    Jellyfin Forum Support Troubleshooting SOLVED: Most compatible container and format
    ghiamar
    Country:Argentina
    2024-07-24, 09:51 PM (This post was last modified: 2024-07-31, 11:54 AM by ghiamar. Edited 4 times in total.)
    Hi! I'm searching for the most compatible format and container to use on iOS, Android and Shield TV Pro 2019 clients. I'm using Jellyfin Server 10.9.8 (Docker) and the official clients for those platforms. For this I read https://jellyfin.org/docs/general/client...c-support/ and decided to use Handbrake to transcode some test videos to MP4 (HB created .m4v files then renamed to .mp4) container with h264 8bit (I think) video and two channels of AAC audio and two channels for subtitles with following results:
    Logged in clients with administrator user account and transcode options disabled:
    • Allow audio playback that requires transcoding
    • Allow video playback that requires transcoding
    Bluey (2018) s01e01.mp4
    • Web client 10.9.8 (Firefox): Play method Direct playing (plays after 2 to 3 minutes)
    • Android client 2.6.2: Play method Remux (After triggering remux, plays very quickly and creates mp4 cache files in /cache/transcodes/, see attachment)
    • iOS client 1.5.0: No go with error "Playback failed because the media is not supported by this client." After a while (about after 2 to 3 minutes), the file plays in direct play mode
    • Shield TV Pro 2019 0.16.11: Works right away, no remux, nothing, as it should I guess...
    Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Season 01 remaster/Bluey (2018) s01e01.mp4':
      Metadata:
        major_brand    : mp42
        minor_version  : 512
        compatible_brands: mp42iso2avc1mp41
        creation_time  : 2024-07-24T14:35:07.000000Z
        title          : Bluey - T01E01 - Stranno
        artist          : Dave McCormack,Melanie Zanetti,Brad Elliot,Hsiao-Ling Tang
        encoder        : HandBrake 1.5.1 2022030700
        description    : Bluey y Bingo sacan un xilófono mágico que tiene el poder de congelar a su padre
      Duration: 00:07:18.02, start: 0.000000, bitrate: 1558 kb/s
      Chapters:
        Chapter #0:0: start 0.000000, end 420.503000
          Metadata:
            title          : Intro
        Chapter #0:1: start 420.503000, end 437.937000
          Metadata:
            title          : Credits
      Stream #0:0(und): Video: h264 (Main) (avc1 / 0x31637661), yuv420p(tv, bt709), 1920x1080 [SAR 1:1 DAR 16:9], 1226 kb/s, 23.98 fps, 23.98 tbr, 90k tbn, 47.95 tbc (default)
        Metadata:
          handler_name    : VideoHandler
          vendor_id      : [0][0][0][0]
      Stream #0:1(spa): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 160 kb/s (default)
        Metadata:
          handler_name    : Español (Latinoamericano)
      Stream #0:2(eng): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 160 kb/s
        Metadata:
          handler_name    : English
      Stream #0:3(eng): Subtitle: mov_text (tx3g / 0x67337874), 1920x162, 0 kb/s (default)
        Metadata:
          handler_name    : English [CC]
      Stream #0:4(spa): Subtitle: mov_text (tx3g / 0x67337874), 1920x162, 0 kb/s
        Metadata:
          handler_name    : Español (Latinoamericano) [CC]
      Stream #0:5(eng): Data: bin_data (text / 0x74786574)
        Metadata:
          handler_name    : SubtitleHandler
    Bluey (2018) s01e02.mp4
    Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/home/martinb/.01-media/Season 01 remaster/Bluey (2018) s01e02.mp4':
      Metadata:
        major_brand    : mp42
        minor_version  : 512
        creation_time  : 2024-07-24T16:18:38.000000Z
        title          : Bluey - T01E02 - Stranno
        description    : Mientras juegan a los hospitales, el padre queda en manos de la doctora Bluey, m
      Duration: 00:07:18.02, start: 0.000000, bitrate: 1515 kb/s
      Chapters:
        Chapter #0:0: start 0.000000, end 421.421000
          Metadata:
            title          : Intro
        Chapter #0:1: start 421.421000, end 437.937000
          Metadata:
            title          : Credits
      Stream #0:0(und): Video: h264 (Main) (avc1 / 0x31637661), yuv420p(tv, bt709), 1920x1080 [SAR 1:1 DAR 16:9], 1183 kb/s, 23.98 fps, 23.98 tbr, 90k tbn, 47.95 tbc (default)
