    Jellyfin Forum Support Troubleshooting Dolby Vision MKV + Android TV - remux not working
    awfulfun
    2025-04-10, 03:26 AM (This post was last modified: 2025-04-10, 11:04 AM by awfulfun. Edited 1 time in total.)
    I can play Dolby Vision MKV files on my Android TV through apps such as Kodi, but not through Jellyfin. I've read that Jellyfin can use ffmpeg to remux in real time, but it doesn't seem to work for me.
    When I attempt to play the file, I get a black screen with no audio, and the time code does not move from 0:00.
    Log:
    [2025-04-09 23:15:37.956 -04:00] [INF] [134] Jellyfin.Api.Helpers.MediaInfoHelper: User policy for "Henry". EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True
    [2025-04-09 23:16:14.582 -04:00] [INF] [115] Emby.Server.Implementations.HttpServer.WebSocketManager: WS "192.168.1.154" closed
    [2025-04-09 23:16:14.867 -04:00] [INF] [56] Emby.Server.Implementations.HttpServer.WebSocketManager: WS "192.168.1.154" request
    [2025-04-09 23:20:38.037 -04:00] [INF] [12] Emby.Server.Implementations.Session.SessionManager: Playback stopped reported by app "Android TV" "0.18.6" playing "The Shiver of the Vampires". Stopped at "300000" ms
    awfulfun
    2025-04-10, 11:26 AM (This post was last modified: 2025-04-10, 11:30 AM by awfulfun. Edited 1 time in total.)
    I've also noticed that I don't get an FFmpeg.Transcode... log file when attempting to play a Dolby Vision file on this TV.
    If I play the same file on other devices however, or if I reduce the bit rate low enough, I do get a log file and the file plays.
    2025-04-10, 01:04 PM
    Which kind of Android TV device do you have?
    awfulfun
    2025-04-10, 03:32 PM
    2023 Sony Bravia TV
    2025-04-10, 04:56 PM
    Can you post the media info of the file?
    awfulfun
    2025-04-10, 05:07 PM (This post was last modified: 2025-04-10, 05:09 PM by awfulfun. Edited 1 time in total.)
    Container: mkv
    Path: /data/z_Disc Backups/Movies - Backups/The Shiver of the Vampires/The Shiver of the Vampires.mkv
    Audio
    Title: Mono - French - PCM_S24LE - 1 ch - Default
    Language: fra
    Codec: PCM_S24LE
    AVC: No
    Channels: 1 ch
    Bitrate: 1152 kbps
    Sample rate: 48000 Hz
    Bit depth: 24 bit
    Default: Yes
    Forced: No
    External: No
    Video
    Title: 4K HEVC Dolby Vision Profile 7.6 (HDR10)
    Codec: HEVC
    AVC: No
    Profile: Main 10
    Level: 153
    Resolution: 3840x2160
    Aspect ratio: 16:9
    Anamorphic: No
    Interlaced: No
    Framerate: 23.976025
    Bitrate: 73464 kbps
    Bit depth: 10 bit
    Video range: HDR
    Video range type: HDR10
    DV title: Dolby Vision Profile 7.6 (HDR10)
    DV version major: 1
    DV version minor: 0
    DV profile: 7
    DV level: 6
    DV rpu preset flag: 1
    DV el preset flag: 1
    DV bl preset flag: 1
    DV bl signal compatibility id: 6
    Color space: bt2020nc
    Color transfer: smpte2084
    Color primaries: bt2020
    Pixel format: yuv420p10le
    Ref frames: 1
    Audio
    Title: Mono - English - PCM_S24LE - 1 ch
    Language: eng
    Codec: PCM_S24LE
    AVC: No
    Channels: 1 ch
    Bitrate: 1152 kbps
    Bit depth: 24 bit
    Default: No
    Forced: No
    External: No
    Audio
    Title: Stereo - French - Dolby Digital
    Language: fra
    Codec: AC3
    AVC: No
    Layout: stereo
    Channels: 2 ch
    Bitrate: 112 kbps
    Default: No
    Forced: No
    External: No
    Audio
    Title: Stereo - English - Dolby Digital
    Language: eng
    Codec: AC3
    AVC: No
    Layout: stereo
    Channels: 2 ch
    Bitrate: 112 kbps
    Default: No
    Forced: No
    External: No
    Subtitle
    Title: English - PGSSUB
    Language: eng
    Codec: PGSSUB
    AVC: No
    Resolution: 1920x1080
    Default: No
    Forced: No
    External: No
    Subtitle
    Language: eng
    Codec: PGSSUB
    AVC: No
    Default: No
    Forced: No
    External: No
    Subtitle
    Language: eng
    Codec: PGSSUB
    AVC: No
    Default: No
    Forced: No
    External: No
    2025-04-10, 06:33 PM
    Dolby Vision Profile 7.6 is known to have compatibility issues with certain devices on the Android TV platform. These issues tend to be very device-specific. One potential workaround is to set the audio to stereo, which might trigger transcoding, even if your source audio is mono. Alternatively, lowering the video bitrate could also force a transcode. Another option is to remove Dolby Vision from the file entirely, see here.
    awfulfun
    2025-04-10, 06:47 PM
    Thanks for the info. However, this file works fine when played via the Kodi app on the same TV. Any ideas?
    2025-04-10, 07:08 PM
    Kodi offers better compatibility with Dolby Vision files. One of the workaround I usually mention for these issues is to use Kodi with the Jellyfin plugin or use Kodi as an external player with the AndroidTV app.
    awfulfun
    2025-04-10, 07:39 PM (This post was last modified: 2025-04-10, 07:39 PM by awfulfun.)
    Hmm, so I'm also having a very similar if not same issue playing back a 1080p file. Here's the media info:
    S01E13 Angel One
    Container: mkv
    Path: /data/Shows/Star Trek The Next Generation/Season 01/S01E13 Angel One.mkv
    Video
    Title: AVC - 1080p - H264 - SDR
    Codec: H264
    AVC: Yes
    Profile: High
    Level: 41
    Aspect ratio: 16:9
    Anamorphic: No
    Interlaced: No
    Bitrate: 20746 kbps
    Bit depth: 8 bit
    Video range: SDR
    Video range type: SDR
    Ref frames: 1
    NAL: 4
    Audio
    Title: FLAC 7.1 - English - Default
    Language: eng
    Codec: FLAC
    AVC: No
    Layout: 7.1
    Channels: 8 ch
    Bitrate: 4050 kbps
    Bit depth: 24 bit
    Default: Yes
    Forced: No
    External: No
    Codec: MJPEG
    AVC: No
    Profile: Baseline
    Resolution: 2240x2809
    Bit depth: 8 bit
    Color space: bt470bg
    Pixel format: yuvj444p
    Ref frames: 1
    To confirm, most of my other files are working without issue
