    Jellyfin Forum Support Troubleshooting Media Scanning & Identification SOLVED: Problems with Anime ordering
    Gerico0889
    2025-02-10, 02:20 PM (This post was last modified: 2025-02-10, 07:07 PM by TheDreadPirate. Edited 2 times in total.)
    Hello, I have a problem with Dragon Ball (1986) which is pretty similar to a recent post in this sub-forum. Unfortunately, I have tried the solution provided there but it did not work so I'm currently at wits' end.
    From the picture you can see the naming of the files, which are divided in folder as such ./Dragon Ball/Season 0{1-6}/...
    I identified the Anime on Jellyfin through TMDB and this is what I see there:
    [Image: E3FzhLW.png]
    With the titles completely missing and the order completely wrong (only from Season 2, Season 1 is somehow fine):
    [Image: uHytU2P.png]
    I tried moving everything in one single Season 1 folder, renaming all the files with either the absolute episode number or with the S*E* episode number but I cannot get the correct order. May I have some suggestions? Thank you!
    Gerico0889
    2025-02-10, 06:21 PM
    Nevermind, I managed to solve it.
    Apparently, some episodes were wrongly renamed during the import for some reason. On top of that, I was using TMDB instead of TVDB. Re-importing the files, assuring that the renaming was done correctly and identifying the Anime with TVDB worked. I have all the correct episodes with titles and correct season. Sorry for the spam
