    Jellyfin Forum Support Troubleshooting Networking & Access Buffering on Remote Connection
    PantherGuyMan
    2025-10-04, 02:32 AM
    Hello Jellyfin Forms. Long time lurker, first time poster.
    I've been a happy user of Jellyfin for a little over 2 years now, and have absolutely loved it. Having only done local access in that time, I've recently tried moving into remote access for my Windows 10 server. I've been spending time away from home more often recently and want to access my server outside of my local network. I even bought some more Nvidia Shields for the occasions.
    Since I've made this switch, I've noted an anomaly. Anytime I try to play certain HEVC-encoded media, it simply will not play without constant stuttering. Not all HEVC content is like this, only certain specific ones. This is when direct streaming HEVC content with no transcoding. The streaming device can either be hard wired or wireless connection, it does not make a difference. I've connected everything remotely with Tailscale, and as far as I can tell the network speed is nearly unaffected. Connections at both locations are just under 1 gigabit down and up.  At home, no issues and all is working as it should. This only happens when connecting out of my local network.
    I've tried disabling transcoding completely since other posts point to this being a possible cause, to no avail. I monitored windows task manager while this happened and saw no spikes of any kind in the system, from either the drives nor the processors. I appreciate any assistance that can be provided.
    Server Specifications are as follows:
    CPU: Intel Xeon E5-2697 V4
    RAM: 32GB DDR4
    GPU: Intel ARC A380
    Boot Drive: Crucial 500GB SSD
    Media Drives: Seagate Ironworlf Pro 20TB X2
    schnappi
    2025-10-14, 11:52 PM
    How are you accessing remotely? Tailscale, port forwarding, or something else? Regardless, if you are using Tailscale or something else, temporarily test with port forwarding via HTTP (create a test user and dummy media if you don't want this test to go over the internet) and see if the issue is replicated.
