    Jellyfin Forum Support Troubleshooting SOLVED: Problem transcoding with QSV on Intel ARC A380 on Debian 12 bookworm
    "Selected ratecontrol mode is unsupported" when trying to transcode video
    ainmosni
    2024-05-10, 11:12 AM (This post was last modified: 2024-05-10, 03:05 PM by ainmosni. Edited 2 times in total.)
    Hey all,
    When I try to play certain videos via the Android app, I get the following error:
    [Image: photo-2024-05-10-12-34-35.jpg]
    When looking at the logs, I see an ffmpeg command followed by
    [12:34:20] [ERR] [303] Jellyfin.Api.Helpers.TranscodingJobHelper: FFmpeg exited with code 1
    When I enter the container and run the command in the logs I see the following:
    root@jellyfin-0:/config# /usr/lib/jellyfin-ffmpeg/ffmpeg -analyzeduration 200M -init_hw_device vaapi=va:,kernel_driver=i915,driver=iHD -init_hw_device qsv=qs@va -filter_hw_device qs -autorotate 0 -i file:"/config/test.mkv" -map_metadata -1 -map_chapters -1 -threads 0 -map 0:0 -map 0:1 -map -0:s -codec:v:0 h264_qsv -low_power 1 -preset 7 -look_ahead 0 -b:v 4041447 -maxrate 4041447 -bufsize 8082894 -profile:v:0 high -level 41 -g:v:0 72 -keyint_min:v:0 72 -vf "setparams=color_primaries=bt709:color_trc=bt709:colorspace=bt709,scale=trunc(min(max(iw\,ih*a)\,min(1920\,1080*a))/2)*2:trunc(min(max(iw/a\,ih)\,min(1920/a\,1080))/2)*2,format=yuv420p" -codec:a:0 libfdk_aac -ac 2 -ab 192000 -ar 48000 -copyts -avoid_negative_ts disabled -max_muxing_queue_size 2048 -f hls -max_delay 5000000 -hls_time 3 -hls_segment_type mpegts -start_number 0 -hls_segment_filename "/config/transcodes/6155ff3833d70620e888d60b5dd1704d%d.ts" -hls_playlist_type vod -hls_list_size 0 -y "/config/transcodes/6155ff3833d70620e888d60b5dd1704d.m3u8"
    ffmpeg version 5.1.4-Jellyfin Copyright (c) 2000-2023 the FFmpeg developers
      built with gcc 10 (Debian 10.2.1-6)
      configuration: --prefix=/usr/lib/jellyfin-ffmpeg --target-os=linux --extra-libs=-lfftw3f --extra-version=Jellyfin --disable-doc --disable-ffplay --disable-ptx-compression --disable-static --disable-libxcb --disable-sdl2 --disable-xlib --enable-lto --enable-gpl --enable-version3 --enable-shared --enable-gmp --enable-gnutls --enable-chromaprint --enable-libdrm --enable-libass --enable-libfreetype --enable-libfribidi --enable-libfontconfig --enable-libbluray --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvorbis --enable-libopenmpt --enable-libdav1d --enable-libwebp --enable-libvpx --enable-libx264 --enable-libx265 --enable-libzvbi --enable-libzimg --enable-libfdk-aac --arch=amd64 --enable-libsvtav1 --enable-libshaderc --enable-libplacebo --enable-vulkan --enable-opencl --enable-vaapi --enable-amf --enable-libmfx --enable-ffnvcodec --enable-cuda --enable-cuda-llvm --enable-cuvid --enable-nvdec --enable-nvenc
    Input #0, matroska,webm, from 'file:/config/test.mkv':
      Metadata:
        title          : Dimension 20 - S21E16 - Untapped Rage
        COMPATIBLE_BRANDS: isomiso2avc1mp41
        MAJOR_BRAND    : isom
        MINOR_VERSION  : 512
        ENCODER        : Lavf60.16.100
      Duration: 01:41:14.50, start: 0.000000, bitrate: 4041 kb/s
      Stream #0:0: Video: h264 (High), yuv420p(tv, bt709, progressive), 1920x1080, 23.98 fps, 23.98 tbr, 1k tbn (default)
        Metadata:
          HANDLER_NAME    : VideoHandler
          VENDOR_ID      : [0][0][0][0]
          DURATION        : 01:41:14.444000000
      Stream #0:1(eng): Audio: aac (LC), 48000 Hz, stereo, fltp (default)
        Metadata:
          HANDLER_NAME    : SoundHandler
          DURATION        : 01:41:14.496000000
    Stream mapping:
      Stream #0:0 -> #0:0 (h264 (native) -> h264 (h264_qsv))
      Stream #0:1 -> #0:1 (aac (native) -> aac (libfdk_aac))
    [h264_qsv @ 0x556cec8dfa80] Selected ratecontrol mode is unsupported
    [h264_qsv @ 0x556cec8dfa80] some encoding parameters are not supported by the QSV runtime. Please double check the input parameters.
    Error initializing output stream 0:0 -- Error while opening encoder for output stream #0:0 - maybe incorrect parameters such as bit_rate, rate, width or height
    [libfdk_aac @ 0x556cec8f5e80] 2 frames left in the queue on closing
    Conversion failed!
    My playback config page looks like this:
    [Image: Screenshot-20240510-124612.png]
    [Image: Screenshot-20240510-124636.png]
    [Image: Screenshot-20240510-124709.png]
    [Image: Screenshot-20240510-124743.png]
    My jellyfin server is running in a container running privileged in a single node kubernetes cluster.
    The image I'm using is the official image:
    docker.io/jellyfin/jellyfin@sha256:41fc4f9a51f638930bf16eace81acacbafaf26436d0efc0b0edd9447cb134a2c
    The Jellyfin version in this image is
    And the video cards are an integrated radeon card, that I don't want to use, and an intel ARC a380 that I'm trying to use via QSV.
    The video does play properly when played on my laptop through firefox or on my LG TV via the WebOS app.
    This is probably something I'm missing, but this is not my speciality,
    Thanks in advance.
    Fate
    2024-05-10, 11:46 AM
    Which intel driver packages do you have installed on your host?
    Intel A330 is relatively new.... maybe not well supported on the old versions.
    I also noticed your ffmpeg is old(5.1.1), but that could be normal for the docker stuff. Sorry not that familiar with docker/k8
    2024-05-10, 12:56 PM (This post was last modified: 2024-05-10, 12:57 PM by TheDreadPirate. Edited 1 time in total.)
    The official Jellyfin docker image has ALL of the user space Intel drivers needs for Quick Sync.
    What Linux distro and kernel are you running? And how did you pass in your renderD devices?
    ainmosni
    2024-05-10, 01:26 PM (This post was last modified: 2024-05-10, 01:31 PM by ainmosni.)
    (2024-05-10, 11:46 AM)Fate Wrote: Which intel driver packages do you have installed on your host?
    The container has all the drivers installed, iHD, which I understand is the right driver for the ARC cards is included.
    (2024-05-10, 12:56 PM)TheDreadPirate Wrote: The official Jellyfin docker image has ALL of the user space Intel drivers needs for Quick Sync.
    It's a k3s installed on Debian 12, on which I installed the backported kernel 6.6.13+bpo-amd64. The devices are passed in by setting the container to privileged, which gives it access to the devices on the host OS.
    Host OS:
    root@payne:/etc/sysctl.d# ls -la /dev/dri/
    total 0
    drwxr-xr-x  3 root root        140 May 10 08:38 .
    drwxr-xr-x 19 root root      4040 May 10 08:38 ..
    drwxr-xr-x  2 root root        120 May 10 08:38 by-path
    crw-rw----  1 root video  226,  0 May 10 08:38 card0
    crw-rw----  1 root video  226,  1 May 10 08:38 card1
    crw-rw----  1 root render 226, 128 May 10 08:38 renderD128
    crw-rw----  1 root render 226, 129 May 10 08:38 renderD129
    Container:
    root@jellyfin-0:/# ls -la /dev/dri/
    total 0
    drwxr-xr-x  2 root root      120 May 10 08:58 .
    drwxr-xr-x 14 root root      3860 May 10 08:58 ..
    crw-rw----  1 root video 226,  0 May 10 08:58 card0
    crw-rw----  1 root video 226,  1 May 10 08:58 card1
    crw-rw----  1 root  105 226, 128 May 10 08:58 renderD128
    crw-rw----  1 root  105 226, 129 May 10 08:58 renderD129
    ainmosni
    2024-05-10, 01:38 PM (This post was last modified: 2024-05-10, 01:42 PM by ainmosni. Edited 1 time in total.)
