    Jellyfin Forum Support Troubleshooting SOLVED: MP4 (AVI) & MPG (VOB) encoded have occasional corrupted frame on Fire TV Cube
    H264 files are fine
    jimbobbob
    2024-09-08, 03:07 PM (This post was last modified: 2024-09-08, 08:00 PM by jimbobbob. Edited 5 times in total.)
    Hi,
    When I try to play any MP4 encoded file every few seconds or so there's a glitched frame that shows a lot of small colored blocks.
    Its fine if I play a MKV H264 file.
    It only happens with files that show MP4 as the encoding.
    This affects AVI & VOB files from what I can tell.
    Only happens on the Fire TV cube.  Connecting with the Web client plays them fine (web client is same PC as the server 127.0.0.1)
    I tried using ffmpeg to change the container from AVI to MP4 using this command
    ffmpeg -i input.avi -c:v copy -c:a copy OUTPUT.mp4
    But still the same problem.
    Edit to add: I also just ran the same command adding -fflags +genpts to make a .mkv which was also the same
    Jellyfin server 10.9.11
    Jellyfin Fire TV client 0.17.4
    I get two log files.
    log_20240908.log
    [2024-09-08 15:34:08.747 +01:00] [INF] Jellyfin version: "10.9.11"
    [2024-09-08 15:34:08.759 +01:00] [INF] Environment Variables: ["[JELLYFIN_LOG_DIR, C:\Users\xxxxx\AppData\Local\jellyfin\log]"]
    [2024-09-08 15:34:08.761 +01:00] [INF] Arguments: ["C:\Users\xxxxx\Desktop\jellyfin_10.9.11-amd64\jellyfin\jellyfin.dll"]
    [2024-09-08 15:34:08.761 +01:00] [INF] Operating system: "Microsoft Windows 10.0.19045"
    [2024-09-08 15:34:08.762 +01:00] [INF] Architecture: X64
    [2024-09-08 15:34:08.763 +01:00] [INF] 64-Bit Process: True
    [2024-09-08 15:34:08.763 +01:00] [INF] User Interactive: True
    [2024-09-08 15:34:08.764 +01:00] [INF] Processor count: 8
    [2024-09-08 15:34:08.765 +01:00] [INF] Program data path: "C:\Users\xxxxx\AppData\Local\jellyfin"
    [2024-09-08 15:34:08.765 +01:00] [INF] Log directory path: "C:\Users\xxxxx\AppData\Local\jellyfin\log"
    [2024-09-08 15:34:08.766 +01:00] [INF] Config directory path: "C:\Users\xxxxx\AppData\Local\jellyfin\config"
    [2024-09-08 15:34:08.766 +01:00] [INF] Cache path: "C:\Users\xxxxx\AppData\Local\jellyfin\cache"
    [2024-09-08 15:34:08.767 +01:00] [INF] Web resources path: "C:\Users\xxxxx\Desktop\jellyfin_10.9.11-amd64\jellyfin\jellyfin-web"
    [2024-09-08 15:34:08.767 +01:00] [INF] Application directory: "C:\Users\xxxxx\Desktop\jellyfin_10.9.11-amd64\jellyfin\"
    [2024-09-08 15:34:08.846 +01:00] [INF] Setting cache path: "C:\Users\xxxxx\AppData\Local\jellyfin\cache"
    [2024-09-08 15:34:08.870 +01:00] [INF] Loading assemblies
    [2024-09-08 15:34:08.938 +01:00] [INF] Defined LAN subnets: ["127.0.0.1/8", "10.0.0.0/8", "172.16.0.0/12", "192.168.0.0/16"]
    [2024-09-08 15:34:08.939 +01:00] [INF] Defined LAN exclusions: []
    [2024-09-08 15:34:08.940 +01:00] [INF] Used LAN subnets: ["127.0.0.1/8", "10.0.0.0/8", "172.16.0.0/12", "192.168.0.0/16"]
    [2024-09-08 15:34:08.941 +01:00] [INF] Filtered interface addresses: ["192.168.178.25", "127.0.0.1"]
    [2024-09-08 15:34:08.942 +01:00] [INF] Bind Addresses ["0.0.0.0"]
    [2024-09-08 15:34:08.943 +01:00] [INF] Remote IP filter is "Allowlist"
