    Jellyfin Forum Support Troubleshooting SOLVED: Movie exits with error code due "audio codec not supported"
    ohshitgorillas
    Threads: 8
    2023-10-20, 03:56 AM
    Interesting... because the TV (running Roku natively) is already plugged in via Ethernet. The media server has a 2.5Gb connection to the router. Bandwidth should be the last issue. Maybe time to try a different switch?
    Deleted User
    Unregistered
    #12
    2023-10-20, 04:02 AM
    perhaps, or cables?
    between your first log showing "Slow HTTP Response" which indicates network
    then the ffmpeg log showing '[q] command received. Exiting.' which indicates the client disconnected
    the ffmpeg log also shows a very good encode speed which indicates no issue on the server itself
    if it were truly an audio codec it shouldn't start playback at all
    putting all that together, the issue is sure to be between exiting the server and entering the roku, therefor network
    ohshitgorillas
    Threads: 8
    2023-10-20, 04:30 AM
    It's interesting then if the problem is the network why these files and larger ones play just fine over Plex on the same TV?
    Deleted User
    Unregistered
    #14
    2023-10-20, 04:44 AM
    then perhaps i have completely misread everything
    the way i understand things is the way i have laid them out to you
    i am not infallible nor am i a jellyfin guru - just a user trying to help another
    ohshitgorillas
    Threads: 8
    2023-10-20, 06:13 PM
    Well I appreciate it... and in fact Plex did freeze a few times last night while watching a particularly large movie. So you may be onto something after all. Thanks for the help.
    ohshitgorillas
    Threads: 8
    2023-10-21, 09:02 PM
    After upgrading my video card driver from nvidia 470 to 535, the movie now plays fine. Apparently that was the problem.
    Thanks again for your effort @000.
