    Jellyfin Forum Support General Questions Stuck with H.264 and AAC audio
    "The audio codec is not supported" and "The video's range type is not supported"
    eyzinc
    2024-01-08, 11:29 PM
    Im watching spider man across the spider verse from a 4K blue ray rip i did and for some reason it says under the transcoding info, the "Video Codec" it says its H.264 and the "Audio Codec" is AAC even though that this movie is has HEVC Main10 and Dolby Atmos data. I went in and made the system not use H.264 as a transcoding video format option but it still uses it instead of HG.265. Any thoughts?
    tmsrxzar
    2024-01-08, 11:35 PM (This post was last modified: 2024-01-08, 11:36 PM by tmsrxzar. Edited 1 time in total.)
    it's a client setting not a server one
    what client?
    eyzinc
    2024-01-09, 12:42 AM
    Well I was watching it off of edge. Which said taht it was compatable with HEVC and better audio codec support
    tmsrxzar
    2024-01-09, 12:54 AM
    (2024-01-09, 12:42 AM)eyzinc Wrote: Well I was watching it off of edge. Which said taht it was compatable with HEVC and better audio codec support
    fact; browsers don't make good clients for jellyfin, opinion; edge is the worst pos
    use jellyfin media player for windows https://jellyfin.org/downloads
    2024-01-09, 01:02 AM
    Edge supports HEVC with some work, but it definitely doesn't support HDR. Audio codec support on Edge is about the same as other browsers. If you're on a Windows PC use either JMP or Jellyfin MPV Shim.