    [2024-09-08 15:34:08.943 +01:00] [INF] Filtered subnets: []
    [2024-09-08 15:34:11.114 +01:00] [INF] Loaded plugin: "TMDb" "10.9.11.0"
    [2024-09-08 15:34:11.115 +01:00] [INF] Loaded plugin: "Studio Images" "10.9.11.0"
    [2024-09-08 15:34:11.116 +01:00] [INF] Loaded plugin: "OMDb" "10.9.11.0"
    [2024-09-08 15:34:11.128 +01:00] [INF] Loaded plugin: "MusicBrainz" "10.9.11.0"
    [2024-09-08 15:34:11.129 +01:00] [INF] Loaded plugin: "AudioDB" "10.9.11.0"
    [2024-09-08 15:34:11.187 +01:00] [INF] Kestrel is listening on "0.0.0.0"
    [2024-09-08 15:34:11.631 +01:00] [INF] Running startup tasks
    [2024-09-08 15:34:11.631 +01:00] [INF] Watching directory "D:\xxxxxx"
    [2024-09-08 15:34:11.632 +01:00] [INF] Watching directory "D:\xxxxxx"
    [2024-09-08 15:34:11.632 +01:00] [INF] Watching directory "E:\xxxxxx"
    [2024-09-08 15:34:11.632 +01:00] [INF] Watching directory "F:\xxxxxx"
    [2024-09-08 15:34:11.633 +01:00] [INF] Watching directory "F:\xxxxxx"
    [2024-09-08 15:34:11.639 +01:00] [INF] Daily trigger for "Generate Trickplay Images" set to fire at 2024-09-09 03:00:00.000 +01:00, which is 11:25:48.3605807 from now.
    [2024-09-08 15:34:11.646 +01:00] [INF] Daily trigger for "Extract Chapter Images" set to fire at 2024-09-09 02:00:00.000 +01:00, which is 10:25:48.3533888 from now.
    [2024-09-08 15:34:11.697 +01:00] [INF] Found ffmpeg version "7.0.2"
    [2024-09-08 15:34:11.741 +01:00] [INF] Available "decoders": ["libdav1d", "av1", "av1_cuvid", "av1_qsv", "h264", "h264_qsv", "h264_cuvid", "hevc", "hevc_qsv", "hevc_cuvid", "mpeg2video", "mpeg2_qsv", "mpeg2_cuvid", "mpeg4", "mpeg4_cuvid", "msmpeg4", "vc1_qsv", "vc1_cuvid", "vp8", "libvpx", "vp8_cuvid", "vp8_qsv", "vp9", "libvpx-vp9", "vp9_cuvid", "vp9_qsv", "aac", "ac3", "dca", "flac", "mp3", "truehd"]
    [2024-09-08 15:34:11.781 +01:00] [INF] Available "encoders": ["libsvtav1", "av1_nvenc", "av1_qsv", "av1_amf", "av1_vaapi", "libx264", "h264_amf", "h264_nvenc", "h264_qsv", "h264_vaapi", "libx265", "hevc_amf", "hevc_nvenc", "hevc_qsv", "hevc_vaapi", "mjpeg_qsv", "mjpeg_vaapi", "mpeg4", "msmpeg4", "libvpx", "libvpx-vp9", "aac", "ac3", "alac", "dca", "flac", "libmp3lame", "libopus", "truehd", "libvorbis", "srt"]
    [2024-09-08 15:34:11.822 +01:00] [INF] Available filters: ["deinterlace_qsv", "deinterlace_vaapi", "hwupload_cuda", "libplacebo", "overlay_opencl", "overlay_qsv", "overlay_vaapi", "overlay_vulkan", "overlay_cuda", "procamp_vaapi", "scale_cuda", "scale_qsv", "scale_vaapi", "scale_vulkan", "tonemap_opencl", "tonemap_vaapi", "vpp_qsv", "yadif_cuda", "zscale"]
    [2024-09-08 15:34:11.891 +01:00] [WRN] Filter: "tonemap_cuda" with option "GPU accelerated HDR to SDR tonemapping" is not available
    [2024-09-08 15:34:12.059 +01:00] [INF] Available hwaccel types: ["cuda", "vaapi", "dxva2", "qsv", "d3d11va", "opencl", "vulkan", "d3d12va"]
    [2024-09-08 15:34:12.081 +01:00] [INF] WS "192.168.178.131" request
    [2024-09-08 15:34:13.420 +01:00] [INF] FFmpeg: "ffmpeg"
    [2024-09-08 15:34:13.421 +01:00] [INF] ServerId: "a298aa7746174bd58d71978d70584e0f"
    [2024-09-08 15:34:13.422 +01:00] [INF] Core startup complete
    [2024-09-08 15:34:13.422 +01:00] [INF] Startup complete 0:00:04.7659469
