    Jellyfin Forum Support Troubleshooting SOLVED: record with m3u tuner not visible
    goerdi
    Threads: 35
    2025-01-26, 11:34 AM (This post was last modified: 2025-01-26, 03:31 PM by goerdi. Edited 1 time in total.)
    Hi !
    I setup recording directory with jellyfin:jellyfin user and recording is successfully done (not error) and video file is there....
    but i cannot see it under recordings in the weg-gui
    [2025-01-26 12:25:00.015 +01:00] [INF] Beginning recording. Will record for 24.999742493333333 minutes.
    [2025-01-26 12:25:00.015 +01:00] [INF] Writing file to: "/data/jellyfin/Der Prinz von Bel-Air/Der Prinz von Bel-Air 2025_01_26_12_25_00 - Der Alptraum.ts"
    [2025-01-26 12:25:00.017 +01:00] [INF] "/usr/lib/jellyfin-ffmpeg/ffmpeg" "-async 1 -fflags +igndts -stream_loop -1 -reconnect_at_eof 1 -reconnect_streamed 1 -reconnect_delay_max 2 -analyzeduration 5000000 -i \"http://192.168.63.1:9981/stream/channelid/1729523798?profile=vaapi_x265_pass\" -codec:v:0 copy -fflags +genpts -map_metadata -1 -threads 0 -codec:a:0 copy -sn -y \"/data/jellyfin/Der Prinz von Bel-Air/Der Prinz von Bel-Air 2025_01_26_12_25_00 - Der Alptraum.ts\""
    [2025-01-26 12:25:00.043 +01:00] [INF] ffmpeg recording process started for "/data/jellyfin/Der Prinz von Bel-Air/Der Prinz von Bel-Air 2025_01_26_12_25_00 - Der Alptraum.ts"
    [2025-01-26 12:25:00.048 +01:00] [INF] Triggering refresh on "/data/jellyfin/Der Prinz von Bel-Air/Der Prinz von Bel-Air 2025_01_26_12_25_00 - Der Alptraum.ts"
    drwxr-xr-x 2 jellyfin jellyfin      4096 Jan 26 12:25 'Der Prinz von Bel-Air'
    -rw-r--r-- 1 jellyfin jellyfin      546 Jan 26 12:25 'Der Prinz von Bel-Air 2025_01_26_12_25_00 - Der Alptraum.nfo'
    -rw-r--r-- 1 jellyfin jellyfin 75235328 Jan 26 12:27 'Der Prinz von Bel-Air 2025_01_26_12_25_00 - Der Alptraum.ts'
    -rw-r--r-- 1 jellyfin jellyfin      116 Jan 26 12:25  tvshow.nfo
    Ciao Gerd
    I7-8700 / 32GB Ram
    Intel A380 / Ubuntu 24.04
    16 TB NAS TS-253
    2 TB NVME  / 2 TB SSD
    2025-01-26, 05:17 PM
    Do you have real time monitoring enabled? If not, the new recordings won't appear until the next scheduled scan.
    goerdi
    Threads: 35
    2025-02-03, 06:28 AM (This post was last modified: 2025-02-03, 06:47 AM by goerdi. Edited 2 times in total.)
    Hi !
    I will check..... but in common the TV recording thing with Jellyfin is not the best...
    edit: i checked and i have no possibility to enable real time monitoring for recording path...
    all time i have no Cover ... movies are shown as series and and and... anymay i use it only in emergency :-)
    BTw: but i will try
    Ciao Gerd
    I7-8700 / 32GB Ram
    16 TB NAS TS-253