    Here's the specs of the host machine:
    OS: Debian GNU/Linux 12 (bookworm) x86_64
    Host: MS-7D76 2.0
    Kernel: 6.6.13+bpo-amd64
    Uptime: 7 hours
    Packages: 769 (dpkg)
    Shell: bash 5.2.15
    CPU: AMD Ryzen 7 7700X (16) @ 5.573GHz
    GPU: AMD ATI 13:00.0 Raphael
    GPU: Intel DG2 [Arc A380]
    Memory: 30402MiB / 95743MiB
    2024-05-10, 01:50 PM
    If you aren't using the AMD iGPU at all, can you disable it in the BIOS just to eliminate it as a variable?
    ainmosni
    2024-05-10, 02:07 PM
    OK, I just did, verified by only one dri device persisting, and vainfo gives the following output:
    root@jellyfin-0:/# /usr/lib/jellyfin-ffmpeg/vainfo -a
    Trying display: drm
    libva info: VA-API version 1.20.0
    libva info: Found init function __vaDriverInit_1_20
    vainfo: VA-API version: 1.20 (libva 2.20.0)
    vainfo: Driver version: Intel iHD driver for Intel(R) Gen Graphics - 23.4.0 (05e4d0d)
    vainfo: Supported config attributes per profile/entrypoint pair
    VAProfileNone/VAEntrypointVideoProc
        VAConfigAttribRTFormat                 : VA_RT_FORMAT_YUV420
                                                 VA_RT_FORMAT_YUV422
                                                 VA_RT_FORMAT_YUV444
                                                 VA_RT_FORMAT_YUV411
                                                 VA_RT_FORMAT_YUV400
                                                 VA_RT_FORMAT_RGB16
                                                 VA_RT_FORMAT_RGB32
    VAProfileNone/VAEntrypointStats
                                                 VA_RT_FORMAT_YUV422
                                                 VA_RT_FORMAT_YUV444
                                                 VA_RT_FORMAT_YUV411
                                                 VA_RT_FORMAT_YUV400
                                                 VA_RT_FORMAT_RGB16
                                                 VA_RT_FORMAT_RGB32
    VAProfileMPEG2Simple/VAEntrypointVLD
                                                 VA_RT_FORMAT_YUV422
                                                 VA_RT_FORMAT_RGB32
        VAConfigAttribDecSliceMode             : VA_DEC_SLICE_MODE_NORMAL
        VAConfigAttribDecProcessing            : VA_DEC_PROCESSING_NONE
        VAConfigAttribMaxPictureWidth          : 1920
        VAConfigAttribMaxPictureHeight         : 1920
        VAConfigAttribProcessingRate           : VA_PROCESSING_RATE_DECODE
    VAProfileMPEG2Main/VAEntrypointVLD
                                                 VA_RT_FORMAT_YUV422
                                                 VA_RT_FORMAT_RGB32
    VAProfileH264Main/VAEntrypointVLD
                                                 VA_RT_FORMAT_YUV422
                                                 VA_RT_FORMAT_RGB32
                                                 VA_DEC_SLICE_MODE_BASE
        VAConfigAttribMaxPictureWidth          : 8192
        VAConfigAttribMaxPictureHeight         : 8192
    VAProfileH264Main/VAEntrypointEncSliceLP
                                                 VA_RT_FORMAT_YUV422
                                                 VA_RT_FORMAT_YUV444
                                                 VA_RT_FORMAT_RGB32
        VAConfigAttribRateControl              : VA_RC_CQP
        VAConfigAttribEncPackedHeaders         : VA_ENC_PACKED_HEADER_SEQUENCE
                                                 VA_ENC_PACKED_HEADER_PICTURE
                                                 VA_ENC_PACKED_HEADER_SLICE
                                                 VA_ENC_PACKED_HEADER_MISC
                                                 VA_ENC_PACKED_HEADER_RAW_DATA
        VAConfigAttribEncInterlaced            : VA_ENC_INTERLACED_NONE
        VAConfigAttribEncMaxRefFrames          : l0=3
                                                 l1=1
        VAConfigAttribEncMaxSlices             : 256
        VAConfigAttribEncSliceStructure        : VA_ENC_SLICE_STRUCTURE_EQUAL_ROWS
                                                 VA_ENC_SLICE_STRUCTURE_MAX_SLICE_SIZE
        VAConfigAttribMaxPictureWidth          : 4096
        VAConfigAttribMaxPictureHeight         : 4096
        VAConfigAttribEncQualityRange          : number of supported quality levels is 7
        VAConfigAttribEncQuantization          : VA_ENC_QUANTIZATION_TRELLIS_SUPPORTED
        VAConfigAttribEncIntraRefresh          : VA_ENC_INTRA_REFRESH_ROLLING_COLUMN
                                                 VA_ENC_INTRA_REFRESH_ROLLING_ROW
        VAConfigAttribEncSkipFrame             : supported
        VAConfigAttribEncROI                   : num_roi_regions=16
                                                 roi_rc_priority_support=0
                                                 roi_rc_qp_delta_support=1
        VAConfigAttribProcessingRate           : VA_PROCESSING_RATE_ENCODE
        VAConfigAttribEncDirtyRect             : number of supported regions is 4
        VAConfigAttribFEIMVPredictors          : number of supported MV predictors is 4
        VAConfigAttribMaxFrameSize             : max_frame_size=1
                                                 multiple_pass=1
    VAProfileH264High/VAEntrypointVLD
                                                 VA_RT_FORMAT_YUV422
                                                 VA_RT_FORMAT_RGB32
    VAProfileH264High/VAEntrypointEncSliceLP
                                                 VA_RT_FORMAT_YUV422
                                                 VA_RT_FORMAT_YUV444
                                                 VA_RT_FORMAT_RGB32
                                                 l1=1
                                                 multiple_pass=1
    VAProfileJPEGBaseline/VAEntrypointVLD
                                                 VA_RT_FORMAT_YUV422
                                                 VA_RT_FORMAT_YUV444
                                                 VA_RT_FORMAT_YUV411
                                                 VA_RT_FORMAT_YUV400
                                                 VA_RT_FORMAT_RGB16
                                                 VA_RT_FORMAT_RGB32
        VAConfigAttribDecJPEG                  : VA_ROTATION_NONE
                                                 VA_ROTATION_90
                                                 VA_ROTATION_180
                                                 VA_ROTATION_270
        VAConfigAttribMaxPictureWidth          : 16384
        VAConfigAttribMaxPictureHeight         : 16384
    VAProfileJPEGBaseline/VAEntrypointEncPicture
                                                 VA_RT_FORMAT_YUV422
                                                 VA_RT_FORMAT_YUV444
                                                 VA_RT_FORMAT_YUV411
                                                 VA_RT_FORMAT_YUV400
                                                 VA_RT_FORMAT_RGB16
                                                 VA_RT_FORMAT_RGB32
        VAConfigAttribEncPackedHeaders         : VA_ENC_PACKED_HEADER_RAW_DATA
        VAConfigAttribEncJPEG                  : arithmatic_coding_mode=0
                                                 progressive_dct_mode=0
                                                 non_interleaved_mode=0
                                                 differential_mode=0
                                                 differential_mode=0
                                                 max_num_components=3
                                                 max_num_scans=1
                                                 max_num_huffman_tables=2
                                                 max_num_quantization_tables=3
        VAConfigAttribEncQualityRange          : number of supported quality levels is 1
    VAProfileH264ConstrainedBaseline/VAEntrypointVLD
                                                 VA_RT_FORMAT_YUV422
                                                 VA_RT_FORMAT_RGB32
    VAProfileH264ConstrainedBaseline/VAEntrypointEncSliceLP
                                                 VA_RT_FORMAT_YUV422
                                                 VA_RT_FORMAT_YUV444
                                                 VA_RT_FORMAT_RGB32
                                                 l1=1
                                                 multiple_pass=1
    VAProfileHEVCMain/VAEntrypointVLD
    VAProfileHEVCMain/VAEntrypointEncSliceLP
                                                 VA_RT_FORMAT_YUV422
                                                 VA_RT_FORMAT_YUV444
                                                 VA_RT_FORMAT_YUV420_10
                                                 VA_RT_FORMAT_YUV422_10
                                                 VA_RT_FORMAT_YUV444_10
                                                 VA_RT_FORMAT_RGB32
                                                 VA_RT_FORMAT_RGB32_10
                                                 VA_RT_FORMAT_RGB32_10BPP
                                                 VA_RT_FORMAT_YUV420_10BPP
                                                 l1=3
        VAConfigAttribEncMaxSlices             : 70
        VAConfigAttribEncSliceStructure        : VA_ENC_SLICE_STRUCTURE_POWER_OF_TWO_ROWS
                                                 VA_ENC_SLICE_STRUCTURE_ARBITRARY_ROWS
        VAConfigAttribMaxPictureHeight         : 12288
        VAConfigAttribEncQuantization          : VA_ENC_QUANTIZATION_NONE
        VAConfigAttribEncDirtyRect             : number of supported regions is 16
        VAConfigAttribEncTileSupport           : supported
                                                 multiple_pass=1
        VAConfigAttribPredictionDirection      : VA_PREDICTION_DIRECTION_PREVIOUS
                                                 VA_PREDICTION_DIRECTION_FUTURE
    VAProfileHEVCMain10/VAEntrypointVLD
    VAProfileHEVCMain10/VAEntrypointEncSliceLP
                                                 VA_RT_FORMAT_YUV422
                                                 VA_RT_FORMAT_YUV444
                                                 VA_RT_FORMAT_RGB32
                                                 l1=3
                                                 multiple_pass=1
    VAProfileVP9Profile0/VAEntrypointVLD
    VAProfileVP9Profile1/VAEntrypointVLD
        VAConfigAttribRTFormat                 : VA_RT_FORMAT_YUV422
                                                 VA_RT_FORMAT_YUV444
    VAProfileVP9Profile2/VAEntrypointVLD
        VAConfigAttribRTFormat                 : VA_RT_FORMAT_YUV420_10
                                                 VA_RT_FORMAT_YUV420_12
    VAProfileVP9Profile3/VAEntrypointVLD
        VAConfigAttribRTFormat                 : VA_RT_FORMAT_YUV422_10
                                                 VA_RT_FORMAT_YUV422_12
                                                 VA_RT_FORMAT_YUV444_12
    VAProfileHEVCMain12/VAEntrypointVLD
                                                 VA_RT_FORMAT_YUV400
    VAProfileHEVCMain422_10/VAEntrypointVLD
                                                 VA_RT_FORMAT_YUV422
                                                 VA_RT_FORMAT_YUV400
    VAProfileHEVCMain422_10/VAEntrypointEncSliceLP
                                                 VA_RT_FORMAT_YUV422
                                                 VA_RT_FORMAT_YUV444
                                                 VA_RT_FORMAT_RGB32
                                                 l1=3
                                                 multiple_pass=1
    VAProfileHEVCMain422_12/VAEntrypointVLD
                                                 VA_RT_FORMAT_YUV422
                                                 VA_RT_FORMAT_YUV400
    VAProfileHEVCMain444/VAEntrypointVLD
                                                 VA_RT_FORMAT_YUV422
                                                 VA_RT_FORMAT_YUV444
                                                 VA_RT_FORMAT_YUV400
    VAProfileHEVCMain444/VAEntrypointEncSliceLP
                                                 VA_RT_FORMAT_YUV422
                                                 VA_RT_FORMAT_YUV444
                                                 VA_RT_FORMAT_RGB32
                                                 l1=3
                                                 multiple_pass=1
    VAProfileHEVCMain444_10/VAEntrypointVLD
                                                 VA_RT_FORMAT_YUV422
                                                 VA_RT_FORMAT_YUV444
                                                 VA_RT_FORMAT_YUV400
