2025-01-04, 03:51 PM
Hey all, first I want to give a bit of background to explain why this is suddenly an issue after using Jellyfin for 2-3 years probably. A few months ago, the Pioneer bookshelf speakers I was using started popping, so I upgraded my speakers. But I went from a speaker amp and passive speakers to two powered studio monitors. Thus, I went from a speaker amp with a single volume knob within easy reach to two monitors, each with a volume knob on the back that would be extremely inconvenient and annoying to have to constantly adjust.
The last couple weeks are the first time I've watched anything on my computer using Jellyfin Media Player since the speaker upgrade, and the volume is VERY quiet when Direct Playing. If I play the video directly over the network share using VLC at 100% volume, it is MUCH louder than Jellyfin Media Player at 100% volume. That's why I'm assuming this is probably some client setting related, but I'm not really seeing anything that looks like it might be applicable.
I'm not even sure I'm looking in the right place for the client settings, but I went to the hamburger menu > Settings > Playback under the User category. I tried setting Maximum Allowed Audio Channels from Auto to 2, and I tried setting Audio Normalization from Track Gain (which I like to have to apply ReplainGain metadata for music) to Off. Neither change made any difference.
The server itself doesn't seem to have any audio playback settings at all as far as Direct Play is concerned, so I don't think the server is the issue here.
I'd appreciate any help with this. It may be that this was always an issue, but when I had a volume knob within arm's reach it wasn't a big deal to adjust the volume up for playing a movie on Jellyfin then back down for playing YouTube or video games or whatever else. But now I would have to stand up, reach behind each of two speakers, and adjust the volume up before playing a movie, then repeat that process to adjust it back down when doing anything else, and that's simply not a tenable solution anymore.
I know the server has a volume boost or something under transcoding settings, so if worse comes to worse I might have to resort to just forcing it to transcode the audio, or just stop watching media on my PC and watching it on my TV, since it wouldn't be a big deal to adjust the volume there.
Tgabjs
Tgabjs
You can force server to transcode everything (including video) but this is not a solution.