    [2024-09-08 15:34:14.665 +01:00] [INF] "Update Plugins" Completed after 0 minute(s) and 0 seconds
    [2024-09-08 15:34:14.684 +01:00] [INF] "Clean up collections and playlists" Completed after 0 minute(s) and 0 seconds
    [2024-09-08 15:34:47.426 +01:00] [INF] User policy for "hafod". EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True
    [2024-09-08 15:34:47.687 +01:00] [INF] "ffmpeg" "-analyzeduration 200M -probesize 1G -f avi -noautorotate -i file:\"F:\xxxxxxx.avi\" -map_metadata -1 -map_chapters -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 libx265 -tag:v:0 hvc1 -preset veryfast -crf 28 -maxrate 5585224 -bufsize 11170448 -x265-params:0 no-info=1 -force_key_frames:0 \"expr:gte(t,n_forced*3)\" -bf 0 -vf \"setparams=color_primaries=bt709:color_trc=bt709:colorspace=bt709,scale=trunc(min(max(iw\,ih*a)\,min(704\,512*a))/2)*2:trunc(min(max(iw/a\,ih)\,min(704/a\,512))/2)*2,format=yuv420p\" -codec:a:0 copy -copyts -avoid_negative_ts disabled -max_muxing_queue_size 2048 -f hls -max_delay 5000000 -hls_time 3 -hls_segment_type mpegts -start_number 0 -hls_segment_filename \"C:\Users\xxxxx\AppData\Local\jellyfin\cache\transcodes\7eeea91b80dd62eee5eac8ac29cca87c%d.ts\" -hls_playlist_type vod -hls_list_size 0 -y \"C:\Users\xxxxx\AppData\Local\jellyfin\cache\transcodes\7eeea91b80dd62eee5eac8ac29cca87c.m3u8\""
    [2024-09-08 15:35:03.627 +01:00] [INF] Stopping ffmpeg process with q command for "C:\Users\xxxxx\AppData\Local\jellyfin\cache\transcodes\7eeea91b80dd62eee5eac8ac29cca87c.m3u8"
    [2024-09-08 15:35:04.095 +01:00] [INF] FFmpeg exited with code 0
    [2024-09-08 15:35:04.096 +01:00] [INF] Deleting partial stream file(s) "C:\Users\xxxxx\AppData\Local\jellyfin\cache\transcodes\7eeea91b80dd62eee5eac8ac29cca87c.m3u8"
    [2024-09-08 15:35:05.611 +01:00] [INF] Playback stopped reported by app "Android TV" "0.17.4" playing "Episode #1.1". Stopped at "13534" ms
    FFmpeg.Transcode....log
    {"Protocol":0,"Id":"cfcf2550040d8c4c6d13548f622b9deb","Path":"F:\\xxxxxxxxxxxxx.avi","EncoderPath":null,"EncoderProtocol":null,"Type":0,"Container":"avi","Size":276363264,"Name":"xxxxxxxxxxxxxxxxxxxxxx","IsRemote":false,"ETag":"ef733b308860220893bdd9a5faab9760","RunTimeTicks":17214400512,"ReadAtNativeFramerate":false,"IgnoreDts":false,"IgnoreIndex":false,"GenPtsInput":false,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"OpenToken":null,"RequiresClosing":false,"LiveStreamId":null,"BufferMs":null,"RequiresLooping":false,"SupportsProbing":true,"VideoType":0,"IsoType":null,"Video3DFormat":null,"MediaStreams":[{"Codec":"mpeg4","CodecTag":"XVID","Language":null,"ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Comment":null,"TimeBase":"1/25","CodecTimeBase":null,"Title":null,"VideoRange":1,"VideoRangeType":1,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":null,"LocalizedDefault":null,"LocalizedForced":null,"LocalizedExternal":null,"LocalizedHearingImpaired":null,"DisplayTitle":"540p MPEG4 SDR","NalLengthSize":null,"IsInterlaced":false,"IsAVC":null,"ChannelLayout":null,"BitRate":1117045,"BitDepth":8,"RefFrames":1,"PacketLength":null,"Channels":null,"SampleRate":null,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Height":512,"Width":704,"AverageFrameRate":25,"RealFrameRate":25,"Profile":"Advanced