    Jellyfin Forum Support Troubleshooting Dolby Vision MKV + Android TV - remux not working
    #11
    2025-04-10, 07:47 PM
    FLAC 7.1 doesn't work for me on the Android TV client, but that’s a separate from the DV issue. For that, you can go to Preferences > Developer Options, then enable "Prefer FFmpeg for audio playback." I’d only recommend using this setting for compatibility issues, like with FLAC 7.1 audio.
    awfulfun
    2025-04-10, 11:07 PM (This post was last modified: 2025-04-10, 11:09 PM by awfulfun.)
    Amazing, that fixed playback for the 1080p file, thank you
    Is there any way to force transcoding that doesn't meaningfully reduce video or audio quality?
    2025-04-11, 11:44 AM
    There is pretty much no discernible drop in quality for AUDIO, regardless. How much quality you lose with video transcoding depends on your hardware.
    Recent-ish Intel and Nvidia GPUs will both transcode with little or no noticeable drop in quality.
