    Jellyfin Forum Support General Questions What’s the best way to listen to audio books using Jellyfin on iPhone?
    Reken
    2024-02-27, 01:01 AM
    I’ve used the Jellyfin app and it’s really finicky. Swiftfin, Finamp and Infuse don't even display my audio book library. Is there another way to do it that I’m missing?
    2024-02-27, 02:12 AM
    I am assuming you are using the Books type library for your audio books. Which is what you should be using since the Music library doesn't support playback tracking/resume. Those clients do not support Books libraries.
    Tcon
    2025-03-07, 07:22 PM
    I have this same problem. On the iPhone app and using a browser on my phone the audio stops as soon as the app goes into the background or I lock the phone? Is there a way to fix this or just hope a future update addresses it? I have my audiobooks in a books library.
    2025-03-07, 07:37 PM
    This is a long running issue with our iOS app.
    https://github.com/jellyfin/jellyfin-expo/issues/19
    For music check out Finamp via Apple Testflight.
    https://testflight.apple.com/join/UqHTQTSs
    Not sure what options there are for audio books.
    Tcon
    2025-03-09, 06:58 PM
    Ok thanks
    OcherSpangly
    2025-07-27, 03:27 AM
    For iPhone, BookPlayer has been great for audiobooks. It’s open source, has all the functionality I expected, and was designed to import audiobooks from Jellyfin.
    34626
    Threads: 41
    Country:Denmark
    2025-07-27, 01:54 PM
    I just use Jellyfin app.
    My audiobooks is re-encoded to .opus and kept in .mka container - works great.
    Just use "books" as content type of the library.
    Debian 13 | Jellyfin 10.11 RC-9 docker | Intel N5105 | RAM 32 GB | 26 TB storage
