    Jellyfin Forum Support Troubleshooting Sudden transcoding issue with Radeon 680M
    will.rkr
    2025-05-09, 08:53 PM
    I installed Jellyfin in a privileged LXC container on proxmox. I passed through /dev/dri/card1 and /dev/dri/renderD128 and everything worked smoothly yesterday. I confirmed that HW transcoding (AMD AMF) was enabled and played a couple of 4K movies without issues.
    This morning I noticed the container had halted. Oddly, even without rebooting the PC, /dev/dri/card1 was now card0. I updated the passthrough, powered it off and on. But now I can no longer play any videos with HW transcoding. Turning off HW transcoding enables me to play 480P movies but not 4K.
    I also tried VAAPI but the same error. When I ran this command, it generated errors below.
        /usr/lib/jellyfin-ffmpeg/ffmpeg -v verbose -init_hw_device vaapi=vaConfused-facedev/dri/renderD128 -init_hw_device opencl@va
        No matching devices found.
        Device creation failed: -19.
        Failed to set value 'opencl@va' for option 'init_hw_device': No such device
        Error parsing global options: No such device
    I installed the latest AMD GPU drivers and followed this guide.
         1. https://amdgpu-install.readthedocs.io/en...lling.html
         2. https://jellyfin.org/docs/general/post-i...ration/amd
    Happy to upload logs if those are useful. Here's a snippet from my one of my streams which seemed relevant.
             Stream mapping:
             Stream #0:0 (mpeg2video) -> setparams:default
             Stream #0:5 (dvdsub) -> scale:default
             overlay:default -> Stream #0:0 (av1_amf)
             Stream #0:1 -> #0:1 (ac3 (native) -> aac (libfdk_aac))
             [av1_amf @ 0x5e6de9d417c0] DLL libamfrt64.so.1 failed to open
             [vost#0:0/av1_amf @ 0x5e6de9d526c0] Error while opening encoder - maybe incorrect parameters such as bit_rate, rate, width or heigh
    t.
             [fc#0 @ 0x5e6de9d3b080] Error sending frames to consumers: Unknown error occurred
            [fc#0 @ 0x5e6de9d3b080] Task finished with error code: -1313558101 (Unknown error occurred)
            [fc#0 @ 0x5e6de9d3b080] Terminating thread with return code -1313558101 (Unknown error occurred)
            [vost#0:0/av1_amf @ 0x5e6de9d526c0] Could not open encoder before EOF
            [vost#0:0/av1_amf @ 0x5e6de9d526c0] Task finished with error code: -22 (Invalid argument)
            [vost#0:0/av1_amf @ 0x5e6de9d526c0] Terminating thread with return code -22 (Invalid argument)
            [out#0/hls @ 0x5e6de9d4f4c0] Nothing was written into output file, because at least one of its streams received no packets.
            frame=    0 fps=0.0 q=0.0 Lsize=      0KiB time=N/A bitrate=N/A speed=N/A
    Thanks in advance for your assistance.
    will.rkr
    2025-05-13, 03:59 AM
    FYI, I "solved" this a few days ago by recreating the container. I only passed in /dev/dri/renderD128 and set the group permission to match the one required by Jellyfin (993).
    I also went with VAAPI drives. All my 4K videos played smoothly. Sadly, today I had to restart the container to fix 4K playback though 480/1080P worked fine. So there does seem to be some flakiness in either the drivers/hardware or with Jellyfin itself.
    At some point, I'll run Plex in a container to see if I can isolate. A bit sad since I otherwise enjoyed Jellyfin performance and it's UI.
    nyanmisaka
    2025-05-13, 05:20 AM
    AMF is not recommended on Linux. Use VA-API instead.