Simple Profile","Type":1,"AspectRatio":"4:3","Index":0,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Path":null,"PixelFormat":"yuv420p","Level":5,"IsAnamorphic":null},{"Codec":"mp3","CodecTag":null,"Language":null,"ColorRange":null,"ColorSpace":null,"ColorTransfer":null,"ColorPrimaries":null,"DvVersionMajor":null,"DvVersionMinor":null,"DvProfile":null,"DvLevel":null,"RpuPresentFlag":null,"ElPresentFlag":null,"BlPresentFlag":null,"DvBlSignalCompatibilityId":null,"Comment":null,"TimeBase":"3/125","CodecTimeBase":null,"Title":null,"VideoRange":0,"VideoRangeType":0,"VideoDoViTitle":null,"AudioSpatialFormat":0,"LocalizedUndefined":null,"LocalizedDefault":"Default","LocalizedForced":null,"LocalizedExternal":"External","LocalizedHearingImpaired":null,"DisplayTitle":"MP3 - Stereo","NalLengthSize":null,"IsInterlaced":false,"IsAVC":null,"ChannelLayout":"stereo","BitRate":160000,"BitDepth":null,"RefFrames":null,"PacketLength":null,"Channels":2,"SampleRate":48000,"IsDefault":false,"IsForced":false,"IsHearingImpaired":false,"Height":null,"Width":null,"AverageFrameRate":null,"RealFrameRate":null,"Profile":null,"Type":0,"AspectRatio":null,"Index":1,"Score":null,"IsExternal":false,"DeliveryMethod":null,"DeliveryUrl":null,"IsExternalUrl":null,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Path":null,"PixelFormat":null,"Level":0,"IsAnamorphic":null}],"MediaAttachments":[],"Formats":[],"Bitrate":1284335,"Timestamp":null,"RequiredHttpHeaders":{},"TranscodingUrl":null,"TranscodingSubProtocol":0,"TranscodingContainer":null,"AnalyzeDurationMs":null,"DefaultAudioStreamIndex":null,"DefaultSubtitleStreamIndex":null}
    ffmpeg -analyzeduration 200M -probesize 1G -f avi -noautorotate -i file:"F:\TV-Series-2\Never Mind The Buzzcocks\S01\Never Mind The Buzzcocks - s01e01 - Matthew Priest, Bruce Dickinson, Richard Fairbrass, Donna McPhail.avi" -map_metadata -1 -map_chapters -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 libx265 -tag:v:0 hvc1 -preset veryfast -crf 28 -maxrate 5585224 -bufsize 11170448 -x265-params:0 no-info=1 -force_key_frames:0 "expr:gte(t,n_forced*3)" -bf 0 -vf "setparams=color_primaries=bt709:color_trc=bt709:colorspace=bt709,scale=trunc(min(max(iw\,ih*a)\,min(704\,512*a))/2)*2:trunc(min(max(iw/a\,ih)\,min(704/a\,512))/2)*2,format=yuv420p" -codec:a:0 copy -copyts -avoid_negative_ts disabled -max_muxing_queue_size 2048 -f hls -max_delay 5000000 -hls_time 3 -hls_segment_type mpegts -start_number 0 -hls_segment_filename "C:\Users\xxxxx\AppData\Local\jellyfin\cache\transcodes\7eeea91b80dd62eee5eac8ac29cca87c%d.ts" -hls_playlist_type vod -hls_list_size 0 -y "C:\Users\xxxxx\AppData\Local\jellyfin\cache\transcodes\7eeea91b80dd62eee5eac8ac29cca87c.m3u8"
    ffmpeg version 7.0.2-full_build-www.gyan.dev Copyright (c) 2000-2024 the FFmpeg developers
      built with gcc 13.2.0 (Rev5, Built by MSYS2 project)
