    Jellyfin Forum Support General Questions Trickplay too slow. What will help?
    mrcoffee
    2025-04-25, 03:37 PM
    I have about 40tb of data on a truenas ixsystem server . I’m currently generating trickplay images at a rate of 1 movie every two minutes. At this rate I’ll be done in 11 days.
    Would hooking up a 12gb Nvidia 4070 super in my server  make the trick play images any faster ? Right now I assume it’s just the cpu doing it.
    Also why was I able to complete the trick play on Emby in just a few days if they are using the same ffmpeg program to convert ? I don’t like Emby but it was much faster for me. I was using key frames only for it also.
    Any guidance on making it faster would be great. I already have all 6 cores assigned to jellyfin.
    Thanks for the help.
    2025-04-25, 04:51 PM (This post was last modified: 2025-04-25, 04:53 PM by Efficient_Good_5784. Edited 1 time in total.)
    While you can make the trickplay task use a GPU, it will actually make the process slower than on a CPU.
    What I have been told before is that unless your CPU is really low-powered and slow, it's better to just let the CPU handle the creation.
    That said, trickplay creation has an option to use video keyframes, which is what you want to use if you want this to go by faster.
    The reason keyframes makes things go faster is because normally, the trickplay task needs to process a video frame by frame. As it's going frame by frame, it's keeping track of the time and obtaining a frame at the desired interval that it will then convert to a jpg image for the trickplay file. The process of going through each frame takes time.
    The reason you need to go through each frame in order is because modern video codecs have different types of frames. The majority of the frames present in an encoded video are not full images by themselves, but are the difference between the last few frames and itself at that point in time in the video.
    Keyframes (also known as I-frames) are 100% full images that don't need any other frames to show the full picture. Depending on how the video was encoded, you will have a number of these all throughout the video. You can quickly pull these up since they are already complete by themselves.
    By choosing to use keyframes in Jellyfin's trickplay task, what you're doing is finding the closest keyframe relative to each time period you set for the task and using that for the video scrubbing preview. You'll be trading accuracy of your time interval for images, but using keyframes is super fast compared to the traditional way to create them.
    So tl;dr is to enable the keyframe option if you want this to go by fast.
    mrcoffee
    2025-04-25, 05:46 PM
    Thanks for the reply. . It’s currently set on key frames only already. With key frames off it does about a movie an hour or two on an 8 core 2.2 Intel atom CPU. Maybe I’ll wait it out , I just couldn’t figure out why it was slower than Emby with the same settings.
    Thanks for your reply. It helps out a lot. I appreciate it.
