    Jellyfin Forum Support Troubleshooting Transcoding issues and hardware acceleration
    Hardware acceleration doens't seem to work
    glassy
    2025-03-02, 04:29 PM
    Hello All,
    I've been having issues with transcoding during a recent re-install of jellyfin through docker. The issue appears on any player that I've tried so far (web player on localhost, jellyfin app on webOS).
    My host system is running arch, on an intel 10700K and an 7800XT (with mesa drivers). Jellyfin version is 10.9.7
    What I am noticing is extremely high cpu usage even in 1080p videos, and 4k videos are almost unplayable (lets 5s buffering for 1s of playback).
    My docker-compose looks like this:
        image: jellyfin/jellyfin
        container_name: jellyfin
        user: 1000:1000
        network_mode: 'host'
        security_opt:
          - no-new-privileges:true
        devices:
        group_add:
          - "989"
          - /home/iakovos/Git/config:/jellyfin-config
          - /home/iakovos/Git/cache:/jellyfin-cache
          - /mnt/MediaA/Series:/Series2
          - /mnt/MediaA/Movies:/Movies2
          - /mnt/one_tb_storage/home/iakovos/Downloads/Series:/Series
          - /mnt/one_tb_storage/home/iakovos/Downloads/Movies:/Movies
          - /mnt/one_tb_storage/home/iakovos/Downloads/Books:/Books
          - /mnt/one_tb_storage/home/iakovos/Downloads/AudioBooks:/AudioBooks
        restart: 'unless-stopped'
        extra_hosts:
          - "host.docker.internal:host-gateway"
    I've followed this guide (https://jellyfin.org/docs/general/administration/hardware-acceleration/amd/) and I can see the following outputs for the commands listed towards the virtualization section.
    sudo docker exec -it jellyfin /usr/lib/jellyfin-ffmpeg/vainfo --display drm --device /dev/dri/renderD128
    Trying display: drm
    libva info: VA-API version 1.21.0
    libva info: Trying to open /usr/lib/jellyfin-ffmpeg/lib/dri/radeonsi_drv_video.so
    libva info: Found init function __vaDriverInit_1_21
    amdgpu: os_same_file_description couldn't determine if two DRM fds reference the same file description.
    If they do, bad things may happen!
    vainfo: VA-API version: 1.21 (libva 2.21.0)
    vainfo: Driver version: Mesa Gallium driver 24.0.8 for AMD Radeon RX 7800 XT (radeonsi, navi32, LLVM 16.0.6, DRM 3.59, 6.13.2-arch1-1)
          VAProfileHEVCMain              : VAEntrypointEncSlice
          VAProfileHEVCMain10            : VAEntrypointEncSlice
          VAProfileAV1Profile0            : VAEntrypointVLD
          VAProfileAV1Profile0            : VAEntrypointEncSlice
    sudo docker exec -it jellyfin /usr/lib/jellyfin-ffmpeg/ffmpeg -v debug -init_hw_device vulkan
    Splitting the commandline.
    Reading option '-v' ... matched as option 'v' (set logging level) with argument 'debug'.
    Reading option '-init_hw_device' ... matched as option 'init_hw_device' (initialise hardware device) with argument 'vulkan'.
    Finished splitting the commandline.
    Parsing a group of options: global .
    Applying option v (set logging level) with argument debug.
    Applying option init_hw_device (initialise hardware device) with argument vulkan.
