limited to my Movies library, while my Shows library works fine, and behaves the same way in all clients (Web, Android, AndroidTV). Strangely, the problem occurs only when certain sort options are selected, it doesn't work for name, critics rating, date played, parental rating, and play count, while others work fine. I am running server 10.9.7 inside docker and had no problems till about 2 months ago.
    When trying this via browser I get server side error
    GEThttp://111.111.111.111/Users/73f9a0ff3bba4d9bb0c94cf88846b874/Items?SortBy=SortName,ProductionYear&SortOrder=Descending&IncludeItemTypes=Movie&Recursive=true&Fields=PrimaryImageAspectRatio,MediaSourceCount&ImageTypeLimit=1&EnableImageTypes=Primary,Backdrop,Banner,Thumb&StartIndex=0&ParentId=8f01ecb48aebf0004f05622a1dddfdfc&Limit=100[HTTP/1.1 500 Internal Server Error 87ms]
    And looking into logs it is most likely this one:
    [2024-07-04 16:40:22.216 +00:00] [ERR] [21] Jellyfin.Api.Middleware.ExceptionMiddleware: Error processing request. URL "GET" "/Users/73f9a0ff3bba4d9bb0c94cf88846b874/Items".
    System.InvalidOperationException: Failed to compare two elements in the array.
    ---> System.TypeInitializationException: The type initializer for 'ICU4N.Text.Transliterator' threw an exception.
    ---> System.TypeInitializationException: The type initializer for 'ICU4N.Globalization.UCultureInfo' threw an exception.
    ---> System.Globalization.CultureNotFoundException: Only the invariant culture is supported in globalization-invariant mode. See https://aka.ms/GlobalizationInvariantMode for more information. (Parameter 'name')
    en is an invalid culture identifier.
      at System.Globalization.CultureInfo..ctor(String name, Boolean useUserOverride)
      at ICU4N.Globalization.UCultureInfo..cctor()
      at ICU4N.Globalization.UCultureInfo.get_CurrentCulture()
      at ICU4N.Impl.ICUResourceBundle.GetBundleInstance(String baseName, String localeID, Assembly root, OpenType openType)
      at ICU4N.Impl.ICUResourceBundle.GetBundleInstance(String baseName, String localeID, Assembly root, Boolean disableFallback)
      at ICU4N.Util.UResourceBundle.<>c__DisplayClass25_0.<GetRootType>b__0(String key)
      at System.Collections.Concurrent.ConcurrentDictionary`2.GetOrAdd(TKey key, Func`2 valueFactory)
      at ICU4N.Util.UResourceBundle.GetRootType(String baseName, Assembly root)
      at ICU4N.Util.UResourceBundle.InstantiateBundle(String baseName, String localeName, Assembly root, Boolean disableFallback)
      at ICU4N.Util.UResourceBundle.GetBundleInstance(String baseName, String localeName, Assembly root, Boolean disableFallback)
      at ICU4N.Util.UResourceBundle.GetBundleInstance(String baseName, String localeName, Assembly root)
      at ICU4N.Text.Transliterator..cctor()
      at ICU4N.Text.Transliterator.GetInstance(String id)
      at Jellyfin.Extensions.StringExtensions.<>c.<.cctor>b__8_0()
      at System.Lazy`1.ViaFactory(LazyThreadSafetyMode mode)
      at System.Lazy`1.ExecutionAndPublication(LazyHelper executionAndPublication, Boolean useDefaultConstructor)
      at System.Lazy`1.CreateValue()
      at Jellyfin.Extensions.StringExtensions.Transliterated(String text)
      at MediaBrowser.Controller.Entities.BaseItem.ModifySortChunks(ReadOnlySpan`1 name)
      at MediaBrowser.Controller.Entities.BaseItem.CreateSortName()