      configuration: --enable-gpl --enable-version3 --enable-static --disable-w32threads --disable-autodetect --enable-fontconfig --enable-iconv --enable-gnutls --enable-libxml2 --enable-gmp --enable-bzlib --enable-lzma --enable-libsnappy --enable-zlib --enable-librist --enable-libsrt --enable-libssh --enable-libzmq --enable-avisynth --enable-libbluray --enable-libcaca --enable-sdl2 --enable-libaribb24 --enable-libaribcaption --enable-libdav1d --enable-libdavs2 --enable-libuavs3d --enable-libxevd --enable-libzvbi --enable-librav1e --enable-libsvtav1 --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs2 --enable-libxeve --enable-libxvid --enable-libaom --enable-libjxl --enable-libopenjpeg --enable-libvpx --enable-mediafoundation --enable-libass --enable-frei0r --enable-libfreetype --enable-libfribidi --enable-libharfbuzz --enable-liblensfun --enable-libvidstab --enable-libvmaf --enable-libzimg --enable-amf --enable-cuda-llvm --enable-cuvid --enable-dxva2 --enable-d3d11va --enable-d3d12va --enable-ffnvcodec --enable-libvpl --enable-nvdec --enable-nvenc --enable-vaapi --enable-libshaderc --enable-vulkan --enable-libplacebo --enable-opencl --enable-libcdio --enable-libgme --enable-libmodplug --enable-libopenmpt --enable-libopencore-amrwb --enable-libmp3lame --enable-libshine --enable-libtheora --enable-libtwolame --enable-libvo-amrwbenc --enable-libcodec2 --enable-libilbc --enable-libgsm --enable-libopencore-amrnb --enable-libopus --enable-libspeex --enable-libvorbis --enable-ladspa --enable-libbs2b --enable-libflite --enable-libmysofa --enable-librubberband --enable-libsoxr --enable-chromaprint
    Input #0, avi, from 'file:F:\TV-Series-2\Never Mind The Buzzcocks\S01\Never Mind The Buzzcocks - s01e01 - Matthew Priest, Bruce Dickinson, Richard Fairbrass, Donna McPhail.avi':
      Metadata:
        software        : VirtualDubMod 1.5.10.1 (build 2439/release)
      Duration: 00:28:41.44, start: 0.000000, bitrate: 1284 kb/s
      Stream #0:0: Video: mpeg4 (Advanced Simple Profile) (XVID / 0x44495658), yuv420p, 704x512 [SAR 1:1 DAR 11:8], 1117 kb/s, 25 fps, 25 tbr, 25 tbn
      Stream #0:1: Audio: mp3 (mp3float) (U[0][0][0] / 0x0055), 48000 Hz, stereo, fltp, 160 kb/s
    Stream mapping:
      Stream #0:0 -> #0:0 (mpeg4 (native) -> hevc (libx265))
      Stream #0:1 -> #0:1 (copy)
    [mpeg4 @ 0000026638f3bc80] Video uses a non-standard and wasteful way to store B-frames ('packed B-frames'). Consider using the mpeg4_unpack_bframes bitstream filter without encoding but stream copy to fix it.
    x265 [info]: HEVC encoder version 3.6+36-2cdd69a6d
    x265 [info]: build info [Windows][GCC 14.1.0][64 bit] 8bit+10bit+12bit
    x265 [info]: using cpu capabilities: MMX2 SSE2Fast LZCNT SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2
    x265 [info]: Main profile, Level-3 (Main tier)
    x265 [info]: Thread pool created using 8 threads
    x265 [info]: Slices                              : 1
    x265 [info]: frame threads / pool features      : 3 / wpp(8 rows)
    x265 [warning]: Source height < 720p; disabling lookahead-slices
    x265 [info]: Coding QT: max CU size, min CU size : 64 / 8
    x265 [info]: Residual QT: max TU size, max depth : 32 / 1 inter / 1 intra
    x265 [info]: ME / range / subpel / merge        : hex / 57 / 1 / 2
    x265 [info]: Keyframe min / max / scenecut / bias  : 25 / 250 / 40 / 5.00
    x265 [info]: Lookahead / bframes / badapt        : 15 / 0 / 0
