    Jellyfin Forum Support General Questions Stops playing sound when screen locks
    Peter
    Country:Netherlands
    2024-06-25, 10:18 AM
    Hi,
    I just started using Jellyfin but Jellyfin stops playing mp3's when the screen locks.
    When playing a mp4, the screen will not lock.
    I'm using an Iphone (iOS Version: 17.5.1) and Jellyfin app Version 10.9.6
    I've tried the following settings:
    - Settings-General-Background App Refresh --> on, Jellyfin itself is not listed.
    - Settings-Battery-Low Power Mode --> off.
    - Within the Jellyfin app-Settings-Keep Screen Awake --> on.
    Tried also to logon via a Web Browser (Safari and Chrome), unfortunately same issue when the screen locks, Jellyfin via browser stops playing.
    When Setting-Display & Brightness-Auto-Lock --> never, Jellyfin keeps playing but to preserve the battery it would be great if it is possible to turn the screen off.
    Is there any other setting that I missed or is it not possible using an Iphone?
    Thank you in advance!
    2024-06-25, 11:58 AM
    On the Android app, there's a client setting for "background audio" meant for videos, but I assume it also works to allow audio-only files to be played in the background.
    Does the iPhone app have that setting? Try enabling it.
    pixel24
    Threads: 56
    2024-06-26, 08:56 AM
    Quote:On the Android app, there's a client setting for "background audio"
    Interesting. I have exactly this problem on both an Android and an iOS phone.
    @Peter: I don't currently have access to the iOS device because it is being used by a friend. Did the setting resolve the issue for you?
    Peter
    Country:Netherlands
    2024-06-26, 09:48 AM
    Hi,
    No, I cannot find the setting "Background Audio".
    I've added a screenshot, hopefully it is visible.
    2024-06-26, 12:20 PM (This post was last modified: 2024-06-26, 12:27 PM by theguymadmax. Edited 1 time in total.)
    Use Finamp, a dedicated Jellyfin music player. Background playing is not an issue.
    Peter
    Country:Netherlands
    2024-06-26, 01:43 PM
    Hi @theguymadmax,
    I've tried Finamp as well, but I'm unable to connect.
    When I populate the Server URL, like this: https://111.222.333.444:8096 and the right username and password:
    Error
    ClientException with SocketException: Connection refused (OS Error: Connection refused, erno = 61), address = 111.222.333.444, port = 55555, uri=https://111.222.333.444:8096/Users/AuthenticateByName
    When I populate the Server URL, like this: https://mydomainname.xxx and the right username and password:
    Error
    Could not fetch the response for POST https://mydomainname.xxx/Users/ AuthenticateByName.
    Status code: 403, error: Error processing request
    2024-06-26, 02:28 PM
    (2024-06-26, 01:43 PM)Peter Wrote: Hi @theguymadmax,
    Error
    Error
    When I logged on for the first time I got the same error when I tried to connect from my external ip. I'm pretty sure I was using the right credentials. Well about the 4th time it finally connected. Don't know what I did different.
    External server:
    https://mydomainname.xxx  - correct
    Internal server: try using http instead of https
    http:// 111.222.333.444:8096
    2024-06-26, 03:43 PM
    If you aren't using the Finamp beta, consider doing so. It is at a point where it is stable and pretty much feature complete.
    https://forum.jellyfin.org/t-announcing-...esign-beta
    But if you want to stick with the official android app, read my post in this thread.
    https://forum.jellyfin.org/t-jellyfin-an...0#pid21120
    It lists all the settings that you may need to double check in Android to allow for unrestricted battery and data usage in the background.
    Peter
    Country:Netherlands
    I tried to login several times without success, same error :-(.
    Finally, I thought about the "Maximum number of simultaneous user sessions" (Edit User - Profile - Maximum number of simultaneous user sessions) setting, which was set to 1 and I had already a Jellyfin session open. Increased the "Maximum number of simultaneous user sessions" setting and I was able to login.
    Now, when the screen locks or when using another app simultaneously, Finamp (mp3) keeps playing :-).
    Thank you all for your suggestions, especially @theguymadmax !
    Syndicate-Alchemsit
    2025-01-04, 09:54 PM
    (2024-06-26, 03:43 PM)Peter Wrote: I tried to login several times without success, same error :-(.
    I had my fingers crossed that this would work for me as well but it doesn't seem to have made a difference. I changed my 'Maximum number of simultaneous user sessions' parameter to 10, re-synced my Media files and reset my iOS Jellyfin app completely before re-logging and loading up a song.
    My MP3s are still pausing as soon as I minimize the Jellyfin app or lock my phone. Do you think it could be a hardware limitation? I'm using an iPhone SE (2nd Gen) with iOS 18.1.1.