        Metadata:
        Metadata:
        Metadata:
        Metadata:
        Metadata:
        Metadata:
    Bluey (2018) s01e03.mp4
    Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/home/martinb/.01-media/Season 01 remaster/Bluey (2018) s01e03.mp4':
      Metadata:
        major_brand    : mp42
        minor_version  : 512
        creation_time  : 2024-07-24T16:19:51.000000Z
        title          : Bluey - T01E03 - Stranno
        description    : La madre de Bluey le sugiere que use el globo que les queda para jugar a 'Que no
      Duration: 00:07:18.02, start: 0.000000, bitrate: 1861 kb/s
      Chapters:
        Chapter #0:0: start 0.000000, end 421.504000
          Metadata:
            title          : Intro
        Chapter #0:1: start 421.504000, end 437.937000
          Metadata:
            title          : Credits
      Stream #0:0(und): Video: h264 (Main) (avc1 / 0x31637661), yuv420p(tv, bt709), 1920x1080 [SAR 1:1 DAR 16:9], 1529 kb/s, 23.98 fps, 23.98 tbr, 90k tbn, 47.95 tbc (default)
        Metadata:
        Metadata:
        Metadata:
        Metadata:
        Metadata:
        Metadata:
    .txt   Bluey (2018) s01e01.mp4-FFmpeg.Remux-2024-07-24_21-34-54_0c3c95c8818c63623fba07c24798cbb2_7b9cdc7b.log.txt (Size: 20.63 KB / Downloads: 89)
    .txt   Bluey (2018) s01e02.mp4-FFmpeg.Remux-2024-07-24_21-35-09_9fcb4e460a2876799f5e3f9b04b2e259_3d16c202.log.txt (Size: 20.63 KB / Downloads: 113)
    .txt   Bluey (2018) s01e03.mp4-FFmpeg.Remux-2024-07-24_21-35-27_25c2051ecde5e9133fd2f4ec271e36a6_79d36057.log.txt (Size: 20.63 KB / Downloads: 96)
    Ubuntu 22.04 LTS
    Intel Core i5-8500T (6 cores, 6 threads)
    16GB (2x8GB) SODIMM DDR4-2667
    Intel UHD Graphics 630
    OS drive
        Samsung SSD 840 120GB
        2x TeamGroup 2TB nvme (software raid1 mdadm)
    2024-07-25, 12:12 AM
    If its direct playing, it shouldn't take 2 to 3 minutes to start. Can you share your full jellyfin log via pastebin?
    ghiamar
    Country:Argentina
    2024-07-26, 01:16 PM (This post was last modified: 2024-07-26, 01:17 PM by ghiamar.)
    Bump, sorry
    (2024-07-25, 12:12 AM)TheDreadPirate Wrote: If its direct playing, it shouldn't take 2 to 3 minutes to start.  Can you share your full jellyfin log via pastebin?
    Sorry, didn't see this message, please tell me how can I obtain the full JF log and will share it right away
    Ubuntu 22.04 LTS
    OS drive
    2024-07-26, 01:38 PM
    Its in the same directory as the ffmpeg logs you attached in your first post.
    ghiamar
    Country:Argentina
    2024-07-26, 01:55 PM
    Ok, I think I got them, uploading 3 logs
    log_20240724.log: https://pastebin.com/raw/rKYEtr3G
    log_20240725.log: https://pastebin.com/raw/ZXVz7ExT
    log_20240726.log: https://pastebin.com/raw/FvFeZz37
    Ubuntu 22.04 LTS
    OS drive
    ghiamar
    Country:Argentina
    2024-07-26, 02:22 PM (This post was last modified: 2024-07-26, 02:46 PM by ghiamar. Edited 2 times in total. Edit Reason: updated devices config in docker compose )
    Just to mention that I've enabled HW accel with this guide https://elblogdelazaro.org/posts/2020-04...-jellyfin/ and this reddit thread https://www.reddit.com/r/jellyfin/commen..._is_being/ resulting in this docker compose file and attached JF transcoding config (see attachment):
        image: 'jellyfin/jellyfin:10.9.8'
        container_name: jellyfin
        restart: always
          - /XXXX/XXXX/jellyfin/config:/config
          - /XXXX/XXXX/jellyfin/config/web-config.json:/jellyfin/jellyfin-web/config.json
          - /XXXX/XXXX/jellyfin/cache:/cache
          - type: bind
            source: /XXXX/XXXX/jellyfin/media
            target: /media
        # user: 0:0
        network_mode: 'host'
        # Optional - alternative address used for autodiscovery
        environment:
          - JELLYFIN_PublishedServerUrl=https://XXXXXXX.XXXXXXXX.com
        # Optional - may be necessary for docker healthcheck to pass if running in host network mode
        extra_hosts:
          - 'host.docker.internal:host-gateway'
        devices:
    Ubuntu 22.04 LTS
    OS drive
    2024-07-26, 04:06 PM (This post was last modified: 2024-07-26, 06:02 PM by TheDreadPirate. Edited 1 time in total.)
