    Jellyfin Forum Support Troubleshooting SOLVED: Problem solved! Since 10.9.2, loss options. Need help
    Forced subs aren't working like it should be.
    Alliyance
    2024-05-20, 01:26 AM (This post was last modified: 2024-05-20, 04:27 PM by Alliyance. Edited 8 times in total.)
    My main Jellyfin is installed on a seedbox, I believe they use Linux system. Since the new version, the Users page has been change. I don't have Playback settings and Client and Contols was added which I don't have access. I installed the 10.9.2 version on my pc and everything is there. Why's that?
    Its impossible to change the settings in the user Subtitles, Client settings and Controls. When i try to click, it doesn't open the page for the settings. In either on iphone app or WebUi
    The Preferred Subtitle language is ignore under Subtitle mode "Smart".
    My movies are binlingal and some users are programmed under "Preferred subtiltes language" for the French Forced subs to activate and the english users is the english forced subs, but now, the forced french subs are turn on for the english users.
    Alliyance
    2024-05-20, 04:25 PM
    The issue was cause by my server company, It's fix now.
    Thanks
