    Jellyfin Forum Support Troubleshooting SOLVED: Streaming Issue on Multiple Devices with Android and Android TV
    2024-02-27, 10:21 PM (This post was last modified: 2024-02-27, 10:22 PM by TheDreadPirate.)
    Do you have a restriction on the number of simultaneous streams?
    Dashboard > Users > select "tv" user. How many concurrent streams is that user allowed?
    derwagenistrot
    2024-02-28, 01:03 PM
    It's set to 0.
    Furthermore, I'm using different accounts to access Jellyfin:
    tv user - for MiBox
    ivan user - for AndroidPhone
    docker - for web
    They are not shown in log, dunno why.
    wfreeman
    Country:Poland
    #13
    2024-02-28, 03:35 PM
    Today, I've got the same problem. I've made no changes to the configuration. I only have the up-to-date application on my Android phone. The server is still the same, 10.8.13, plus I have 'Throttle Transcodes' enabled.
    2024-02-28, 06:56 PM
    Are either of you using a reverse proxy? @derwagenistrot which docker image are you using? The official image or LSIO?
    derwagenistrot
    2024-02-28, 07:23 PM
    (2024-02-28, 06:56 PM)TheDreadPirate Wrote: Are either of you using a reverse proxy?  @derwagenistrot which docker image are you using?  The official image or LSIO?
    I use official image from https://hub.docker.com/r/jellyfin/jellyfin
    Reverse proxy is enabled, but not for jellyfin, i.e. when I added server in TV client i used 192.168.1.... address.
    2024-02-28, 08:05 PM
    Turn on debug logging, replicate the problem, then share the new log on pastebin or sourcebin.
    https://jellyfin.org/docs/general/admini...ug-logging