    Two things.
    What is the point of this line?
    And can you change your media mount from a bind to a volume mount?
    - /XXXX/XXXX/jellyfin/media:/media
    For some reason bind mounts sometimes cause weird problems that are hard to explain.
    One thing I noticed in your log is that your remuxes are outputting in a weird format. The output of the remux might be the cause of the issue you are experiencing.
    [2024-07-26 01:42:46.640 +00:00] [INF] [186] MediaBrowser.MediaEncoding.Transcoding.TranscodeManager: "/usr/lib/jellyfin-ffmpeg/ffmpeg" "-analyzeduration 200M -probesize 1G -fflags +genpts -f mov,mp4,m4a,3gp,3g2,mj2  -i file:\"/media/TV Shows/Petit (2018)/Season 01/Petit (2018) s01e01 - Mi mascota imaginaria existe.mp4\" -map 0:0 -map 0:1 -map -0:s -codec:v:0 copy -map_metadata -1 -map_chapters -1 -threads 0 -codec:a:0 copy -y \"/cache/transcodes/8d08736382a730bd1bc933c1ff91bc79.mov
    I've seen this happen for another user. Normally transcodes are written to /config/transcodes instead of /cache/transcodes. Since you have /config, essentially, mounted twice I'm wondering if that is causing some weird issues with how and where transcodes are written.
    Comment out the web-config.json line, restart jellyfin, and try again.
    ghiamar
    Country:Argentina
    2024-07-26, 05:54 PM
    (2024-07-26, 04:06 PM)TheDreadPirate Wrote: What is the point of this line?
    Read about that here https://jellyfin.org/docs/general/client...ig/#docker, but I really didn't changed anything in that file, removing...
    (2024-07-26, 04:06 PM)TheDreadPirate Wrote: And can you change your media mount from a bind to a volume mount?
    Think I nailed it, changed this
    Quote:      - type: bind
            source: /media/data/jellyfin/media
            target: /media
    to this
    Quote:      - /media/data/jellyfin/media:/media
    (2024-07-26, 04:06 PM)TheDreadPirate Wrote: Comment out the web-config.json line, restart jellyfin, and try again.
    Done, will try and let you know
    Ubuntu 22.04 LTS
    OS drive
    ghiamar
    Country:Argentina
    2024-07-26, 06:41 PM
    Well, tried some not played before tracks and for one got a remux, https://pastebin.com/raw/29UN0vHv for the test files (e01, e02, e03) the play starts right away (because I guess there's some cache somewhere, don't know where).
    If I re enable Allow audio playback that requires transcoding and Allow video playback that requires transcoding, transcoding kicks in now with hardware acceleration (I guess because transcoding FPS went up to > 300 ) but de playback start delay persists (about 1 min in web player, didn't tested it in my other clients), logs https://pastebin.com/raw/d1m2CUXq and https://pastebin.com/raw/pYLKBk7J
    Re uploaded today's log https://pastebin.com/raw/H8RjybiF
    Ubuntu 22.04 LTS
    OS drive
    ghiamar
    Country:Argentina
    2024-07-26, 06:52 PM
    After several tries in iOS client with error "Playback failed because the media is not supported by this client.", I got the file playing, see logs
    https://pastebin.com/raw/gfkB2aUw
    https://pastebin.com/raw/RZJTvdM4
    https://pastebin.com/raw/WkCbwZdF
    https://pastebin.com/raw/rUZs5E84
    Log https://pastebin.com/j3LHqypR
    Ubuntu 22.04 LTS
    OS drive