    x265 [info]: b-pyramid / weightp / weightb      : 0 / 1 / 0
    x265 [info]: References / ref-limit  cu / depth  : 2 / on / on
    x265 [info]: AQ: mode / str / qg-size / cu-tree  : 2 / 1.0 / 32 / 1
    x265 [info]: Rate Control / qCompress            : CRF-28.0 / 0.60
    x265 [info]: VBV/HRD buffer / max-rate / init    : 11170 / 5585 / 0.750
    x265 [info]: tools: rd=2 psy-rd=2.00 early-skip rskip mode=1 signhide tmvp
    x265 [info]: tools: fast-intra strong-intra-smoothing deblock sao
    Output #0, hls, to 'C:\Users\xxxxx\AppData\Local\jellyfin\cache\transcodes\7eeea91b80dd62eee5eac8ac29cca87c.m3u8':
      Metadata:
        encoder        : Lavf61.1.100
      Stream #0:0: Video: hevc (hvc1 / 0x31637668), yuv420p(bt709, progressive), 704x512 [SAR 1:1 DAR 11:8], q=2-31, 25 fps, 90k tbn
          Metadata:
            encoder        : Lavc61.3.100 libx265
          Side data:
            cpb: bitrate max/min/avg: 5585000/0/0 buffer size: 11170000 vbv_delay: N/A
      Stream #0:1: Audio: mp3 (U[0][0][0] / 0x0055), 48000 Hz, stereo, fltp, 160 kb/s
    frame=  40 fps=0.0 q=30.0 size=N/A time=00:00:00.00 bitrate=N/A speed=  0x
    [hls @ 0000026638f16240] Opening 'C:\Users\xxxxx\AppData\Local\jellyfin\cache\transcodes\7eeea91b80dd62eee5eac8ac29cca87c0.ts' for writing
    frame=  85 fps= 82 q=30.0 size=N/A time=00:00:01.80 bitrate=N/A speed=1.74x
    frame=  133 fps= 86 q=30.2 size=N/A time=00:00:03.72 bitrate=N/A speed=2.39x
    [hls @ 0000026638f16240] Opening 'C:\Users\xxxxx\AppData\Local\jellyfin\cache\transcodes\7eeea91b80dd62eee5eac8ac29cca87c1.ts' for writing
    frame=  176 fps= 85 q=30.3 size=N/A time=00:00:05.44 bitrate=N/A speed=2.64x
    frame=  224 fps= 87 q=29.8 size=N/A time=00:00:07.36 bitrate=N/A speed=2.85x
    [hls @ 0000026638f16240] Opening 'C:\Users\xxxxx\AppData\Local\jellyfin\cache\transcodes\7eeea91b80dd62eee5eac8ac29cca87c2.ts' for writing
    frame=  270 fps= 87 q=27.9 size=N/A time=00:00:09.20 bitrate=N/A speed=2.97x
    [hls @ 0000026638f16240] Opening 'C:\Users\xxxxx\AppData\Local\jellyfin\cache\transcodes\7eeea91b80dd62eee5eac8ac29cca87c3.ts' for writing
    frame=  323 fps= 89 q=29.6 size=N/A time=00:00:11.32 bitrate=N/A speed=3.13x
    [hls @ 0000026638f16240] Opening 'C:\Users\xxxxx\AppData\Local\jellyfin\cache\transcodes\7eeea91b80dd62eee5eac8ac29cca87c4.ts' for writing
    frame=  379 fps= 92 q=29.9 size=N/A time=00:00:13.56 bitrate=N/A speed=3.29x
    frame=  426 fps= 92 q=29.5 size=N/A time=00:00:15.44 bitrate=N/A speed=3.32x
    [hls @ 0000026638f16240] Opening 'C:\Users\xxxxx\AppData\Local\jellyfin\cache\transcodes\7eeea91b80dd62eee5eac8ac29cca87c5.ts' for writing
    frame=  473 fps= 92 q=29.6 size=N/A time=00:00:17.32 bitrate=N/A speed=3.35x
    frame=  520 fps= 91 q=31.1 size=N/A time=00:00:19.20 bitrate=N/A speed=3.37x
    [hls @ 0000026638f16240] Opening 'C:\Users\xxxxx\AppData\Local\jellyfin\cache\transcodes\7eeea91b80dd62eee5eac8ac29cca87c6.ts' for writing
    frame=  578 fps= 93 q=29.5 size=N/A time=00:00:21.52 bitrate=N/A speed=3.47x
    [hls @ 0000026638f16240] Opening 'C:\Users\xxxxx\AppData\Local\jellyfin\cache\transcodes\7eeea91b80dd62eee5eac8ac29cca87c7.ts' for writing
    frame=  630 fps= 94 q=29.5 size=N/A time=00:00:23.60 bitrate=N/A speed=3.51x
    [hls @ 0000026638f16240] Opening 'C:\Users\xxxxx\AppData\Local\jellyfin\cache\transcodes\7eeea91b80dd62eee5eac8ac29cca87c8.ts' for writing
    frame=  683 fps= 94 q=31.2 size=N/A time=00:00:25.72 bitrate=N/A speed=3.55x
    [hls @ 0000026638f16240] Opening 'C:\Users\xxxxx\AppData\Local\jellyfin\cache\transcodes\7eeea91b80dd62eee5eac8ac29cca87c9.ts' for writing
    frame=  776 fps=100 q=28.4 size=N/A time=00:00:29.44 bitrate=N/A speed= 3.8x
    [hls @ 0000026638f16240] Opening 'C:\Users\xxxxx\AppData\Local\jellyfin\cache\transcodes\7eeea91b80dd62eee5eac8ac29cca87c10.ts' for writing
    frame=  889 fps=107 q=28.5 size=N/A time=00:00:33.96 bitrate=N/A speed= 4.1x
    [hls @ 0000026638f16240] Opening 'C:\Users\xxxxx\AppData\Local\jellyfin\cache\transcodes\7eeea91b80dd62eee5eac8ac29cca87c11.ts' for writing
    [hls @ 0000026638f16240] Opening 'C:\Users\xxxxx\AppData\Local\jellyfin\cache\transcodes\7eeea91b80dd62eee5eac8ac29cca87c12.ts' for writing
    frame=  985 fps=112 q=28.8 size=N/A time=00:00:37.80 bitrate=N/A speed=4.31x
    [hls @ 0000026638f16240] Opening 'C:\Users\xxxxx\AppData\Local\jellyfin\cache\transcodes\7eeea91b80dd62eee5eac8ac29cca87c13.ts' for writing
    frame= 1082 fps=116 q=29.2 size=N/A time=00:00:41.68 bitrate=N/A speed=4.48x
    [hls @ 0000026638f16240] Opening 'C:\Users\xxxxx\AppData\Local\jellyfin\cache\transcodes\7eeea91b80dd62eee5eac8ac29cca87c14.ts' for writing
    frame= 1182 fps=120 q=28.7 size=N/A time=00:00:45.68 bitrate=N/A speed=4.66x
    [hls @ 0000026638f16240] Opening 'C:\Users\xxxxx\AppData\Local\jellyfin\cache\transcodes\7eeea91b80dd62eee5eac8ac29cca87c15.ts' for writing
    frame= 1275 fps=123 q=28.5 size=N/A time=00:00:49.40 bitrate=N/A speed=4.78x
    [hls @ 0000026638f16240] Opening 'C:\Users\xxxxx\AppData\Local\jellyfin\cache\transcodes\7eeea91b80dd62eee5eac8ac29cca87c16.ts' for writing
    [hls @ 0000026638f16240] Opening 'C:\Users\xxxxx\AppData\Local\jellyfin\cache\transcodes\7eeea91b80dd62eee5eac8ac29cca87c17.ts' for writing
    frame= 1373 fps=126 q=28.7 size=N/A time=00:00:53.32 bitrate=N/A speed=4.91x
    [hls @ 0000026638f16240] Opening 'C:\Users\xxxxx\AppData\Local\jellyfin\cache\transcodes\7eeea91b80dd62eee5eac8ac29cca87c18.ts' for writing
    frame= 1454 fps=128 q=30.2 size=N/A time=00:00:56.56 bitrate=N/A speed=4.97x
    [hls @ 0000026638f16240] Opening 'C:\Users\xxxxx\AppData\Local\jellyfin\cache\transcodes\7eeea91b80dd62eee5eac8ac29cca87c19.ts' for writing
    frame= 1523 fps=128 q=29.5 size=N/A time=00:00:59.32 bitrate=N/A speed=  5x
    [hls @ 0000026638f16240] Opening 'C:\Users\xxxxx\AppData\Local\jellyfin\cache\transcodes\7eeea91b80dd62eee5eac8ac29cca87c20.ts' for writing
    frame= 1587 fps=128 q=30.8 size=N/A time=00:01:01.88 bitrate=N/A speed=4.99x
    [hls @ 0000026638f16240] Opening 'C:\Users\xxxxx\AppData\Local\jellyfin\cache\transcodes\7eeea91b80dd62eee5eac8ac29cca87c21.ts' for writing
    frame= 1660 fps=129 q=29.8 size=N/A time=00:01:04.80 bitrate=N/A speed=5.02x
    [hls @ 0000026638f16240] Opening 'C:\Users\xxxxx\AppData\Local\jellyfin\cache\transcodes\7eeea91b80dd62eee5eac8ac29cca87c22.ts' for writing