      at MediaBrowser.Controller.Entities.BaseItem.get_SortName()
      at Emby.Server.Implementations.Sorting.SortNameComparer.Compare(BaseItem x, BaseItem y)
      at System.Linq.EnumerableSorter`2.CompareAnyKeys(Int32 index1, Int32 index2)
      at System.Collections.Generic.ArraySortHelper`1.PickPivotAndPartition(Span`1 keys, Comparison`1 comparer)
      at System.Collections.Generic.ArraySortHelper`1.IntroSort(Span`1 keys, Int32 depthLimit, Comparison`1 comparer)
      at System.Collections.Generic.ArraySortHelper`1.Sort(Span`1 keys, Comparison`1 comparer)
      at System.Linq.EnumerableSorter`2.QuickSort(Int32[] keys, Int32 lo, Int32 hi)
      at System.Linq.EnumerableSorter`1.Sort(TElement[] elements, Int32 count)
      at System.Linq.OrderedEnumerable`1.Fill(Buffer`1 buffer, Span`1 destination)
      at System.Linq.OrderedEnumerable`1.ToArray()
      at MediaBrowser.Controller.Entities.UserViewBuilder.SortAndPage(IEnumerable`1 items, Nullable`1 totalRecordLimit, InternalItemsQuery query, ILibraryManager libraryManager, Boolean enableSorting)
      at MediaBrowser.Controller.Entities.Folder.PostFilterAndSort(IEnumerable`1 items, InternalItemsQuery query, Boolean enableSorting)
      at MediaBrowser.Controller.Entities.Folder.QueryRecursive(InternalItemsQuery query)
      at MediaBrowser.Controller.Entities.Folder.GetItemsInternal(InternalItemsQuery query)
      at MediaBrowser.Controller.Entities.Folder.GetItems(InternalItemsQuery query)
      at Jellyfin.Api.Controllers.ItemsController.GetItems(Nullable`1 userId, String maxOfficialRating, Nullable`1 hasThemeSong, Nullable`1 hasThemeVideo, Nullable`1 hasSubtitles, Nullable`1 hasSpecialFeature, Nullable`1 hasTrailer, Nullable`1 adjacentTo, Nullable`1 parentIndexNumber, Nullable`1 hasParentalRating, Nullable`1 isHd, Nullable`1 is4K, LocationType[] locationTypes, LocationType[] excludeLocationTypes, Nullable`1 isMissing, Nullable`1 isUnaired, Nullable`1 minCommunityRating, Nullable`1 minCriticRating, Nullable`1 minPremiereDate, Nullable`1 minDateLastSaved, Nullable`1 minDateLastSavedForUser, Nullable`1 maxPremiereDate, Nullable`1 hasOverview, Nullable`1 hasImdbId, Nullable`1 hasTmdbId, Nullable`1 hasTvdbId, Nullable`1 isMovie, Nullable`1 isSeries, Nullable`1 isNews, Nullable`1 isKids, Nullable`1 isSports, Guid[] excludeItemIds, Nullable`1 startIndex, Nullable`1 limit, Nullable`1 recursive, String searchTerm, SortOrder[] sortOrder, Nullable`1 parentId, ItemFields[] fields, BaseItemKind[] excludeItemTypes, BaseItemKind[] includeItemTypes, ItemFilter[] filters, Nullable`1 isFavorite, MediaType[] mediaTypes, ImageType[] imageTypes, ItemSortBy[] sortBy, Nullable`1 isPlayed, String[] genres, String[] officialRatings, String[] tags, Int32[] years, Nullable`1 enableUserData, Nullable`1 imageTypeLimit, ImageType[] enableImageTypes, String person, Guid[] personIds, String[] personTypes, String[] studios, String[] artists, Guid[] excludeArtistIds, Guid[] artistIds, Guid[] albumArtistIds, Guid[] contributingArtistIds, String[] albums, Guid[] albumIds, Guid[] ids, VideoType[] videoTypes, String minOfficialRating, Nullable`1 isLocked, Nullable`1 isPlaceHolder, Nullable`1 hasOfficialRating, Nullable`1 collapseBoxSetItems, Nullable`1 minWidth, Nullable`1 minHeight, Nullable`1 maxWidth, Nullable`1 maxHeight, Nullable`1 is3D, SeriesStatus[] seriesStatus, String nameStartsWithOrGreater, String nameStartsWith, String nameLessThan, Guid[] studioIds, Guid[] genreIds, Boolean enableTotalRecordCount, Nullable`1 enableImages)
