    Jellyfin Forum Support Troubleshooting transcoding issues with jellyfin 10.10.7
    cannot get transcoding to work properly
    justtrife
    Threads: 8
    2025-05-26, 12:02 AM (This post was last modified: 2025-05-26, 12:08 AM by justtrife. Edited 3 times in total.)
    system specs
    msi z390 godlike
    i9-9900k
    arc a770 oc (16gb variant)
    32gb ram
    more space than you can shake a stick at.
    running fedora 42 (only os installed, jellyfin is NOT in a container)
    the issue I'm running into is, if I pick any of the 3 avail transcoding options avail to me in my setup (Intel qsv, vaapi or video4linux2) there are invariably files that will not play (ranging from avi to mkv), if I set it to none EVERYTHING plays properly but from what I can see it s not using the dgpu when set to none.  I can provide any logs I'm asked for to help resolve this issue.
    what throws me off is when I was on Linux mint/Ubuntu, Intel qsv was what I used and everything played properly.
    side issue: I cannot get music to work period, I used to have it working under windows when I was first getting my feet wet but I haven't been able to get this working under linux and I've been through 3 variants (Linux mint, Ubuntu and now Fedora), any help in this area would be greatly appreciated as I have about 700gb of music just sitting, it is stored on the same drive that I have other media that jellyfin does see.
    side side issue: I've noticed that the favorites button (the heart) appears to have disappeared and I do not know how to bring it back...
    thank you in advance for any help.
