    Jellyfin Forum Support Troubleshooting Cannot Enable Low Power Encoding for Synology 423+(J4125)
    initzhang
    Country:Hong Kong
    2024-05-31, 12:07 PM (This post was last modified: 2024-06-01, 01:33 PM by initzhang. Edited 3 times in total.)
    Hi there, I have some troubles in enabling the low power encoding (H264) on my new 423+.
    I have done the following steps, could anyone point out what is missing/wrong for me? Many thanks in advance!
    (1) I have downloaded the i915 firmware from git.kernel.org (tag=20240513) and put them under /lib/firmware/i915.
    Quote:$ ls -l /lib/firmware/i915/ | grep -E "bxt|glk"
    [quote]
    -rwxr-xr-x 1 root root    8380 May 30 23:55 bxt_dmc_ver1_07.bin
    -rwxr-xr-x 1 root root  176256 May 30 23:55 bxt_guc_32.0.3.bin
    -rwxr-xr-x 1 root root  181888 May 30 23:55 bxt_guc_33.0.0.bin
    -rwxr-xr-x 1 root root  196224 May 30 23:55 bxt_guc_49.0.1.bin
    -rwxr-xr-x 1 root root  199616 May 30 23:55 bxt_guc_62.0.0.bin
    -rwxr-xr-x 1 root root  216768 May 30 23:55 bxt_guc_69.0.3.bin
    -rwxr-xr-x 1 root root  206464 May 30 23:55 bxt_guc_70.1.1.bin
    -rwxr-xr-x 1 root root  140928 May 30 23:55 bxt_guc_ver8_7.bin
    -rwxr-xr-x 1 root root  146432 May 30 23:55 bxt_guc_ver9_29.bin
    -rwxr-xr-x 1 root root  149824 May 30 23:55 bxt_huc_2.0.0.bin
    -rwxr-xr-x 1 root root  154432 May 30 23:55 bxt_huc_ver01_07_1398.bin
    -rwxr-xr-x 1 root root  146880 May 30 23:55 bxt_huc_ver01_8_2893.bin
    -rwxr-xr-x 1 root root    8800 May 30 23:55 glk_dmc_ver1_04.bin
    -rwxr-xr-x 1 root root  176640 May 30 23:55 glk_guc_32.0.3.bin
    -rwxr-xr-x 1 root root  182336 May 30 23:55 glk_guc_33.0.0.bin
    -rwxr-xr-x 1 root root  196672 May 30 23:55 glk_guc_49.0.1.bin
    -rwxr-xr-x 1 root root  200000 May 30 23:55 glk_guc_62.0.0.bin
    -rwxr-xr-x 1 root root  217216 May 30 23:55 glk_guc_69.0.3.bin
    -rwxr-xr-x 1 root root  206784 May 30 23:55 glk_guc_70.1.1.bin
    -rwxr-xr-x 1 root root  226048 May 30 23:55 glk_huc_4.0.0.bin
    -rwxr-xr-x 1 root root  222080 May 30 23:55 glk_huc_ver03_01_2893.bin
    (2) I have edited the /etc/modprobe.d/i915.conf file which contains the following content.
    Quote:$ cat /etc/modprobe.d/i915.conf
    i915.enable_guc=2
    (3) I have rebooted the machine many times, but the GuC and HuC status are null.
    Quote:$ sudo cat /sys/kernel/debug/dri/0/i915_huc_load_status
    HuC firmware: (null)
    status: fetch NONE, load NONE
    version: wanted 0.0, found 0.0
    header: offset 0, size 0
    uCode: offset 0, size 0
    RSA: offset 0, size 0
    HuC status 0x00006000:
    $ sudo cat /sys/kernel/debug/dri/0/i915_guc_load_status
    GuC firmware: (null)
    GuC status 0x00000001:
    Bootrom status = 0x0
    uKernel status = 0x0
    MIA Core status = 0x0
    Scratch registers:
    0: 0x0
    1: 0x0
    2: 0x0
    3: 0x0
    4: 0x0
    5: 0x0
    6: 0x0
    7: 0x0
    8: 0x0
    9: 0x0
    10: 0x0
    11: 0x0
    12: 0x0
    13: 0x0
    14: 0x0
    15: 0x0
    (4) the dmesg shows nothing about GuC and HuC also
    Quote:$ dmesg | grep i915
    [   24.567361] [drm] Finished loading DMC firmware i915/glk_dmc_ver1_04.bin (v1.4)
    [   25.593843] [drm] Initialized i915 1.6.0 20171222 for 0000:00:02.0 on minor 0
    [   25.634993] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
    My machine: Linux Synology423plus 4.4.302+ #69057 SMP Fri Jan 12 17:02:28 CST 2024 x86_64 GNU/Linux synology_geminilake_423+
    I am using the latest 10.8.13 nyanmisaka/jellyfin pulled from container manager
    ==== update 2024Jun1:
    I just find out that the full dmesg output contains the following two lines, which are weird since glk firmware is public available
    Quote:[   34.002180] [drm] GuC: No firmware known for this platform!
    [   34.002181] [drm] HuC: No firmware known for this platform!
    Then unfortunately I found a patch of intel driver kernel indicating that GuC and HuC are deliberately turned off for glk CPU because by then the firmware was not ready... https://patchwork.kernel.org/project/int...intel.com/
    So now the only solution is to downgrade DSM back to where the patch is not applied?
    2024-05-31, 07:19 PM
    Where are you running these commands? I didn't know that Synology gave you shell access to the OS. FWIW, Gemini Lake does not require low power encoding.
    initzhang
    Country:Hong Kong
    2024-06-01, 12:02 PM
    TheDreadPirate dateline='[url=tel:1717183177' Wrote: 1717183177[/url]']
    Hi, thanks for your reply!
    I ran these commands in the shell of synology after enabling its ssh.
    As for the LP encoding I think it is possible according to this thread. I can transcode with jellyfin, just want to make the most out of itSmiling-face
    https://www.reddit.com/r/jellyfin/commen...are_button
    2024-06-01, 06:09 PM
    Do you have HDR content? My understanding is that low power encoding only really comes into play when tone mapping HDR to SDR.
    But to answer your question, I re-read your post and re-read the low power encoding guide.
    Step 2 states you need to put this in /etc/modprobe.d/
    sudo mkdir -p /etc/modprobe.d
    sudo sh -c "echo 'options i915 enable_guc=2' >> /etc/modprobe.d/i915.conf"
    Yours only has "i815 enable_guc=2" without options at the beginning.
    initzhang
    Country:Hong Kong
    2024-06-02, 07:52 AM (This post was last modified: 2024-06-02, 08:12 AM by initzhang. Edited 1 time in total.)
    (2024-06-01, 06:09 PM)TheDreadPirate Wrote: Do you have HDR content?  My understanding is that low power encoding only really comes into play when tone mapping HDR to SDR.
    Hi, thanks for the reply. Yes I do have a lot HDR and DoVi contents.
    Depending on the linux kernel version (pre or after 4.15 according to https://cdrdv2-public.intel.com/609249/6...v1-1-1.pdf) and distro, all possible options are:
    • i915.enable_guc=2
    • i915.enable_guc_loading=1 i915.enable_guc_submission=1
    • options i915 enable_guc_loading=1 enable_guc_submission=1
    • options i915 enable_guc=2
    Unfortunately none of these four works.
    I have also updated the main thread, the root cause seems to be a patch regarding the 4.4 kernel of DSM 7.2.