      at Jellyfin.Api.Controllers.ItemsController.GetItemsByUserIdLegacy(Guid userId, String maxOfficialRating, Nullable`1 hasThemeSong, Nullable`1 hasThemeVideo, Nullable`1 hasSubtitles, Nullable`1 hasSpecialFeature, Nullable`1 hasTrailer, Nullable`1 adjacentTo, Nullable`1 parentIndexNumber, Nullable`1 hasParentalRating, Nullable`1 isHd, Nullable`1 is4K, LocationType[] locationTypes, LocationType[] excludeLocationTypes, Nullable`1 isMissing, Nullable`1 isUnaired, Nullable`1 minCommunityRating, Nullable`1 minCriticRating, Nullable`1 minPremiereDate, Nullable`1 minDateLastSaved, Nullable`1 minDateLastSavedForUser, Nullable`1 maxPremiereDate, Nullable`1 hasOverview, Nullable`1 hasImdbId, Nullable`1 hasTmdbId, Nullable`1 hasTvdbId, Nullable`1 isMovie, Nullable`1 isSeries, Nullable`1 isNews, Nullable`1 isKids, Nullable`1 isSports, Guid[] excludeItemIds, Nullable`1 startIndex, Nullable`1 limit, Nullable`1 recursive, String searchTerm, SortOrder[] sortOrder, Nullable`1 parentId, ItemFields[] fields, BaseItemKind[] excludeItemTypes, BaseItemKind[] includeItemTypes, ItemFilter[] filters, Nullable`1 isFavorite, MediaType[] mediaTypes, ImageType[] imageTypes, ItemSortBy[] sortBy, Nullable`1 isPlayed, String[] genres, String[] officialRatings, String[] tags, Int32[] years, Nullable`1 enableUserData, Nullable`1 imageTypeLimit, ImageType[] enableImageTypes, String person, Guid[] personIds, String[] personTypes, String[] studios, String[] artists, Guid[] excludeArtistIds, Guid[] artistIds, Guid[] albumArtistIds, Guid[] contributingArtistIds, String[] albums, Guid[] albumIds, Guid[] ids, VideoType[] videoTypes, String minOfficialRating, Nullable`1 isLocked, Nullable`1 isPlaceHolder, Nullable`1 hasOfficialRating, Nullable`1 collapseBoxSetItems, Nullable`1 minWidth, Nullable`1 minHeight, Nullable`1 maxWidth, Nullable`1 maxHeight, Nullable`1 is3D, SeriesStatus[] seriesStatus, String nameStartsWithOrGreater, String nameStartsWith, String nameLessThan, Guid[] studioIds, Guid[] genreIds, Boolean enableTotalRecordCount, Nullable`1 enableImages)
      at lambda_method680(Closure, Object, Object[])
      at Microsoft.AspNetCore.Mvc.Infrastructure.ActionMethodExecutor.SyncObjectResultExecutor.Execute(ActionContext actionContext, IActionResultTypeMapper mapper, ObjectMethodExecutor executor, Object controller, Object[] arguments)
      at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.InvokeActionMethodAsync()
      at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.InvokeNextActionFilterAsync()
      at Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker.InvokeInnerFilterAsync()
      at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.InvokeFilterPipelineAsync()
    I would be happy for any suggestion what to try or what other info to provide.
    2024-07-04, 04:57 PM
    In docker, set this environment variable to 0.
    DOTNET_SYSTEM_GLOBALIZATION_INVARIANT
    elter
    2024-07-04, 05:02 PM
    That fixed it, thank you.
    gregory
    Country:France
    2024-08-05, 11:53 AM
    (2024-07-04, 04:57 PM)TheDreadPirate Wrote: In docker, set this environment variable to 0.
    Thank you, it solves also for me (french characters).
    Gregory
