2024-09-17, 08:56 AM
Hello. I spun up a virtual Jellyfin server. It seemed to be working but was being a bit sluggish. When I did a reboot Jellyfin did not start so after Googling it I ran sudo -u jellyfin /usr/bin/jellyfin start and I got the following error:
Error whilst attempting to create folder
System.IO.IOException: No space left on device : '/home/jellyfin/.local/share/jellyfin'
at System.IO.FileSystem.CreateDirectory(String fullPath, UnixFileMode unixCreateMode)
at System.IO.Directory.CreateDirectory(String path)
at Jellyfin.Server.Helpers.StartupHelpers.CreateApplicationPaths(StartupOptions options)
It seems like Jellyfin filled my drive which isn't entirely surprising cause I only gave it a 10GB drive. I upped it to 20GB and followed a guide online to expand the partition but I am still getting the same error. Can someone help me out. I'm not sure if I didn't expand it correctly or if I need to configure Jellyfin to be able to use the new space? This is what my partitions currently look like.
jellyfin@jellyfin:~$ sudo lsblk -o NAME,FSTYPE,SIZE,MOUNTPOINT,LABEL
[sudo] password for jellyfin:
NAME FSTYPE SIZE MOUNTPOINT LABEL
loop0 squashfs 55M /snap/core18/1880
loop1 squashfs 55.7M /snap/core18/2829
loop2 squashfs 38.8M /snap/snapd/21759
loop3 squashfs 64M /snap/core20/2318
loop4 squashfs 71.3M /snap/lxd/16099
loop5 squashfs 91.9M /snap/lxd/29619
sr0 1024M
xvda 20G #This used to be 10G
├─xvda1 1M
├─xvda2 ext4 1G /boot
└─xvda3 LVM2_member 17.6G #This used to be 9.something G
└─ubuntu--vg-ubuntu--lv ext4 17.6G / #This used to be 9.something G
xvdb 12.8T
└─xvdb1 ntfs 12.8T /media/ExternalDrive1 Elements
Please let me know if you need further information.
sr0 1024M
├─xvda1 1M
xvdb 12.8T
