    Jellyfin Forum Support Troubleshooting SOLVED: Problems with Caddy
    Strange errors when reverse proxying Jellyfin with Caddy
    MassiveA
    Country:Italy
    2025-04-14, 08:21 PM
    Hi everybody,
    I'm quiet desperate. Let's begin from my configuration. I run a Jellyfin and Caddy istance in docker on a Ubuntu 24.10 machine, no firewall for now, I'm troubleshooting. I will write down my docker compose for reference:
        image: jellyfin/jellyfin
        container_name: jellyfin
        network_mode: 'host'
        group_add:
          - "992" #render
          - "44"  #video
          - /home/andrea/Docker/jellyfin/configConfused-faceconfig
          - /home/andrea/Docker/jellyfin/cacheConfused-facecache
          - /mnt/0d2de316-4f48-4c8d-b4bf-a9d8a8eeaf5f/Media/MoviesConfused-facemovies
          - /mnt/0d2de316-4f48-4c8d-b4bf-a9d8a8eeaf5f/Media/AnimationMoviesConfused-faceanimovies
          - /mnt/0d2de316-4f48-4c8d-b4bf-a9d8a8eeaf5f/Media/CartoonsConfused-facecartoons
          - /mnt/0d2de316-4f48-4c8d-b4bf-a9d8a8eeaf5f/Media/TVShowsConfused-facetvshows
        devices:
          - /dev/driConfused-facedev/dri
        environment:
          - PUID=1000
          - GUID=1000
          - JELLYFIN_PublishedServerUrl=https://jellyfin.serveroneago.eu/
        extra_hosts:
          - 'host.docker.internal:host-gateway'
        restart: 'unless-stopped'
      caddy:
        image: caddy:latest
        container_name: caddy
        restart: unless-stopped
        ports:
          - 80:80
          - 443:443
          - 443:443/udp
          - /home/andrea/Docker/Caddy/CaddyfileConfused-faceetc/caddy/Caddyfile
          - /home/andrea/Docker/Caddy/configConfused-faceconfig
          - /home/andrea/Docker/Caddy/dataConfused-facedata
        networks:
          caddy_net:
            ipv4_address: 172.19.0.10
        environment:
          - PUID=1000
          - GUID=1000
        depends_on:
          - hetzner-ddns
    Hetzner ddns is what I use to update my dynamic ip to hetnzer via API. I gave caddy a static ip in its bridge network for some troubleshooting but I could remove that without any change. I will paste here my caddy file:
    jellyfin.serveroneago.eu {
        reverse_proxy 192.168.68.62:8096
    easy peasy.
    In Jellyfin I wrote 192.168.68.62 in the known proxys section.
    Now let's come to my problem, whener I try to stream something outside my LAN, like on my phone in 5G on the jellyfin android app, the stream blocks almost instantly. I have a 30Mpbs upload so I ruled that one out. I went to look at caddy logs and I found two kinds of errors:
    First one is:
    {"level":"warn","ts":1744661377.3292377,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","upstream":"192.168.68.62:8096","duration":0.003041625,"request":{"remote_ip":"78.210.11.124","remote_port":"58754","client_ip":"78.210.11.124","proto":"HTTP/3.0","method":"GET","host":"jellyfin.serveroneago.eu","uri":"/Playback/BitrateTest?Size=1000000","headers":{"Sec-Fetch-Dest":["empty"],"Priority":["u=1, i"],"Sec-Fetch-Mode":["cors"],"Accept-Language":["it-IT,it;q=0.9,en-US;q=0.8,en;q=0.7"],"Authorization":["REDACTED"],"Sec-Ch-Ua":["\"Android WebView\";v=\"135\", \"Not-A.Brand\";v=\"8\", \"Chromium\";v=\"135\""],"Sec-Ch-Ua-Mobile":["?1"],"X-Forwarded-For":["78.210.11.124"],"Accept":["*/*"],"X-Requested-With":["org.jellyfin.mobile"],"Sec-Fetch-Site":["same-origin"],"Sec-Ch-Ua-Platform":["\"Android\""],"Accept-Encoding":["gzip, deflate, br, zstd"],"Cache-Control":["no-cache, no-store"],"User-Agent":["Mozilla/5.0 (Linux; Android 15; Pixel 9 Build/BP1A.250305.020.A2; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/135.0.7049.38 Mobile Safari/537.36"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["jellyfin.serveroneago.eu"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h3","server_name":"jellyfin.serveroneago.eu"}},"error":"writing: H3_REQUEST_CANCELLED"}
    Second one is:
    {"level":"warn","ts":1744661378.9086902,"logger":"http.handlers.reverse_proxy","msg":"aborting with incomplete response","upstream":"192.168.68.62:8096","duration":0.033417364,"request":{"remote_ip":"78.210.11.124","remote_port":"59216","client_ip":"78.210.11.124","proto":"HTTP/2.0","method":"GET","host":"jellyfin.serveroneago.eu","uri":"/Videos/db177dc4-cdb9-eea6-4aec-5162e214e4c0/stream?static=true&playSessionId=1807704d4dc542678781f281e7850815&mediaSourceId=db177dc4cdb9eea64aec5162e214e4c0&deviceId=cfc7d0e9dcd7dfc06d37fd4ce5744bf0bd57ba549d000a72&streamOptions=%7B%7D","headers":{"Accept-Encoding":["gzip, deflate, br"],"X-Forwarded-For":["78.210.11.124"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["jellyfin.serveroneago.eu"],"Icy-Metadata":["1"],"User-Agent":["Jellyfin Android/2.6.2 (Linux;Android 15) ExoPlayerLib/2.19.1"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"jellyfin.serveroneago.eu"}},"error":"writing: http2: stream closed"}
    I even tried limiting caddy to http1.1, but if I do that the error will change to tcp writing broken pipe.
