    Jellyfin Forum Support Troubleshooting Media Scanning & Identification SOLVED: Problem with Media Folder
    Problem with finding the Media Folder
    TomSuperHero
    2024-03-29, 06:35 PM
    Hello Forum,
    first, excuse me for my bad English, it isn't my first language.
    I'm a total noob when it comes to Linux, Jellyfin or Server hosting. But I decided to change that and start a Jellyfin Server on an old PC I still had. I installed Ubuntu Server (newest Version) and CasaOS and then Jellyfin.
    Now to the Problem I have, Jellyfin, CasaOS and Ubuntu are installed on a NVME. The movies I have I would like to have on a different Drive which I mounted to /Jellyfin and gave permissions to Jellyfin. But Jellyfin can’t find the drive and therefor Aren't able to access the movies on there.
    Hope somebody can help me.
    Thanks for your help in advantage.
    Tom
    2024-03-29, 10:56 PM (This post was last modified: 2024-03-29, 10:56 PM by TheDreadPirate. Edited 1 time in total.)
    What format is it? EXT4? Or is it exFAT or NTFS?
    And since you are using CasaOS I'm assuming that means Jellyfin is running as a container, correct?
    TomSuperHero
    2024-03-30, 08:17 AM (This post was last modified: 2024-03-30, 08:18 AM by TomSuperHero. Edited 1 time in total.)
    it is EXT4
    and yes i think so is that a Problem or can it be caused by that
    2024-03-30, 05:26 PM
    No. I was just making sure I understood how everything is setup so I know what to ask.
    When you say you mounted this drive with your media to /Jellyfin, is that in Ubuntu?
    Can you share your container config for Jellyfin?
    TomSuperHero
    2024-03-31, 08:30 AM (This post was last modified: 2024-03-31, 01:11 PM by TomSuperHero. Edited 1 time in total.)
    Yeah i mounted the drive with Ubuntu.
    What do you mean with the Folder Config. Is it a File and when yes where can i find it.
    2024-03-31, 08:48 PM
    I want to see what your docker config looks like. Like this.
    ersion: '3.5'
        image: jellyfin/jellyfin:10.8.13-1
        container_name: jellyfin-stable-testing
        user: 114:122
        group_add:
          - "109" # Intel render group
        network_mode: 'host'
          - ./jellyfin-data/config:/config
          - ./jellyfin-data/cache:/cache
          - /media:/media:ro
        devices:
        restart: 'unless-stopped'
        # Optional - alternative address used for autodiscovery
        #environment:
        #  - JELLYFIN_PublishedServerUrl=http://example.com
        # Optional - may be necessary for docker healthcheck to pass if running in host network mode
        extra_hosts:
          - "host.docker.internal:host-gateway"
    TomSuperHero
    2024-03-31, 09:59 PM (This post was last modified: 2024-04-01, 08:25 AM by TomSuperHero. Edited 1 time in total.)
    How do i get this is there anything to get this kind of „code“
    Sorry im a noob at this
    2024-03-31, 10:25 PM
    Quote:\[code\]code block goes here\[/code\]
    Ignore the back slashes.  I had to put them there so you could see the syntax.
    TomSuperHero
    2024-04-01, 08:26 AM
    Yeah that i already know i meant like where can i get the thing that was in The code Bracket
    2024-04-01, 06:12 PM
    I re-read your original post and remembered you were using Casa. Can you show me screenshots of the configuration window for your Jellyfin container?
