    Jellyfin Forum Support Troubleshooting Networking & Access SOLVED: sshfs mount does not work with Jellyfin
    Directories mounted with sshfs cannot be included in the library.
    Tron0070
    2023-12-18, 06:30 PM
    Hi guys, I recently got a fresh root server and wanted to mount a storage folder via sshfs. The folder has been mounted, but Jellyfin can't find the folder when I want to specify it as a library. Jellyfin simply closes the window.
    Does anyone know what I can do so that I can assign folders to the library that are mounted with sshfs?
    Thank you
    Jellyfin: Version: 10.8.13
    Kernel: x86_64 Linux 5.15.0-91-generic
    OS: Ubuntu 22.04
    AMD EPYC 7702
    8 GB DDR4 RAM (ECC)
    4 dedicated cores
    160 GB SSD
    root@v220231274841249262:~# cat /etc/fuse.conf
    # The file /etc/fuse.conf allows for the following parameters:
    # user_allow_other - Using the allow_other mount option works fine as root, in
    # order to have it work as user you need user_allow_other in /etc/fuse.conf as
    # well. (This option allows users to use the allow_other option.) You need
    # allow_other if you want users other than the owner to access a mounted fuse.
    # This option must appear on a line by itself. There is no value, just the
    # presence of the option.
    user_allow_other
    # mount_max = n - this option sets the maximum number of mounts.
    # Currently (2014) it must be typed exactly as shown
    # (with a single space before and after the equals sign).
    #mount_max = 1000
    Venson
    Threads: 8
    2023-12-18, 07:40 PM
    Hey,
    What do you mean by "Jellyfin simply closes the window."?
    Jellyfin 10.12.0 release will be Soon™
    [Image: default-yellow.png]
    Tron0070
    2023-12-18, 08:08 PM
    Hi Venso, thank you for your help.
    I click on "Add Media Library" then on the plus for "add Folders" (001.jpg). Then I select the folder. When the folder in which the directory is mounted is reached (002.jpg), the "Select Path" window appears again (003.jpg).
    Venson
    Threads: 8
    2023-12-18, 08:15 PM (This post was last modified: 2023-12-18, 08:15 PM by Venson.)
    OK lets go though that together.
    Step 1:
    Click the plus
    Step 2:
    Navigate down and click on the folder you want to enter until you see the insides of the folder you want to add.
    In this example i want to add /media/Comics/Deutsch
    Step 3:
    Click on "Ok"
    The new folder should now be visible in the list of folder.
    Step 4:
    Click on OK to close the dialog.
    Tron0070
    2023-12-18, 08:32 PM (This post was last modified: 2023-12-20, 04:35 PM by Tron0070. Edited 1 time in total.)
    I don't even get that far. Before I reach the folder, "Select Path" (003.jpg) appears again
    I have created a test account. This is hosted by Hetzner. Maybe you can use it for testing to find out what the problem is.
    sshfs -p23 u123456-sub6@u123456.your-storagebox.de:/home /choose/your/path/
    Passwort: ***************
    The account will be deleted later.
    Tron0070
    2023-12-18, 08:47 PM
    And the first hackers are already inside Smiling-face
    Venson
    Threads: 8
    2023-12-18, 08:53 PM
    did you add some symlinks?
    Cannot test that rn as i am not on my dev pc.
    Tron0070
    2023-12-18, 09:00 PM
    There are no symlinks.
    I'll leave the test account open for a while and watch the hackers
    Quote:ls
    cd ..
    ls
    sudo
    su root
    touch 1
    mount
    help
    tail /etc/passwd
    ls
    cd
    ls
    wget
    curl
    borg
    ls -la
    rm .hsh_history
    mkdir .ssh
    ls -la
    touch .ssh/authorized_keys
    ls -la
    echo
    Tron0070
    2023-12-20, 04:34 PM (This post was last modified: 2023-12-20, 04:36 PM by Tron0070. Edited 1 time in total.)
    OK. It now works with the two options "-o allow_other,default_permissions"
    sshfs -o allow_other,default_permissions username@server:/home /choose/your/path/
    Thanks again @Venson
    Venson
    Threads: 8
    2023-12-20, 04:54 PM
    You are welcome, but i really did not do anything^^
