For the life of me, I can’t find a simple walkthrough on how to do this and all the info I see makes it sound like you just need only one file to add to the plugin folder. Whereas it seems like you need more than one.
My problem is this, I am trying to install jellyfin theme songs and kodisyncqueue plugins. I have done the net stuff and got my bin folder with the .dlls.
But which files do I need to copy from that folder and drop into the plugins folder and what would be the name of the folder I make for them within that folder. I gather that for the themes plugin its supposed to be a folder called theme songs or so,but what about kodisync?
any help would be appreciated.
