    Jellyfin Forum Support Troubleshooting SOLVED: Path not found when setting up library - jellyfin on docker
    bagelsworth
    2024-09-04, 10:34 PM
    Thanks I think I pasted a command i was experimenting with.
    So for the media directories.. Do i need to define one per library?
    /media/library/movies
    /media/library/shows
    Would i need to call those both out explicitly or is just mounting /media recursive?
    2024-09-04, 10:37 PM
    You can have the overarching folder defined in the container config.
    bagelsworth
    2024-09-04, 10:49 PM (This post was last modified: 2024-09-04, 10:50 PM by bagelsworth.)
    Thanks.  I have tried several variations but still getting path not found.  I did manage to get the compose working though.
    Attempt 1:
        image: jellyfin/jellyfin:latest
        container_name: jellyfin
        user: 1000:1000
        network_mode: 'host'
          - /docker/jellyfin/config:/config
          - /docker/jellyfin/cache:/cache
          - type: bind
            source: /media/library
            target: /library
        restart: 'unless-stopped'
    Attempt 2 - tried with both user and no user defined:
          - /media/library:/library
    2024-09-04, 11:00 PM
    What is the output of
    cat /proc/mounts
    bagelsworth
    2024-09-04, 11:06 PM (This post was last modified: 2024-09-04, 11:08 PM by bagelsworth. Edited 1 time in total.)
    OK i just got it work... I am not sure why but just doing "/mediaConfused-facemedia" in the compose allowed me to add a library for "/media/library/movies". Not sure I understand why though..
    Also does not defining a user run Jellyfin as root by default?
    And thank you very much for your time and patience helping me with this! Trying to make the switch from windows to all linux and I struggle with linux directories and permissions.
    2024-09-04, 11:11 PM (This post was last modified: 2024-09-04, 11:13 PM by TheDreadPirate.)
    Yes, without a user specified the container will run as root.
    If you struggle with Linux permissions, I wrote a primer in the walkthrough sub-forum.
    https://forum.jellyfin.org/t-mounting-lo...ons-primer
    Also, prior to just doing "/mediaConfused-facemedia" what path were you trying to add in the Jellyfin UI?
    bagelsworth
    2024-09-04, 11:16 PM
    Awesome that is great. Bookmarked and ill look through it.
    I was trying to add /media/library and /media/library/movies
    2024-09-05, 02:41 AM
    Ah. Ok. With the way you mounted it, those directories wouldn't exist. You mounted /media/library as "/library" in the container. So in the Jellyfin UI you should have been starting from /library/movies, etc.
