2023-08-12, 09:09 AM
(This post was last modified: 2023-08-12, 11:39 AM by Jolle. Edited 2 times in total.)
I'm running into a problem after the initial setup went well.
Setup is:
- a Synology with a N3160, which is a Braswell CPU from my understanding
- using this docker image: https://hub.docker.com/r/nyanmisaka/jellyfin
- all i changed (settings) was adding paths to my media+config+cache
Streaming/watching is working fine on all clients, at least until I try to transcode a file (force to lower resolution/bandwidth). It returns a "source error" no matter of the original file (container, codec, resolution).
Tried QSV and VAAPI.
Here's a log if that helps: https://pastebin.com/YfPpf2zE
Any helping hand would be greatly appreciated!
Setup is:
