    Jellyfin Forum Support Troubleshooting Transcoding Problem
    Transcoding Problem
    Virauge
    2023-09-12, 12:31 PM (This post was last modified: 2023-09-12, 12:50 PM by Virauge. Edited 1 time in total.)
    First time poster with an issue I've had for awhile.  When a video is being transcoded for DLNA playback, jellyfin server disconnects from the playback TV with roughly a 1 minute 30 seconds of playback remaining, every time.  I've noticed this with every transcoded video playback with this device and the jellyfin server.  I have attached a transcoding log that this has happened to and the jellyfin log, which I truncated removing stuff with timestamps outside of when the issues were occurring due to logfile size.  Any help would be appreciated.
    Jellyfin: 10.8.10
    OS: Ubuntu 22.04.3 Headless
    Architecture: x64
    Playback Device: Samsung PN60F5500 (It's an older TV 2016 I believe)
    Network: Wired 1gbit, both TV and Jellyfin server
    Server specs: AMD 5600G. 32GB RAM, 4TB HDD (3TB free space all allocated to be usable)
    Default setup for profiles and transcoding, no hardware acceleration enabled
    .txt   jellyfinlog.txt (Size: 125.22 KB / Downloads: 99)
    .txt   Log.txt (Size: 49.82 KB / Downloads: 128)
    2023-09-13, 12:11 AM
    Something is missing here and I'm not sure what. There are errors in the log that I can't personally trace far enough to make sense to me. The ffmpeg log doesn't appear to have any errors, but you've provided one and there are several instances where ffmpeg exited with a non-zero (unhappy) exit status, which should provide at least a little bit more information than the log that you've attached. If this is really it, I'd recommend trying debug logging, but be aware that the amount of information generated is HUGE in comparison to a regular log.