    VAProfileHEVCMain444_10/VAEntrypointEncSliceLP
                                                 VA_RT_FORMAT_YUV422
                                                 VA_RT_FORMAT_YUV444
                                                 VA_RT_FORMAT_RGB32
                                                 l1=3
                                                 multiple_pass=1
    VAProfileHEVCMain444_12/VAEntrypointVLD
                                                 VA_RT_FORMAT_YUV422
                                                 VA_RT_FORMAT_YUV444
                                                 VA_RT_FORMAT_YUV400
    VAProfileHEVCSccMain/VAEntrypointVLD
                                                 VA_RT_FORMAT_YUV400
    VAProfileHEVCSccMain/VAEntrypointEncSliceLP
                                                 VA_RT_FORMAT_YUV422
                                                 VA_RT_FORMAT_YUV444
                                                 VA_RT_FORMAT_RGB32
                                                 l1=3
                                                 multiple_pass=1
    VAProfileHEVCSccMain10/VAEntrypointVLD
                                                 VA_RT_FORMAT_YUV400
    VAProfileHEVCSccMain10/VAEntrypointEncSliceLP
                                                 VA_RT_FORMAT_YUV422
                                                 VA_RT_FORMAT_YUV444
                                                 VA_RT_FORMAT_RGB32
                                                 l1=3
                                                 multiple_pass=1
    VAProfileHEVCSccMain444/VAEntrypointVLD
                                                 VA_RT_FORMAT_YUV422
                                                 VA_RT_FORMAT_YUV444
                                                 VA_RT_FORMAT_YUV400
    VAProfileHEVCSccMain444/VAEntrypointEncSliceLP
                                                 VA_RT_FORMAT_YUV422
                                                 VA_RT_FORMAT_YUV444
                                                 VA_RT_FORMAT_RGB32
                                                 l1=3
                                                 multiple_pass=1
    VAProfileAV1Profile0/VAEntrypointVLD
    VAProfileAV1Profile0/VAEntrypointEncSliceLP
        VAConfigAttribRateControl              : VA_RC_CBR
                                                 VA_RC_VBR
                                                 VA_RC_CQP
                                                 VA_RC_ICQ
                                                 VA_RC_TCBRC
                                                 l1=1
        VAConfigAttribEncMaxSlices             : 3
        VAConfigAttribEncIntraRefresh          : VA_ENC_INTRA_REFRESH_NONE
        VAConfigAttribEncROI                   : num_roi_regions=0
                                                 multiple_pass=1
    VAProfileHEVCSccMain444_10/VAEntrypointVLD
                                                 VA_RT_FORMAT_YUV422
                                                 VA_RT_FORMAT_YUV444
                                                 VA_RT_FORMAT_YUV400
    VAProfileHEVCSccMain444_10/VAEntrypointEncSliceLP
                                                 VA_RT_FORMAT_YUV422
                                                 VA_RT_FORMAT_YUV444
                                                 VA_RT_FORMAT_RGB32
                                                 l1=3
                                                 multiple_pass=1
    (Also, why is the code block adding the newlines?)
    ainmosni
    2024-05-10, 02:17 PM
    I also verified that the i915 kernel module is loaded with the enable_guc=2 parameter.
    2024-05-10, 02:22 PM
    Circling back a bit, check the MPEG2 and both tone mapping boxes. Arc can still decode MPEG2, which is what those boxes are for, and tone mapping is essential for converting HDR to SDR for devices that don't support HDR.
    Otherwise, that all looks much better. What happens when you try to transcode now?
    ainmosni
    I just forced a transcode on the desktop, and that also did not work, so I think I can say that this is not an android issue.