    frame= 1746 fps=130 q=29.2 size=N/A time=00:01:08.24 bitrate=N/A speed=5.09x
    [hls @ 0000026638f16240] Opening 'C:\Users\xxxxx\AppData\Local\jellyfin\cache\transcodes\7eeea91b80dd62eee5eac8ac29cca87c23.ts' for writing
    frame= 1842 fps=132 q=28.5 size=N/A time=00:01:12.08 bitrate=N/A speed=5.17x
    [hls @ 0000026638f16240] Opening 'C:\Users\xxxxx\AppData\Local\jellyfin\cache\transcodes\7eeea91b80dd62eee5eac8ac29cca87c24.ts' for writing
    frame= 1932 fps=134 q=30.3 size=N/A time=00:01:15.68 bitrate=N/A speed=5.23x
    [hls @ 0000026638f16240] Opening 'C:\Users\xxxxx\AppData\Local\jellyfin\cache\transcodes\7eeea91b80dd62eee5eac8ac29cca87c25.ts' for writing
    frame= 2009 fps=134 q=29.9 size=N/A time=00:01:18.76 bitrate=N/A speed=5.26x
    [hls @ 0000026638f16240] Opening 'C:\Users\xxxxx\AppData\Local\jellyfin\cache\transcodes\7eeea91b80dd62eee5eac8ac29cca87c26.ts' for writing
    frame= 2088 fps=135 q=29.6 size=N/A time=00:01:21.92 bitrate=N/A speed=5.29x
    [hls @ 0000026638f16240] Opening 'C:\Users\xxxxx\AppData\Local\jellyfin\cache\transcodes\7eeea91b80dd62eee5eac8ac29cca87c27.ts' for writing
    [q] command received. Exiting.
    [hls @ 0000026638f16240] Opening 'C:\Users\xxxxx\AppData\Local\jellyfin\cache\transcodes\7eeea91b80dd62eee5eac8ac29cca87c28.ts' for writing
    [hls @ 0000026638f16240] Opening 'C:\Users\xxxxx\AppData\Local\jellyfin\cache\transcodes\7eeea91b80dd62eee5eac8ac29cca87c29.ts' for writing
    [out#0/hls @ 0000026638890040] video:5826KiB audio:1726KiB subtitle:0KiB other streams:0KiB global headers:0KiB muxing overhead: unknown
    frame= 2209 fps=135 q=32.5 Lsize=N/A time=00:01:26.75 bitrate=N/A speed=5.31x
    x265 [info]: frame I:    30, Avg QP:25.94  kb/s: 1847.01
    x265 [info]: frame P:  2179, Avg QP:29.39  kb/s: 521.35
    x265 [info]: Weighted P-Frames: Y:2.2% UV:1.4%
    encoded 2209 frames in 16.33s (135.30 fps), 539.35 kb/s, Avg QP:29.35
    2024-09-08, 04:00 PM
    Your H264 MKVs are probably direct playing. Or at least the video isn't being transcoded.
    Can you switch to jellyfin-ffmpeg6 to eliminate your ffmpeg build as the source of the problem? There are significant customizations to FFmpeg for Jellyfin that matter for video transcoding in Jellyfin.
    jimbobbob
    2024-09-09, 06:58 PM (This post was last modified: 2024-09-09, 07:15 PM by jimbobbob. Edited 2 times in total.)
    Hi, thanks for your reply.
    I downloaded jellyfin-ffmpeg 6.0.1-8 from here and replaced the files in my jellyfin portable folder but still the same problem sorry.
    https://github.com/jellyfin/jellyfin-ffm...g/v6.0.1-8
    Yes there is no transcoding done for the x264 ones.  Im surprised it needs to transcode for mp4 to be honest seems a bit odd the Fire TV cant accept mp4.
    Anything else I can try?
    Only other thing I tried was in the Fire TV jellyfin app if I enable "use external player" under the advanced playback settings then I can play the files fine (but with A/V sync issue) with VLC but I dont think its getting transcoded then.
    2024-09-09, 07:38 PM
    Can you try disabling "Allow encoding in HEVC format" in Dashboard > Playback?
    jimbobbob
    2024-09-10, 01:48 PM
    Good News! That seems to have fixed it. Thank you.