    The file I'm trying to stream is being directly played, no transcoding. Here are the jellyfin logs:
    [20:17:19] [INF] [43] Emby.Server.Implementations.HttpServer.WebSocketManager: WS 78.210.11.124 request
    [20:17:21] [INF] [32] Jellyfin.Api.Helpers.MediaInfoHelper: User policy for Andrea. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True
    [20:17:50] [INF] [30] Emby.Server.Implementations.HttpServer.WebSocketManager: WS 151.59.72.186 request
    [20:17:53] [INF] [33] Emby.Server.Implementations.HttpServer.WebSocketManager: WS 151.59.72.186 closed
    [20:17:54] [INF] [34] Emby.Server.Implementations.HttpServer.WebSocketManager: WS 151.59.72.186 request
    [20:18:03] [INF] [33] Emby.Server.Implementations.HttpServer.WebSocketManager: WS 151.59.72.186 closed
    [20:18:03] [INF] [34] Emby.Server.Implementations.HttpServer.WebSocketManager: WS 151.59.72.186 request
    What's stranger is if I try to transcode to something very compressed like 420kbps, caddy will still output those warns, but the stream will go through.
    I will be eternally thankful to anyone who can help.
    2025-04-14, 08:41 PM
    Since it sounds like you are running Jellyfin in a VPS, we aren't concerned about "local" clients, right?
    What you can try doing is switch Jellyfin to bridge networking, put it in caddy_net, and then have caddy use the bridge IP for reverse proxy.
    Since Caddy is handling all connections, it makes sense to keep Jellyfin fully isolated in the bridge network. You don't even need to expose or publish any Jellyfin ports.
    MassiveA
    Country:Italy
    2025-04-14, 08:47 PM
    Sorry, Hetzner is merely providing the domain name. I'm locally hosting Jellyfin on my machine, through docker, and I would like access it both from my LAN and remotely. I will still try putting Jellyfin in the bridge network.
    2025-04-14, 09:27 PM
    You could still access jellyfin locally, but it would be through caddy. Not sure if that matters.
    MassiveA
    Country:Italy
    2025-04-15, 02:29 PM
    I wasn't able to try including jellyfin in the same bridge network as caddy today. I will give it a try tomorrow. But I have a question, would I still be able to access Jellyfin in my LAN with LAN speed, or would it require some tweaking in the caddyfile?
    2025-04-15, 02:51 PM
    If you have remote client bit rate limits, LAN clients will still be considered "local" and will not be restricted to your rate limit.
    MassiveA
    Country:Italy
    2025-04-15, 03:41 PM
    Perfect, thank you
    MassiveA
    Country:Italy
    2025-04-16, 02:40 PM
    I'm back and I've included Jellyfin in the same bridge network as caddy. Saddly I'm havin the same problems while streaming outside remotely. Caddy is giving me the same warns in the logs, while Jellfin is giving me this:
    [16:34:34] [INF] [30] Jellyfin.Api.Helpers.MediaInfoHelper: User policy for Andrea. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True
    [16:34:49] [INF] [30] Emby.Server.Implementations.Session.SessionWebSocketListener: Sending ForceKeepAlive message to 1 inactive WebSockets.
    [16:35:01] [INF] [37] Emby.Server.Implementations.Session.SessionWebSocketListener: Sending ForceKeepAlive message to 1 inactive WebSockets.
    [16:35:13] [INF] [32] Emby.Server.Implementations.Session.SessionWebSocketListener: Lost 1 WebSockets.
    Which is new.
    2025-04-16, 02:56 PM
    Can you share the new docker config for jellyfin and caddy (if caddy changed). And your current caddyfile (if it changed).
    MassiveA
    Country:Italy
    2025-04-16, 03:26 PM
    Of course, thanks for your help by the way.
    https://pastebin.com/VuwVFfJX
    I figured maybe it would be better looking using pastebin.