    [AVHWDeviceContext @ 0x5bf1a6b33500] Supported validation layers:
    [AVHWDeviceContext @ 0x5bf1a6b33500] VK_LAYER_MESA_device_select
    [AVHWDeviceContext @ 0x5bf1a6b33500] VK_LAYER_MESA_overlay
    [AVHWDeviceContext @ 0x5bf1a6b33500] GPU listing:
    [AVHWDeviceContext @ 0x5bf1a6b33500]    0: AMD Radeon RX 7800 XT (RADV NAVI32) (discrete) (0x747e)
    [AVHWDeviceContext @ 0x5bf1a6b33500] Device 0 selected: AMD Radeon RX 7800 XT (RADV NAVI32) (discrete) (0x747e)
    [AVHWDeviceContext @ 0x5bf1a6b33500] Queue families:
    [AVHWDeviceContext @ 0x5bf1a6b33500]    0: graphics compute transfer (queues: 1)
    [AVHWDeviceContext @ 0x5bf1a6b33500]    1: compute transfer (queues: 4)
    [AVHWDeviceContext @ 0x5bf1a6b33500]    2: sparse (queues: 1)
    [AVHWDeviceContext @ 0x5bf1a6b33500] Using device extension VK_KHR_push_descriptor
    [AVHWDeviceContext @ 0x5bf1a6b33500] Using device extension VK_KHR_sampler_ycbcr_conversion
    [AVHWDeviceContext @ 0x5bf1a6b33500] Using device extension VK_KHR_synchronization2
    [AVHWDeviceContext @ 0x5bf1a6b33500] Using device extension VK_KHR_external_memory_fd
    [AVHWDeviceContext @ 0x5bf1a6b33500] Using device extension VK_EXT_external_memory_dma_buf
    [AVHWDeviceContext @ 0x5bf1a6b33500] Using device extension VK_EXT_image_drm_format_modifier
    [AVHWDeviceContext @ 0x5bf1a6b33500] Using device extension VK_KHR_external_semaphore_fd
    [AVHWDeviceContext @ 0x5bf1a6b33500] Using device extension VK_EXT_external_memory_host
    [AVHWDeviceContext @ 0x5bf1a6b33500] Using device: AMD Radeon RX 7800 XT (RADV NAVI32)
    [AVHWDeviceContext @ 0x5bf1a6b33500] Alignments:
    [AVHWDeviceContext @ 0x5bf1a6b33500]    optimalBufferCopyRowPitchAlignment: 1
    [AVHWDeviceContext @ 0x5bf1a6b33500]    minMemoryMapAlignment:              4096
    [AVHWDeviceContext @ 0x5bf1a6b33500]    minImportedHostPointerAlignment:    4096
    [AVHWDeviceContext @ 0x5bf1a6b33500] Using queue family 0 (queues: 1) for graphics
    [AVHWDeviceContext @ 0x5bf1a6b33500] Using queue family 1 (queues: 4) for compute transfers
    Successfully parsed a group of options.
    exit status 1
    My configuration on the dashboard looks like this
    [Image: 3apaqyEwQcFp.png]
    Any ideas what could be wrong?
    2025-03-02, 05:35 PM
    Can you share your ffmpeg log via privatebin.net? One guess is that you have HEVC unchecked. Meaning you are CPU decoding videos that are 8-bit HEVC.
    You could also be audio transcoding and/or burning in subtitles. Both of which occur on the CPU.
    But your ffmpeg log would show us what is going on.
    Also, you are many versions behind.
    glassy
    2025-03-02, 06:21 PM
    (2025-03-02, 05:35 PM)TheDreadPirate Wrote: Can you share your ffmpeg log via privatebin.net?  One guess is that you have HEVC unchecked.  Meaning you are CPU decoding videos that are 8-bit HEVC.
    Thanks,
    my ffmpeg logs are here https://privatebin.net/?520f273c6fe0576f#cpjpK1PhgBYEVT8ScuzVG1jtMpTJsvPrbwUUeAKUxK7
    As for the version, I thought I was only a minor version behind (9 vs 10)?
    2025-03-03, 12:37 PM
    The third digit is a minor version. Bug fixes and security patches only, usually. Each 10.# version is a fairly major version change for Jellyfin with new features, API changes, and dependency upgrades. For example, going from 10.9 to 10.10 comes with a major ffmpeg upgrade from 6.1 to 7.0.2. There were 4 additional 10.9.X releases (10.9.11) and we are up to 10.10.6.
    But the log you shared doesn't appear to match your screenshot. In your screenshot you checked HEVC 10-bit decoding (you should also have HEVC checked) but the ffmpeg log doesn't indicate that it is hardware decoding this video. Nor does it show you have tone mapping checked (NOT VPP tone mapping).
    glassy
    2025-03-03, 10:23 PM
    (2025-03-03, 12:37 PM)TheDreadPirate Wrote: The third digit is a minor version.  Bug fixes and security patches only, usually.  Each 10.# version is a fairly major version change for Jellyfin with new features, API changes, and dependency upgrades.  For example, going from 10.9 to 10.10 comes with a major ffmpeg upgrade from 6.1 to 7.0.2.  There were 4 additional 10.9.X releases (10.9.11) and we are up to 10.10.6.
    Hey, thanks, upgrading my jellyfin image to 10.10.6 seem to have done the trick! Only thing is now every time I switch a view (i.e. going from /dashboard to /dashboard/settings) I have to do a hard refresh. I can see in the logs that my token is invalid each time
    jellyfin2  | [22:23:11] [INF] [22] Jellyfin.Api.Auth.CustomAuthenticationHandler: CustomAuthentication was not authenticated. Failure message: Invalid token.
    jellyfin2  | [22:23:11] [INF] [22] Jellyfin.Api.Auth.CustomAuthenticationHandler: AuthenticationScheme: CustomAuthentication was challenged.
    I doubt this is related to the transcoding I've issues but is it possible it is a known issue with this version?
    2025-03-04, 01:59 PM
    You probably need to clear your browser cache and you may need to purge old tokens in Dashboard > Devices. This will likely force you to log back in, creating a new token.
