2025-05-07, 06:47 PM
(This post was last modified: 5 hours ago by b-riched. Edited 12 times in total.)
Hi there,
Yes, me too, i.e. Clients won‘t Connect to Jellyfin Server.
Web-Clients do connect, but Client Apps do not.
[edit]
Specifically
IOS Safari or Win11 Edge browser will connect via 192.x.z.149:8096 with defined users
But…
Tried iOS Jellyfin Mobile App which tells me ‘unable to connect’
Trier iOS SwiftFin App which tells me that either there is no Internet Connection (external) or
cannot detect any local server in the first place.
Tried iTV Box JF client which will find the server at 192.x.z.149 but does not connect (no error message displayed)
[edit]
Ideas so far (with no success)
- 0.0.0.0 Trick, incl. Trying to connect to one of the listed addresses the JF server is listening (e.g. 172.17.01.1:<ports>)
- switching IPv6 off/on
- naming different IP addresses
- allowing external JF server access
- updating JF apps
- broadcasting to 192..x.y.255 and to 0.0.0.0
- adding one of the 4 ports to the address (192.x.y.149:7359, etc.)
- adding the /jellyfin suffix (and combinations to the above)
- trying other IP addresses such as 192.x.y.3 will be detected by iTV JF App but will cot connect.
- adding protocol prefix to the address, i.e. ‘http://192.x.y.149:7359’ or ‘…:8096’ will not help and IMHO should not,
as the client app does not open a http connection.
I believe that the corresponding ‘http bug’ has already been fixed anyway.
Any other further idea?
Many thanks in advance
LAN:
AVM 6690 cable Router
IPv4 / IPv6
No Open Ports
Net: 192.x.y.1 / 255.255.255.0 (no further Subnets)
Homeserver:
OS: UnRaid 7
UnRaid Server: 192.x.y.149 (Static IP defined by Router)
AdGuard Running on 192.x.y.2 (Static IP defined by Router)
Jellyfin docker V. 10.10.7 up and running fine, users defined, PWs set
Jellyfin Installation:
JELLYFIN_PublishedServerUrl: 192.x.y.149 for both, container and LAN IP
Ports (default): 8096 / 8920 / 7359 / 1900
HTTPS: disabled / Not forced
Remote Access: disabled
IPv4, IPv6 enabled
JF Server Not Published (outside local NW)
[edit]
JF Log File:
- does show successful connections to web-clients.
- does NOT show any unsuccessful connections attempts issued by the JF apps
- does show that networking manager filters for 192.x.y.149 (which is what I would expect it to do)
[edit]
Specifically
But…
[edit]
- updating JF apps
LAN:
IPv4 / IPv6
No Open Ports
Homeserver:
OS: UnRaid 7
IPv4, IPv6 enabled
[edit]
JF Log File:
